273 user(s) are online (213 user(s) are browsing Forums)
Does it work?
sliding Big cams vs vacuum
Zagreb, Croatia
326 Posts
I'd like to see or hear how much vacuum are your engines with
bigger than stock cams making at idle?!
Posted on: 2010/7/15 10:20
Matatk Re: Big cams vs vacuum
Is this just out of curiosity or are you concerned with braking, etc? I don't have a vacuum gauge, but I'll have to get a video of my motor running later. I have something like a 224/232 cam and it has a nice lope, good braking, no issues at 800 rpm idle.
Posted on: 2010/7/15 11:35
Trae1976 Re: Big cams vs vacuum
Johnson City, TN
832 Posts
Mine's pulling 11-12in with a Comp 270H. I believe the stock system in mine was about 18in.
12-211-2 - Comp Cams 'Magnum' Hydraulic Flat Tappet Camshafts Details
Operating Range: 1800-5800 RPM
Duration Advertised: 270° Intake / 270° Exhaust
Duration @ .050'' Lift: 224° Intake / 224° Exhaust
Valve Lift w/1.5 Rockers: .470'' Intake / .470'' Exhaust
Lobe Separation Angle: 110°
Posted on: 2010/7/15 11:47
sliding Re: Big cams vs vacuum
Zagreb, Croatia
326 Posts
I'm just curious, for comparison purpose. I'm still
having idle issues and I'm not sure if vacuum is as
should be, or is too low.
MAP readings (Datamaster or some other logger) at idle
(it doesn't have to be vacuum gauge) is what I'm interested in.
Posted on: 2010/7/15 11:49
Zagreb, Croatia
326 Posts
Thanks! What is your idle set at?
Posted on: 2010/7/15 11:50
Johnson City, TN
832 Posts
About 700.
Posted on: 2010/7/15 12:02
flyboy Re: Big cams vs vacuum
15"@ idle, 700rpm, 19"@1500rpm.
LT4 "Hotcam", 218/228@.050,.492/.525w 1.5X1.6 rockers.
LSA 112*, 6*timing, stock was 19" vac. @ idle.
Posted on: 2010/7/15 12:13
Weavsvet Re: Big cams vs vacuum
446 Posts
12" @ idle, 900 rpm
226/230.565.565/111lsa
Lobe Lift .3533 .3533
duration @ .006 280 284
Posted on: 2010/7/16 6:57
Zagreb, Croatia
326 Posts
Please let me know if my math is correct!
Let's take Weavsvets cam for example.
He's making 12" (it's inHg, right?) at idle.
If we convert that to kPa, that makes ~40 kPa.
So if we take 40kPa off of ~101kPa(atmospheric pressure),
does it mean that his MAP reading at idle should be
arround 61kPa?
Also, does compression have effect on vacuum?
Posted on: 2010/7/16 10:19
pr0zac Re: Big cams vs vacuum
i don't know what its vac reading is at idle. its around 800 rpm and my cam is a 245/253 @ .050 .612/.612 on a 107lsa, 300/308 @.006 and my brakes work fine.
Posted on: 2010/7/16 15:34
Zagreb, Croatia
326 Posts
What CID engine do you have? Stroker?
That cam is way bigger than mine and I'm getting comments that my cam is too big.
Posted on: 2010/7/16 18:42
biggrizzly Re: Big cams vs vacuum
OK here some more specs for you.
My cam card is shown below: This is an emissions legal cam profile designed by Brett Bauer to run with my LE2 heads and pass Maryland emissions so its not too big but supposed to develop better torque and power than the GM Hot Cam.
Based on one of my early scans that I can open and look at today it shows my MAP KPa jumping between 50.0-55.7 at idle around 800 rpm.
At high RPM between 5400-5600 RPM it was registering between 11.8 and 14 Kpa
Cam Specs
Posted on: 2010/7/16 20:00
Posted on: 2010/7/16 20:43
iCorvette Re: Big cams vs vacuum
302 Posts
13.5 inches 850 idle, still lousy brakes
Posted on: 2010/7/16 21:07
you have something wrong with your brakes then. i ran that cam for years and never had a brake issue.
Posted on: 2010/7/17 4:24
Aboatguy Re: Big cams vs vacuum
My Avatar was redistributed!
498 Posts
arround 61kPa?
From checking my datalogs/vs my vacuum gauge your are correct manifold vacuum will reflect in the differential between MAP and BARO at idle. Baro-MAP = manifold vacuum
Posted on: 2010/7/17 14:15
Zagreb, Croatia
326 Posts
Thanks!
Thank you all guys!
Posted on: 2010/7/17 15:28
446 Posts
Sliding
Just so you know I have plenty of brakes at 12" of vacuum. Hope you get it squared away.
EDIT: urns out I had a intake leak. I believe it was the grommet for the PCV. I fixed that and my vacuum went to 14".
Posted on: 2010/7/17 20:15
dan0617 Re: Big cams vs vacuum
12" of vac at idle, 230/236 cam on a 110 lsa. Only time brakes don't work right is when the vac booster is toast. My car is a MAF car so I don't have any MAP info for you.
Posted on: 2010/7/17 20:23
when you going to step up to a HR cam? i wanna see what you can make that car run....
Posted on: 2010/7/18 0:07
302 Posts
new booster 5k miles ago, does not hiss....
Posted on: 2010/7/18 3:19
Josh Re: Big cams vs vacuum
230 / 236, .57X/.57X, 113 LSA. It's a comp cams 280 XFI cam. No problems, 750-800 idle.
45-50 KPA at idle, measured with Data Master. Car is an M6.
A tuner I know and respect thinks that you could go 240/250 or more and still make it work. If mine ever comes apart again, that's the route I'm going. Probably something in the upper 240's and upper 250's.
Don't worry about the guys saying your cam is too big, that's the Corvette mentality it seems like. 99% of those guys haven't ever done a cam swap. They're just regurgitating what they've read on the net.
Posted on: 2010/7/18 4:36
tpi421vett Re: Big cams vs vacuum
Salt Lake City Utah
125 Posts
I have 11" of vacuum with a 252/260SR and the brakes work great. But it is a 450ci engine.
Posted on: 2010/7/19 3:06
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
