196 user(s) are online (130 user(s) are browsing Forums)
uxb101 LS6 motor in my yukon?
CANADA
75 Posts
Hello Guru's
I have a 1999 yukon vortec 5.7 auto with engine problems,i found an ls6 motor with 30k on it ,will this motor bolt up too my tranny, wiring?
this is part of the ad......LS6 engine, complete, from a 2001 z06 with 30k kms
$1800
thanks
Andrew
Posted on: 2010/6/13 1:26
bogus Re: LS6 motor in my yukon?
buy it.
It will fit. The wiring should be REAL close. The PCM will need to be flashed to work right. I would expect accessories to be the biggest difference. You will more than likely need to swap them over.
The truck engine and the car engine are the same basic architecture. Many builders will use the iron LQ9 block to replace the aluminum LSx block when doing major boost.
Damn... that would be COOL.
Posted on: 2010/6/13 2:04
uxb101 Re: LS6 motor in my yukon?
CANADA
75 Posts
I'm going to offer the guy $1500
Posted on: 2010/6/13 3:39
Steve40th Re: LS6 motor in my yukon?
1114 Posts
Its a bolt in per sey. Check the engine for the oiling issues they had as there was a low tension ring issue I believe that was fixed via TSB etc for the 2001 LS6.
Posted on: 2010/6/13 3:57
Ko'u ohana aia ku'a ikaika
CANADA
75 Posts
the motor in the yukon is fouling the plugs on the centre plugs right bank really bad and i dont know if its rings or valve seals/guides,so im thinking just drop in the ls6 ,would be a fun job,will it bolt up to the bellhousing?
Posted on: 2010/6/13 4:11
Yes. GM Bellhousings have been pretty standard for years.
Posted on: 2010/6/13 4:18
CANADA
75 Posts
thats good 380 hp
jpg  sucp_0008_04_z+2001_chevrolet_corvette+LS6_engine.jpg (71.42 KB)
2371_4c145d184be69.jpg 640X480 px
Posted on: 2010/6/13 4:23
Posted on: 2010/6/13 4:33
pr0zac Re: LS6 motor in my yukon?
i am 99% sure that the 99 yukons had the first gen sbc's in them. its not a direct replacement.
Posted on: 2010/6/13 17:30
I am not so sure... lemme check.
I did some research... considering it is an iron head and block, I bet you are right.
I thought the LSx family of Vortec engines started in 1999... a couple of years past the LS1 started in the Vette.
Posted on: 2010/6/13 17:49
CANADA
75 Posts
so it wont bolt up,i left the guy with the motor 2 messages no return call ,maybe its sold??? well i'll just pull the heads off the 5.7 and see whats wrong with it...hope its just a valve spring.
Posted on: 2010/6/13 18:24
BillH Re: LS6 motor in my yukon?
Yea, '99. My 2000 Silverado has a 5.3 Vortec.
Posted on: 2010/6/13 20:49
then what is in this yukon?
Posted on: 2010/6/14 0:34
CANADA
75 Posts
5.7 L31
Engine Details
SAE Net Horsepower @ RPM 255 @ 4600
Engine Type Gas V8
Engine Order Code L31
Displacement 5.7L/350
Fuel System SFI
SAE Net Torque @ RPM 330 @ 2800
Engine Oil Cooler Yes
Posted on: 2010/6/14 3:33
383tpimachine Re: LS6 motor in my yukon?
Corpus Christi
976 Posts
L31 should be a gen 1. the only 350 im aware of is a gen 1/2 sbc
gen 3 had the ls1/ls6 with 346cuin
Posted on: 2010/6/14 4:05
1970 El Camino-Awaiting LSX
if it were a gen 3 it would be a 5.3 or a 6.0. i worked on a tahoe a few weeks ago that was a 99 and had the older style 350 in it.. i know they changed the trucks in that year to the new style..
Posted on: 2010/6/14 13:08
teebee Re: LS6 motor in my yukon?
12370 Posts
He has the early 99. Late 99's got the 5.3 like mine which is LS based.
Posted on: 2010/6/14 14:08
SpectatorRacing Re: LS6 motor in my yukon?
Looks like we should do an LT1 swap, then
Posted on: 2010/6/14 16:55
Raidmagic Re: LS6 motor in my yukon?
Florida
168 Posts
It will still bolt up to your trans. YOu will need a different converter and motor plates for the mounts. You can get a harness at Current performance that will allow you to run the car and motor but will need a computer from the LS family for the engine. It won't be a direct swap and there is some homework you'll need to do but anything is possible if you have the time and money.
Posted on: 2010/6/14 21:15
