241 user(s) are online (190 user(s) are browsing Forums)
Ultraman, more...
biggrizzly Suspension bushing replacement with engine out?
Is it easier or harder to remove and replace front suspension components with the engine and transmission out? Or does it not make any difference at all. I am considering doing an Energy Suspension Bushing overhaul while I'm waiting for motor and transmission to be done. I was just wondering if the weight of the engine has any affect when doing these changes. I didn't know if the spring tension would seem higher without the engine in place to put additional pressure on the spring. Maybe I'm brain-farting here, but just thinking out loud.
Posted on: 2010/11/15 14:03
tjpreul Re: Suspension bushing replacement with engine out?
The front spring is very stout. If you have the proper spring tool it won't make any difference. I used the weight of the engine to do mine, so I don't know they would compress without the engine in.
Posted on: 2010/11/15 14:32
BillH Re: Suspension bushing replacement with engine out?
I'll bet a dollar that with the engine out, you'll just jack the car off the ground.
I've done springs using a chain around the jack, but it's a bit dicey.
Posted on: 2010/11/15 14:39
biggrizzly Re: Suspension bushing replacement with engine out?
I was afraid of that! How do you tell if you need new bushings if they appear ok. They might be hard as rocks. Is that ok? Factory bushings in a car with 157k miles. They got to be getting bad.
Posted on: 2010/11/15 14:48
"They got to be getting bad", yea, pretty much especially if you're going to autox.
You can do the normal checks, jack one tire off the ground, grasp the tire at 9 & 3 to check tierods/steering, at 12 & 6 to check bushings. You'll need someone to help.
With the tire a coulpe of inches off the ground, put a crowbar/2x4 under it and lift up, look for movement in the a-arms and especially the ball joints (how old are they?).
Posted on: 2010/11/15 15:08
bogus Re: Suspension bushing replacement with engine out?
You know, at 157k, if you have replaced none of those parts, I would consider doing a full front end refresh.
New ball joints, new bushings, new rack, new tierod ends, new PS hoses... Just do it and it will be done. It's not an expensive fix, just time consuming.
As for the rear, I always will recommend the Banski kit. That thing has redefined the feel of my 92. Love it.
Posted on: 2010/11/15 17:11
iCorvette Re: Suspension bushing replacement with engine out?
302 Posts
I know you endorse Banski, and they are a sponsor, however along those lines, any comparable "system" work yield the same results Da ele net?
they are not the only game in town, they just made it better, and these struts have been around since the dawn of man?
Posted on: 2010/11/16 6:04
CentralCoaster Re: Suspension bushing replacement with engine out?
Yeah, there's other rod end kits out there. The unique part of the banskis is you don't need a huge fucking crescent wrench to mess with jam nuts for adjusting them. Those are hard to fish in there without pulling the wheel.
Honestly though I don't adjust my suspension anyways. But hey, I can with just a 1/4" box wrench.
Posted on: 2010/11/16 8:00
302 Posts
jumping into harbor fright, I notice alot of "innovative, looking" tools, sears tend to be cutting edge with their tool engineering, but while at the harbor fright, perhaps they have a big wrench for the job with the right angles as to not remove tire.
another thing I noticed with VBP is they have Zerk fittings, this alone can flush out water and rust and maintain the ends better than without.
Posted on: 2010/11/16 19:11
rayquayle Re: Suspension bushing replacement with engine out?
139 Posts
Don, That's what I'm doing:
Posted on: 2010/11/16 22:38
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
1Fast04Vert Re: Suspension bushing replacement with engine out?
Don, even if you leave it alone you should pull out the lower rear A arm bolts and turn them around. From the factory the bolts are in so that you have to pull the motor mount brace to get them out. Now is the time to pull the brace, take the bolts out and then re-insert them from the front. That way if you ever have to do it later it is a whole lot easier.
Posted on: 2010/11/16 22:42
astock165 Re: Suspension bushing replacement with engine out?
Manchester NH
199 Posts
True, an un-lined rod end with a zerk fitting is better than an un-lined rod end without a zerk fitting.
However, the rod ends we use are Teflon lined and have been quite robust. Adding a rod end boot (like the ones from Seals It) will make them zero maintenance for some time.
Posted on: 2010/11/17 3:02
Banski MotorSports LLC
Manchester NH
tom@banskimotorsports.com
www.banskimotorsports.com
Yep.
That what we use on racecars (without the Seals It) and they still last a very long time.
Posted on: 2010/11/17 3:07
I must be the exception then. I'll be picking up a pair of those boots to hold some grease in there.
Posted on: 2010/11/17 6:29
302 Posts
the race track is alot cleaner than the street, and why don't you throw them in your kits and label it complete or at least offer them on your site will set you apart even further from the pack, this way, a buyer not doing full due diligence NOW can be duly notified what the optimum preventive maintenance, configuration will be and not regret have not done it right in the first place.
This would be a serious mind F***, to discover seal-it after the fact, for all those anal retentive Vette owners, such as myself.
Posted on: 2010/11/17 9:36
Manchester NH
199 Posts
In the past I've never found them necessary but my car is a track only car so I can certainly see how some people might want to use them.
That's actually not a bad idea. I'm going to work on that.
Posted on: 2010/11/17 23:52
Manchester NH
Manchester NH
199 Posts
I'm happy to announce that we are now an authorized distributor of the entire Seals-It product line!
This means that we are now offering our C4 rear suspension kits with the rod end boots you'll need for added protection and near zero maintenance.
In addition, we are offering boot only kits for those of you have already purchased our suspension kit(s) and might want to add them.
We'll be integrating the entire Seals-It product line into our online store in the coming weeks and months.
Posted on: 2010/11/28 0:53
Manchester NH
I will be in touch!!!!
Posted on: 2010/11/28 3:15
139 Posts
Me too! I'll be in touch, Tom.
Posted on: 2010/11/28 17:26
NCM Founder #2896
NCM Lifetime #672
I don't praise Banksi because of their status. First off, they are not a sponsor, they are a Registered Vendor. RV status simply allows a vendor to share their wares without being accused of being a spammer! And it's free.
I come to my feelings about the Banski kit by actual use. I did a story on the install in Corvette Enthusiast recently, and have been driving on the Banski kit for 14 months now. It has been absolutely reliable and durable. I have put about 3000 miles on the kit, but the roads around here really do suck.
If you have the CE article, I would read that... you will get the entire reasoning behind it and the install process.
Posted on: 2010/11/28 18:36
139 Posts
Great article too Andy! I get it in hard copy, but in case any of you don't it is available on line here.
Posted on: 2010/11/28 20:03
NCM Founder #2896
NCM Lifetime #672
Oh, cool, it's still online!
Thanks Ray!
Posted on: 2010/11/28 20:14
302 Posts
wow.... you made the phone call, nothing like a symbiotic relationship, I feel you are a good company.
Posted on: 2010/12/6 6:09
Z51L9889 Re: Suspension bushing replacement with engine out?
Dayton, OH
18 Posts
I read on one of the other forums some time ago about how someone figured out how to compress the front spring with the engine out of the car. He took a flat plate and drilled it to match the hole pattern for the lower shock mount. He then took a long piece of threaded rod and bent one end of it so that the bend angle matched the angle between the front shock body and the lower mount. He welded the bent piece to the flat plate, stuck the rod through the hole in the shock tower, and bolted the plate to the lower control arm. He then simply ran a nut down against the shock tower and pulled the control arm up to the right position to reconnect the knuckle.
Hope this helps ....
Posted on: 2011/1/3 21:58
