220 user(s) are online (182 user(s) are browsing Forums)
Driver Information Center.
zoe6 Oil color question
Northern Indiana
167 Posts
Just checked the oil in the ZO6 no oil burning but oil is black. Dad changed oil from Amzoil to Mobil1 extended life. I'm sure the detergents are dispursing the Amsoil built up. However its a little troubling to see it. Do you think I should change oil again. I have about 1100 miles on last change. Just bought 3 jugs of Mobil 1 @ WalMart! scary place! Dad has always used Wix oil filters and K&N. Are Frams any good? I know I'm asking a lot of questions!! Thanks Erin
Posted on: 2010/9/6 23:46
Owner of a great Vette! Totally stock ZO6
TommyT-Bone Re: Oil color question
You ask a legitimate question. They have gone as far as to cut filters in half to show filter construction. I don't believe that Fram has earned favored filter status.
Posted on: 2010/9/7 0:50
Posted on: 2010/9/7 0:51
zoe6 Re: Oil color question
Northern Indiana
167 Posts
I remember the oil filter post! Regarding the oil color, I think I will run it another thousand miles and if it is cleaning the Amsoil deposits out it will just clean that much more! Does that sound right!! Erin
Posted on: 2010/9/7 0:54
I don't put a lot of miles on my cars. I mainly change them because of aged oil. It's only an oil change. If it makes you feel better, do it. I'd rather do too many changes than too few.
Posted on: 2010/9/7 0:58
Northern Indiana
167 Posts
I didn't think it faired very well or vetron would have those in his shop. Ya get what you pay for!
Posted on: 2010/9/7 0:59
Northern Indiana
167 Posts
Excellent advice!
Posted on: 2010/9/7 1:00
CentralCoaster Re: Oil color question
The more expensive Frams are fine.
If you don't know the difference, at least look at the rubber drainback valve inside the filter, if it's orange, that's silicone rubber and generally means the rest of the filter is going to be superior as well.
I would stay far far away from the orange Frams or anything from AC delco at least.
Posted on: 2010/9/7 1:02
1Fast04Vert Re: Oil color question
Erin, I have a lot more miles on mine than you do on Zoe and it is all original and neither burns nor uses any oil between changes. Guess I would be considered unorthodox in that I use 4 qts of Mobile One 5W30 and 1 quart of Lucas Oil Stabilizer at every change. I run Mobile One filters as well, based upon some past research I believe they are worth the money.
Posted on: 2010/9/7 2:11
BillH Re: Oil color question
Stay with Wix, K&N and Mobil 1 filters.
I wouldn't worry at all about the color right now and I'd run it for another 3k at least. Normal change at 5-6k.
I would go to the regular Mobil 1 synthetic. I'm not a fan of the extended life and won't use it again.
If you're storing the car this winter, change the oil before you put it away.
Posted on: 2010/9/7 18:21
Vetron87 Re: Oil color question
Granger, Indiana
1988 Posts
Andy I put Lucas oil stablizer in it.
Bill your right about extended life, will use reg Mobil 1 from now on.
She was getting hyper last night about her oil being so dark. We will change it in the late fall when we put it up for the winter. She is driving it to Minn/St.Paul this weekend to see a couple of Purdue buds.
Her boy friend was complaining of wipelash when they came here after their driving outting. She was probably racing somebody!
Posted on: 2010/9/7 21:45
Bone stock 87 conv.
Glad to hear I am not the only one that believes in Lucas. I mentioned it on CF once and 'the crowd went wild' critizing the hell out of it and me for using it. Bunch of real idiots over there. (Still some good guys too, but lots of idiots)
Posted on: 2010/9/7 22:50
Granger, Indiana
1988 Posts
So CF is Corvette Forum right, I dropped by there once! wow
as study should be done on egos! I'm sure there are other forums but I don't have the time or patience. IE how fast did you go before you hit the brick wall.
I have used Lucas for a long time before that it was Hyperlube. I have a lot of Hot Rod buddies that use Lucas.
Posted on: 2010/9/7 23:03
Bone stock 87 conv.
I think Lucas (and Amsoil for that matter) make very good products.
That being said, I don't use them.
I put 250k on a SBC before it started to smoke a bit running Quaker State dyno & 4.5k changes.
Now I run one oil, M1 in the C4, Silverado @135k mi. (uses zero oil), the racecar with flat tapper (500 mi. changes) and even the snowblower.
The flat tappets show zero wear,BTW.
Posted on: 2010/9/7 23:25
Granger, Indiana
1988 Posts
Hi Bill I started my garage cleaning, than Erin came by, a couple of neighbors dropped by and now I'm doing this. Needless to sat I didn't get much done.
Posted on: 2010/9/7 23:30
Bone stock 87 conv.
Ha, it can't be anything like mine. I spent the day muttering "You're insane".
I'm up to 3 pickup loads to the dump. And I'm only 1/2 done.
Posted on: 2010/9/7 23:36
Granger, Indiana
1988 Posts
My wife keeps telling me I should be on a hoarding show! I have triples of everything. "Why do you need a computer in the garage and are those torch thingee tanks dangerous"
Posted on: 2010/9/7 23:41
Bone stock 87 conv.
Granger, Indiana
1988 Posts
I usually mutter to myself Ron you dumbass WTF is wrong with you with all this stuff! uh..look a Milwaukee 1/2 drill still in the box!! Lifes good again.
Posted on: 2010/9/8 0:37
Bone stock 87 conv.
I was just thinking about that today, what would I tell the firefighters if I had a house fire?
"Got anything flammable in that garage,sir?"
"Well, gee, not too much"
"Let's see, I got:
5 gal. urethane car paint plus reducer and activator.
couple quarts of lacquer
2 gal lacquer thinner
a gal of acetone
a gal of mineral oil
a gal of WD40 plus 2 spray cans
5 cans of brakeclean
a gal of carb cleaner
5 cans carb cleaner
5 gal of 110 octane gasoline
2 gal of regular gasoline
full size oxy/acc tanks
7 gal of industrial automotive parts solvent.
a propane tank, cylinders and mapp gas cylinders"
"You guys bring any marshmallows wid Ya?"
Posted on: 2010/9/8 0:58
Granger, Indiana
1988 Posts
I would tell the firefighter to run.
Two full Ace/tanks and two 02 tanks
6 mapp gas tanks
10 propane tanks
2 large 40lb. propane tanks for heater
55 gal waste oil drum full.
1 gal of lac thinner.
10 gals of gas for Toro mower.
1 1961 Impala SS hub cap.
Oh and gun powder for my reloading.
Please note gun powder is stored in a fireproof locker.
BOOM!
This is the home garage.
Posted on: 2010/9/8 1:08
Bone stock 87 conv.
Granger, Indiana
1988 Posts
Holy shit hope my wife never reads this! she has enough problems with the car thing. Did I ever tell you guys she wanted to be a Nun! Do I automatically go to hell for that!
Posted on: 2010/9/8 1:11
Bone stock 87 conv.
Matatk Re: Oil color question
To get back on topic, it's normal in a higher mileage engine for the oil to turn black somewhat quickly. Being black is not a sign the oil is worn out.
http://www.oilsandlube.com/oil-color.htm
Posted on: 2010/9/8 2:16
Catbert Re: Oil color question
Tobacco Road
1 Posts
Mobil 1 Extended has very high concentrations of several cleaners and probably there is likely a lot of crud in solution. I'd dump it now...cheap insurance. I wouldn't use an orange filter.
Posted on: 2011/1/19 23:23
Don't think Meat, throw the ball - Crash Davis
