193 user(s) are online (125 user(s) are browsing Forums)
BrianCunningham My tuner's car
http://forums.corvetteforum.com/c4-te ... 2196104-398-85-build.html
[QUOTE]SloRvette:
Finally got a car put together for myself.:willy:
[IMG]http://i102.photobucket.com/albums/m102/p8638/P1010044.jpg[/IMG]
12:1 4.040 bore GM 4 bolt 1 piece rear main seal truck block, Eagle 3.875" stroke crank, Eagle 6" rods, Ross pistons - Calico coatings turbo top, anti fricton sides, Canfield heads ported to 215 cc - intake flows 317 @ .700" lift, ported StealthRam - heads flowed the number with intake attached, injectors rolled over for direct port dry nitrous, custom plenum with Accufab Lightning Monblade throttlebody, solid roller cam 242/250 @ .050" .672" gross intake lift .688" gross exhaust lift, Comp solid roller lifters with high pressure roller oiling, custom 3" stainless exhaust, Hooker 2151 headers, FAST XFI, 60 lb injectors, Walbro 340 pump feeding Bosch 044 pump
[IMG]http://i102.photobucket.com/albums/m102/p8638/P1010040.jpg[/IMG]
[IMG]http://i102.photobucket.com/albums/m102/p8638/P1010042.jpg[/IMG][/QUOTE]
Posted on: 2008/12/2 15:44
Schrade Re: My tuner's car
Pretty tight.
'Bout 600hp?
Posted on: 2008/12/2 18:43
pr0zac Re: My tuner's car
that is about the same as my car but mine is hydraulic roller and only a 385.
Posted on: 2008/12/2 19:53
will he do obd2 lt1's if the person has the tuning program?
Posted on: 2008/12/2 19:55
BrianCunningham Re: My tuner's car
Yes!
New, old, he's pretty much done everything.
Posted on: 2008/12/2 20:06
should i just pm him?
Posted on: 2008/12/2 20:25
Notorious Re: My tuner's car
I'll bet that mofo honks! Beautiful craftsmanship and I love the gold finish on the car too. That's one extremely nice C4.
Posted on: 2008/12/2 20:45
If your on the other forum.
I PM'ed him about this thread.
So, who knows he might sign up.
Posted on: 2008/12/2 23:10
bobges Re: My tuner's car
Bushkill PA
254 Posts
Nice ride
Posted on: 2008/12/3 0:19
jsup Re: My tuner's car
1778 Posts
I love the color...
Posted on: 2008/12/3 0:20
Update
SloRvette;
StealthRam 398 - 10.59@129
Took my '85 to Etown for the Challenge today. First time to the track with the car. Pretty much no WOT tuning, just a WAG. Normally aspirated 398 - all motor on 275/45/17 MT drag radials
Here's a link to the car http://forums.corvetteforum.com/c4-te ... 2196104-398-85-build.html
Ran this like the car was sitting in the other thread.
I'm excited.:cheers:
EDIT more info
SloRvette;
That was all motor. No nitrous.
There's no roll bar in the car so I don't see myself going back to Etown anytime soon with this car. I'm bulding a '90 that's going to have a jungle gym in it (25.5 cert.).
This car has such a cool factor in that there's nothing to give away it's performance. Idles nice at 900 rpm. Power brakes work no problem. It's a super clean car - real nice interior, no guages, 17" wheels, stock shifter, AC, the whole bit. I just really don't want to put a bar in it. It's my history that as soon as I put a bar in, the car becomes a race car and not a street car.
Next time to the track will be to get a time slip with the nitrous.
The cam isn't as bad as I thought it would be. Ed Curtis from FlowTech Inductions helped out on this one. 109 lsa, idles at 60-65 kpa. The car does have a FAST XFI on it running true sequential with proper cylinder sequence/firing. Getting that right really helped the idle out. 60 lb injectors. 4000 stall Protorque 9" converter also helps out on the driveabilty.
Also need to give a big thanks to Mike Theroux from Mikesportingservice.com for the great work on the heads and intake.
Posted on: 2009/4/6 2:10
Epimax Re: My tuner's car
Wilmington, NC
1814 Posts
Very Nice!
Posted on: 2009/4/6 10:14
Matatk Re: My tuner's car
22810 Posts
That car is a beast. A lot to handle, too.
Posted on: 2009/4/6 11:36
