244 user(s) are online (179 user(s) are browsing Forums)
383tpimachine Trans cooler?
Corpus Christi
976 Posts
With an auto I know my trans temps are climbing during autox and I will need one when I begin to roadrace.
I was wondering if it was possible to put a trans cooler where the battery is on the passenger side? Then a small pusher fan to pull air in through the gills.
1985 vette. I will get a trans temp gauge to verify the decrease in temp if possible.
Would a deeper pan also help?
Posted on: 2010/9/21 17:13
1970 El Camino-Awaiting LSX
ggrassmid Re: Trans cooler?
Edgewood, KY
18 Posts
deeper pan I dont think will work; check out this...
http://www.yourcovers.com/transpan_9297.php
They claim lower temps cause the fins on the pan
Also, what's wrong with putting a trans cooler in front of radiator?
Posted on: 2010/9/21 18:01
flyboy Re: Trans cooler?
Don't know about the location, but I have read that for whatever reason, the cooler in the radiator should be bypassed when using an auxiliary cooler. Is that your plan?
Posted on: 2010/9/21 18:30
383tpimachine Re: Trans cooler?
Corpus Christi
976 Posts
Yes I was going to bypass since my car will always get to operating temperature in south texas.
The location was just something different. I would rather keep as much air flowing through the rad and condenser as possible but yes it is the 2nd option.
Posted on: 2010/9/21 19:01
Vetron87 Re: Trans cooler?
Granger, Indiana
1988 Posts
I added a trans cooler with its own fan in front of the radiator( only logical place). The cooling fan kicks on above @ 180. I have a AutoMeter 2 1/16 dia. gauge face trans temp. Used high pressure Gates transmission hose and HP clamps. I have a tee placed in line of the return line to the trans. The sensor threads into the tee with a ground wire running from tee to ground, works great. On a hot 98 degree day in traffic never gets above 185, and didn't create a cooling problem for the engine. Hose lines run above fan shroud and are ziptied to the shroud housing.Trans cooler was a B&M with fan.
Posted on: 2010/9/21 22:52
Bone stock 87 conv.
vetteoz Re: Trans cooler?
If you have a fan can mount cooler anywhere as you are not reliant on air flow.
Some have mounted cooler horizontal at rear behind diff
Deeper pan on C4 may have ground clearance problems; more so if car lowered
Posted on: 2010/9/21 22:53
Granger, Indiana
1988 Posts
Neighbor mounted his behind the rear diff. It was fine until he ran over a road kill at night and blew out a AN line fitting. Trans didn't last long after that! Road kill hit the fitting just right even though they where protected.
Posted on: 2010/9/21 23:07
Bone stock 87 conv.
Corpus Christi
976 Posts
In front I have the aux fan besides the main spahl fan I have with the dewitts rad.
Would it fit between my late model condensor and the aux fan?
If so can I program the pusher fan to come on at a certain trans temp?
Posted on: 2010/9/22 0:31
Granger, Indiana
1988 Posts
My 87 doesn't have the Aux fan, had room in front of the radiator. One of my neighbors put a"Be Cool" cooler by his A/C evaporator and was aided by the cooling of the condenser lines.
Posted on: 2010/9/22 0:36
Bone stock 87 conv.
Matatk Re: Trans cooler?
22808 Posts
The front pusher fan is operated by a temperature switch in the d/s head. You can put in a lower temp switch from a camaro, or MAM makes a kit that turns it on at like 205 and off at like 185.
Posted on: 2010/9/22 1:18
22808 Posts
You have any pics of your setup? I'm still deciding how to set mine up once I get around to getting the pieces necessary.
The pusher fan does little except make a noise especially if you have a upgraded main fan with higher than stock cfm flow
I removed mine , mounted the trans cooler w/ fan in it's place and used the old pusher fan wiring / relay as a supply
I have one of these Spal switches on the cooler line to operate the cooler fan
http://cgi.ebay.com/ebaymotors/SPAL-1 ... uckQ5fPartsQ5fAccessories
Also available in 195F On/175F Off
Posted on: 2010/9/22 2:35
Corpus Christi
976 Posts
Thanks vetteoz. I will likely go this route.
What size should I go with?
looking for 450rwhp with a 2200 stall
Posted on: 2010/9/22 3:08
Jeffvette Re: Trans cooler?
Or you can just get rid of the pusher fan when you start running real coolers.
Posted on: 2010/9/22 20:46
mrbillybob Re: Trans cooler?
5 Posts
Derale makes a deep pan with coolng tubes for less than $100 at Star Performance. B&M make tranmission coolers for about same price,rated at 29,200 BTU,11"*11"*1 1/2 "with NPT fittings
Posted on: 2010/10/15 4:19
