606 user(s) are online (92 user(s) are browsing Forums)
wesmigletz Took the 62 for a spin
Land of Fruits and Nuts
325 Posts
Since I haven't driven the 62 since this past Summer, the wife and I decided to go for a ride.
Given the car's age, number's matching quality,and supposed value, we don't drive it nearly as much as we once did. However, it was a beautiful day, and since sitting for long periods aren't good for a car, either, we decided, what the heck...
Posted on: 2010/1/2 23:40
BrianCunningham Re: Took the 62 for a spin
cool
Posted on: 2010/1/3 0:26
Andrew Re: Took the 62 for a spin
Jefferson City, MO
447 Posts
Bwhahahaaaaaaa.. I was expecting a nice sunny, calm Saturday drive, not a burnout. Very nice!
Posted on: 2010/1/3 0:38
2003 Atomic Orange Z06
SOLD 1979 4 Speed with 383
bogus Re: Took the 62 for a spin
that car is the anti-NCRS.
Cool, Wes! Great to see ya around!!!!
Posted on: 2010/1/3 2:33
wesmigletz Re: Took the 62 for a spin
325 Posts
Thanks Bogus. It's good to be home... for another week anyway.
Posted on: 2010/1/3 3:47
TommyT-Bone Re: Took the 62 for a spin
34655 Posts
Glad you got to spank it a little. Enjoy your week home.
Posted on: 2010/1/3 12:58
Matatk Re: Took the 62 for a spin
22996 Posts
Looks like a blast! What kind of times did you run? What is the most recent/current engine combo, too? I lost track....
Posted on: 2010/1/3 16:33
pianoguy Re: Took the 62 for a spin
Outstanding!
Posted on: 2010/1/3 16:40
325 Posts
The combo is unchanged from the last time I raced in July. I just drove to the track, and emptied the trunk, and let her rip. The key variables were that in July, I ran at Famoso in mid 90* temps. This time was at Fontana with low-mid 70s temps. Fontana has a higher elevation and tends to be a bit slower than Famoso, but the temps were lower.
The combo is still the original, #s matching 327 + .040", 3.85" stroke (395 CI +/-), 6.0" rods, 9.6:1 compression, AFR 195 CC street eliminator heads, ported #7530 Weiand Team G intake (only beacuse it fits under a stock hood, using a GM drop base intake), a 670 CFM vacuum secondary Holley carb, a 282 Comp HR, ground on a 112* LSA, 1.6 roller rockers, 1 3/4" Hooker Super Comps, a 2 1/2 exhaust, that exits the rear of the car (over the rearend), a 700R4, 1800-2200 stall converter, original 3.36 rear, 235/60/R15 M/T ET street.
The weak link in the combo is the 5400 RPM shift point of the trans when left in D, with the stock PG shifter.
My first and best pass was:
1.811 60'
7.666 1/8 @ 89.28
12.149 @ 112.83
I only got two 1/4 mile runs because of heavy winds. The second pass, hot-lapped, was 12.19 @ similar MPH.
My best 1/8 was:
1.74 60'
7.696 @ 90.21 MPH
Of course, this was on a 7.7 dial-in...
Posted on: 2010/1/3 20:23
Mekanic Re: Took the 62 for a spin
Tampa Bay Florida
827 Posts
damn good shit wes :D
Posted on: 2010/1/3 21:13
~Rich
Polo LT4
325 Posts
Mekanic, nice avatar. I just spent the past 15 minutes trying to explain to the wife what it meant...
Posted on: 2010/1/4 4:10
ok... I am lost... what does it mean???
Posted on: 2010/1/4 5:14
cuisinartvette Re: Took the 62 for a spin
2 in the pink, 1 in the stink
Posted on: 2010/1/4 15:50
pr0zac Re: Took the 62 for a spin
wow that thing runs.. i mph'd similar to that with my cammed 355 lt4 but my 60 ft's could come close to your auto.
Posted on: 2010/1/4 19:38
Ok... I would rather not have to spend 15 minutes translating THAT one...
Thanks. I feel so much more enlightened now.
Posted on: 2010/1/5 3:21
Tampa Bay Florida
827 Posts
It's known as "the shocker"
And wes... it's easier to just show em
Posted on: 2010/1/5 6:28
~Rich
Polo LT4
325 Posts
The combo runs pretty good for what it is. I like that the engine can do it while fitting under a stock hood. The ET and MPH are both being held back by my low shift points. The trans shifts about 900 RPM too soon.
The combo has 3 things going for it: stroker crank, HR cam, and AFR heads. The intake is less than ideal given the low shift points, moderate cam, 3.36 gears and low stall converter. I'd like to run an RPM airgap, but it won't fit under hood. When I tested the old combo at the track, the Team G was worth .2 seconds and almost .5 MPB vs a Weiand 8120 low-rise dual plane intake. So, I doubt I could improve the ET with a swao to the 8120, or an old C3B I have.
Posted on: 2010/1/6 0:39
