Durango_Boy | Spot what's wrong? | ||
[IMG]http://i106.photobucket.com/albums/m242/durango_boy/CIMG1187.jpg[/IMG]
Posted on: 2009/4/29 21:52
Jeffvette | Re: Spot what's wrong? | ||
Only doing 40. What a pussy!
Posted on: 2009/4/29 21:53
TommyT-Bone | Re: Spot what's wrong? | ||
Tac is whack
Posted on: 2009/4/29 21:54
Durango_Boy | Re: Spot what's wrong? | ||
Yeah he slowed down from 80 so the camera wasn't shaking so badly.
Posted on: 2009/4/29 22:08
CentralCoaster | Re: Spot what's wrong? | ||
He's driving a Corvette instead of a Ford?
Posted on: 2009/4/29 22:18
Sweet90 | Re: Spot what's wrong? | ||
Driving a C4?
Jim |
Posted on: 2009/4/29 23:26
pianoguy | Re: Spot what's wrong? | ||
I won't be doing that for a while *sniff* |
Posted on: 2009/4/29 23:46
JrRifleCoach | Re: Spot what's wrong? | ||
He's using the two finger steering wheel hold.
Owns a Ford. Needs to trim finger nails? |
Posted on: 2009/4/30 0:27
As democracy is perfected, the POTUS represents more closely the inner soul of the people. On some great and glorious day, the folks of the land will reach their heart's desire at last and the White House will be occupied by a fool and narcissistic moron. |
Yeah the Ford key just seemed so out of place and just plain wrong while burning up Columbia in a Corvette.
Posted on: 2009/4/30 0:43
What did you find out Brad? By your post doesn't sound good |
Posted on: 2009/4/30 1:14
DaleD | Re: Spot what's wrong? | ||
Your car broke? I didn't see your post about it, what happened? |
Posted on: 2009/4/30 1:27
Whenever someone says "I'm not book smart, but I'm street smart", all I hear is "I'm not real smart, but I'm imaginary smart". |
I am pretty sure I lost a rod bearing. I talked to the shop today, and got a SWAG of $3-4K to fix it - pull the engine, complete tear-down, clean-up, and reassembly with whatever needs fixing. They are really backed up though, and it could take a month or more to turn it around. I'm going to check out a couple other places tomorrow. The guy said he sees this bearing failure once in a while on cars that sit for long periods or aren't driven regularly. He told me that the wrist pins can seize up a bit and it puts more strain on the bearings. |
Posted on: 2009/4/30 3:32
bogus | Re: Spot what's wrong? | ||
hm...
there are better options. What about a used motor? Check Golan for a short block? |
Posted on: 2009/4/30 5:50
Yeah, I have been mulling that over, though I would kind of like to keep the original engine.
Posted on: 2009/4/30 10:29
Epimax | Re: Spot what's wrong? | ||
3-4G....Good Grief......Sorry to hear that Brad.... I guess you could put a used motor in it, and keep the original to fix up later? |
Posted on: 2009/4/30 11:13
Wow, that's too bad. But, you sound like you're more worried about the downtime than the cost. If so, that's a good thing. A high mile car, I'd go with what the other said and look at a new short block. Whatever you do, hope you get it done fast. |
Posted on: 2009/4/30 13:49
It only has 47K on it
Posted on: 2009/4/30 14:24
Oooops. I got your car confused with another. I take it back then. I'd fix it too. |
Posted on: 2009/4/30 14:57
If nothing else, I have done an outstanding job of hijacking this thread :-P
Posted on: 2009/4/30 15:28
