249 user(s) are online (196 user(s) are browsing Forums)
teebee, more...
JonnyAngle Say I want 47psi...
Minneapolis, MN
151 Posts
...of boost that is. No, just kidding. Say I want 47 psi for my fuel pressure...
When testing it:
Do I have the FPR hose disconnected or connected?
Do I have the car idling, or just in the run position?
How long after I kill the motor should it hold this pressure?
Thanks in advance.
Posted on: 2008/9/9 20:41
bogus Re: Say I want 47psi...
The engine idling, with the vacuum hose off.
It should hold it for a good 15~20 minutes.
I had a fuel pump problem a month ago, and it would hold 40 PSI for about 2 minutes, then drop off like a rock to 30.
Posted on: 2008/9/9 20:53
Matatk Re: Say I want 47psi...
What do you need 47 psi for? Are you testing something or is it for mods?
Posted on: 2008/9/9 22:10
CentralCoaster Re: Say I want 47psi...
What year?
Fuel pressure on my 85 is less than 40 psi.
Posted on: 2008/9/9 22:27
Schrade Re: Say I want 47psi...
Fuel pressure should be tested static (motor off, fuel rail primed), idle with vacuum on FPR, idle with vacuum off of FPR, and pedal down - gauge taped to windshield.
Entire article here:
http://www.corvetteforums.com/m_37283/tm.htm
Posted on: 2008/9/9 23:05
Mekanic Re: Say I want 47psi...
Tampa Bay Florida
827 Posts
http://www.corvetteforums.com/upfiles ... 141548C7EB4DAF97A25E6.jpg
Correct.
And you should have right around 43psi
Posted on: 2008/9/10 0:41
~Rich
Polo LT4
JonnyAngle Re: Say I want 47psi...
Minneapolis, MN
151 Posts
according to tpis, that's what i should run at. (back of package on adjustable fuel pressure reg).
Headers, and basically straight pipes are my performance mods.
Posted on: 2008/9/10 0:43
Tampa Bay Florida
827 Posts
You wont see any performance gains at all upping the fuel pressure, just a loss of mileage and possibly some codes
Posted on: 2008/9/10 0:52
~Rich
Polo LT4
I agree. I don't think with those mods you'll need to up your FP. From what I've read/been told, the computer can adjust for these type of mods without a problem.
Posted on: 2008/9/10 1:25
