154 user(s) are online (93 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
383tpimachine 427 SBC cam help
Corpus Christi
976 Posts
I am specing out cams that would work well with a combo Im saving for. It will be a dart lil M block 427. Will either run 220 or 227 competition ported AFRs. All forged and leaning towards a 250-300 shot of juice.
My dilemma is that I suck about cam selection. I have been snooping around comp cams website and the xfi seems promising. is the 292 with .58int and .57ex to big? I know it would be much to large for a 350 but on a 427 with a good tune would it peak around 7000rpm?
Stall will be bought to match the cam and this car will be street driven to local hangouts.
Any input will be appreciated. Im young and this is the one area I have yet to learn much about
Posted on: 2010/1/8 23:43
pr0zac Re: 427 SBC cam help
it would be alright in a 427
Posted on: 2010/1/8 23:57
383tpimachine Re: 427 SBC cam help
Corpus Christi
976 Posts
What stall with 3.55 gears and 3.73? 3200?
How about idle speed? 8-900 doable?
Posted on: 2010/1/9 0:03
i am no cam expert but i would imagine that be a somewhat of a good cam for a 427. without running a sim on it i would say its going to peak before 7k for sure. my cam is larger (245/253@0.050) in a 383 and idles around 900 without a problem and its on a 107lsa. 88blackz51 has a similar sized cam as what you are looking at in a 421ci. you could pm him for where he got his cam. i would say at least a 3.55 gear and 3000 rpm stall as a minimum. but how you want to use the car would determine alot on where i would go from there.
Posted on: 2010/1/9 3:14
bogus Re: 427 SBC cam help
7000 RPM? damn.
Posted on: 2010/1/9 6:46
cuisinartvette Re: 427 SBC cam help
With that displacement a big head and a 7000 rpm peak Id steer towards a solid roller around the mid 250-260.050 duration, lift mid-high 6xx....of course with n20 it may want less. Talk to a professional grinder that knows his way around nitrous to get the right one though.
tpi421Vette could probably give you some good pointers, he builds and races those big small blocks all the time.
A HR cam isnt going to live long twisting it to 7k and youve got too much invested in that to find out the hard way.
Posted on: 2010/1/9 15:12
why do you want to peak at 7000 rpms?
Posted on: 2010/1/9 19:35
Corpus Christi
976 Posts
thats the highest the engine will ever spin. Realistically I see 63-6500 shift points.
I will never get an off the shelf grind cam when for a few bucks more I can get a custom grind. There is a few local guys who are cam gurus that I will consult with prior to purchase.
Why cant a HR spin to 7000? with correct springs and topend wouldnt it be fine? I understand the solid cam but dont want this to be constantly under the knife adjusting things
Posted on: 2010/1/10 2:30
A HR can spin to 7k but they dont like it, the lifters that is. They are heavy in comparison to solids and the risk of them pumping up and tagging a valve is high;eliminate that factor and its become more reliable.
Its my opinion youre losing power and reliability over a solid with a high rpm motor using a HR. Either one should be checked once or twice a yr anyway if its a sizable cam. No need for constant adjustmets, rollers dont really wear.
Old flat tappet cams with stock rocker arms diffferent story. YOu got plenty of CI and cyl head that sucker is going to want to breathe deep.
If it was only goign to see 6300 or so then a HR may be the way to go.
Everyones got their opinions though all I can say is dont be afraid of a solid, # for # youll get more power under the curve, more torque and better manners.
Flame away :book:
Oops, just reread your post. 3.73 gears and a sub3k stall maybe stick with a HR thats smaller than what I originally posted.
Posted on: 2010/1/10 4:05
BeachBum Re: 427 SBC cam help
751 Posts
I pretty much agree with cuisinartvette..... tough to go to 7000 rpm with a hyd roller.... some do it, but its usually when everything is fresh.... a month later after the springs have gotten a bit loose, valve float starts appearing by 6500 rpm. Nowadays there are quite a few solid rollers built specifically for the street... typically with nice valvetrain friendly gentle lobe ramps, thus adjusting lash isn't required every other week and instead just 1 or 2 adjustments per year are necessary.
But, I won't vouch for how well they do with prolonged idle that a daily driver see's.....I hear some have figured out how to make them last, others say don't run them on the street.... that is, if you're a daily driver seeing extended street driving. Its a tough decision and should be based upon how you truly are going to drive your vette.
But, with 427 cubic inches, with a solid roller, to have a HP peak at 7000 rpm is more cam than you think with a 23 degree head.... something in the range of 264/268 and even a bit bigger would be required.... that same cam could take a 383 to over 7000 rpm, but your motor would eat it up....talk to skidownit on the corvette forum.... I think that is the cam he has been running or thereabouts, and I think his peak is still before 7000 rpm with his 434.... which is par for the course.
If its a true street car, I'd suggest you stay with a hyd roller in the 240 area, if your motor is running right, it should make 550 HP at around 5600-6000 rpm.... and even as much as 575ish..... which is an awful lot of power for the street.... almost stupid power. It'll be perfectly happy with a tight 3k converter as well.
good luck with whatever you do and let us know what you decide on.
Posted on: 2010/1/10 6:54
C4 Corvette 436 - Pure Black
88BlackZ51 Re: 427 SBC cam help
481 Posts
Any news for us? Looking forward to that video!
Posted on: 2010/1/10 11:29
Corpus Christi
976 Posts
I have just always been told a solid takes constant attention. But hearing thsi I might go that route. The car wont see much idle time. It will be to and from the cruise ins which I get to by highways from where I currently live.
What all is needed to run a solid cam?
Posted on: 2010/1/10 22:39
They require very little in the way of maintenance, its blown way out of proportion by the "I heards" on the internet lol.
Get the best lifter you can.....Crower severe duty with the pin oiling option are real nice, Isky red zomes have a good rep too. Maybe someone else has a favorite.
Posted on: 2010/1/11 0:30
anesthes Re: 427 SBC cam help
Boston, MA
Use camquest to get a baseline.
How much power do you want the thing to make?
For a street car I'd think anything larger than 210cc heads would be overkill. 300 cfm should do a little over 7500 on a 427, at 100% VE, and support a little over 630hp naturally aspirated.
Obviously the larger heads have more flow, but with the larger cross sectional area I'd feel the velocity loss on the street would be a bad thing everywhere but peak.
-- Joe
Posted on: 2010/1/11 13:41
Corpus Christi
976 Posts
-- Joe
Camquest is confusing as hell to me and cant exactly find a solid cam that would fit.
I first wanted to go with the 195 comp port from AFR but figured the extra cubes would let me use bigger without a problem. 210s be better?
Posted on: 2010/1/11 17:01
Boston, MA
Camquest will help choose a camshaft a lot better than guys on the forum will. You can get an idea based on your target operating range, intake manifold selection, etc.
For a street car, you want something with enough flow to meet your horsepower and RPM requirements, and decent port velocity. The CNC 210 heads flow over 300 cfm at .550 lift
The 195s flow around 275cfm and have great velocity numbers around 130cfm per square inch. The 210s flow more, and still have respectable velocity numbers in the 120s. Once you get into the 220+, the cross sectional area is much larger for high RPM race applications, so you give up a little down low.
For a *street* car, and not a 9 second pin on body bracket car, I'd go with 210s.
One of AFR's major strong point is the ability to flow remarkable airflow in a smaller cross sectional area. An AFR-1040 (195cc) head flows the same CFM as most 220cc heads by other manufacturers, and do it in a 2.18 square inch port. When people say you need "xxx cc head for a xxx inch block" it's because they are used to other heads flowing a lot less. Most 200cc heads flow in the 240s, 250s tops with large cross sectional areas of 2.20".
About the closest flowing head to the 1040 in the 195cc class is the pro-filer, however it has a larger cross sectional area, requires a felpro 1206 port match, AND the exhaust port is lazy like an LT1 head so you need a lot of camshaft split to get it to perform. And with a price point of only a few hundred bucks away from AFR, it makes it not worth the trouble.
-- Joe
Posted on: 2010/1/11 18:05
Corpus Christi
976 Posts
thanks joe. sounds like the 210 will be a good cross between street and strip
The camquest would help if you would come up with results. It doesnt show any when I put in 400block and solid cam
Posted on: 2010/1/11 18:15
1970 El Camino-Awaiting LSX
Boston, MA
427 block, solid roller, 'good' dual plane intake, naturally aspirated, 10.5:1 compression, mild cam, 850 carb.
You could model it with a miniram or some other EFI intake as well. Hp will probably be within 30hp of what camquest says. I usually model things in engine analyzer to get a real idea. But still.. 600+hp..
No need for nitrous, unless you need 900hp..?
-- Joe
jpg  383-tpimachine.JPG (238.30 KB)
1607_4b4b6dff3584c.jpg 1129X810 px
Posted on: 2010/1/11 18:29
481 Posts
is this motor for the street or for the track?
Posted on: 2010/1/11 18:45
Corpus Christi
976 Posts
mostly strip but local hotrod hangout once a month would be nice.
maybe i need to update mine it doesnt come up with any. and yes I want 800rwhp so nitrous up to a 400 would be great
Posted on: 2010/1/12 5:10
Boston, MA
What is the transmission and rear end?
I know a handful of guys with 900+ hp (flywheel) combos, but they did it with twin turbos and the hit is not as hard.
-- Joe
Posted on: 2010/1/12 11:11
Corpus Christi
976 Posts
-- Joe
very built 4L60e and a d44 soon
Posted on: 2010/1/12 17:04
Boston, MA
-- Joe
The 4L60E might live for a little bit. I've heard of 800fwhp rated 4l60s..
The Dana44, if you hook, I'd think would explode at 800rwhp..
-- Joe
Posted on: 2010/1/12 20:15
yeah not to be rude but there is no way in hell you are going to be able to drop a 400 shot on a friggin d44. hell it won't last with just the engine you are thinking about on a dead hook.
Posted on: 2010/1/12 20:28
tpi421vett Re: 427 SBC cam help
Salt Lake City Utah
125 Posts
I think everyone here has given some real good advise. If you go solid roller, you could go with a Comp 248/254, and I would run a 112 lobe sep with nos. The motor you are talking about was similar to one of the 421's I did. It made 502 rwhp and 481 rwtq N/A. 11.0 compression, ran fine on pump gas.would pull to 6500 rpm. With a 200 shot it made 720 rwhp and 790 rwtq. I really wouldn't spray more than a 250 shot myself. There is alot more room for problems if you want any sort of engine longevity. And a D44 won't have a prayer of living with a big motor and any nos. I broke everything behind the trans (ZF6) and ended up with a 9". And personally I don't think a 4L60 would live long either. I have never had good luck with any engine I have done that had a 4L60. I would go T400 or a 4L80, but both of those will take some obvious fabrication.
Posted on: 2010/1/13 0:12
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
Boston, MA
Agreed. Guys I know that are running over 800fwhp are running TH400s and 9" or 12 bolts.
Jim you should be getting two phone calls tomorrow or the next day.
-- Joe
Posted on: 2010/1/13 4:06
Corpus Christi
976 Posts
thanks for the info.
I was hoping to run the D44HD and hope it handles the shot ok.
How much fab to get a 4L80e to fit? I know I would need a custom driveshaft but if thats what it takes im ok with that.
Want to avoid going straightaxle tho.
Posted on: 2010/1/13 5:26
Salt Lake City Utah
125 Posts
It's been done before, but I have never done one. And a 4L80E will need a stand alone computer to make it work, unless you have aftermaket ecu that can make it work. You would have to fab C beam bracket, and or some sort of crossmember, if the C beam bracket wasn't strong enough. But the c beam would need to attach to it. I am sure you can find guys that have done it out there.
One thing you do have going for you is a automatic is much easier on parts than a manual. So if you left the line easy, and I have seen guys pull timing for X amount of feet, and didn't spray nos right away, and had the strongest D44 you could build it might last for a while.
But I really think once you get to mid to low 10's and quicker, you are going to start to have problems. I have seen a few guys that stick with the IRS, and after so many runs, they go thru and inspect and rebuild everything after so many runs. The faster you go, the more you have to work on it. And the less parts last.
Posted on: 2010/1/13 6:09
Boston, MA
PATC sells the cbeam adapter for the 4L80E.
On paper, the 800+ rwhp sounds wonderful but. In reality, your spending a ton of money to make a car that was meant for carving canyons go fast in a straight line and make it to the finish line in one piece.. I guess I'm the silent minority, but IMO a street car is complete and goes 11s/high 10s, a track car has no interior, a straight axle, and lives on a trailer 6 days a week.. Vega or early nova comes to mind.
-- Joe
Posted on: 2010/1/13 11:41
Corpus Christi
976 Posts
Thats why I want to keep IRS. the car will rarely see juice. More for show than anything but the 427 will get autoX and maybe a lil PCA.
Im still doing the drivetrain. Can an LS1 ecu control the 4L80e? I plan on buying the swap kit for better tuning.
This car isnt meant for the strip. It will see it maybe once a year. For longlevity maybe I will do a twin fogger a 100hp shot and a 200shot that switch off after so many feet. I just love the way a DP system looks
Posted on: 2010/1/13 17:46
i think your best bet would be to spray the engine you have.. i promise you that a d44 wont last.. i have a gladiator 44 from exotic muscle and its shit the bed on a 340rwhp car.. you think for a second its going to last in a 800fwhp car you are out of your mind.
Posted on: 2010/1/13 19:16
-- Joe
+1.
Posted on: 2010/1/13 19:18
Salt Lake City Utah
125 Posts
pr0zac wrote:
I have a gladiator 44 from exotic muscle and its shit the bed on a 340rwhp car.. you think for a second its going to last in a 800fwhp car you are out of your mind.
Wow... that is really dissapointing to hear. I thought the Gladiator D44 was better than that, especially for the price.
Posted on: 2010/1/18 4:39
nothing broke. i just seized the spider gear to the shaft.
Posted on: 2010/1/18 16:10
flyboy Re: 427 SBC cam help
I will be looking forward to updates on your project.
Posted on: 2010/1/22 3:20
Corpus Christi
976 Posts
Im still playing with my 383. Next its getting the LS1 pcm and built 4L60e. Im just getting everything I need before actually dropping in the next engine. The D36 will hopefully last a a little while before grenading.
Posted on: 2010/1/22 4:03
