biggrizzly | Re-Installing Knock Sensors on an LT1 | ||
I'm getting ready to re-install my knock sensors in the morning. They were new last engine build. (5K miles or so). They have some of the original orange/red thread sealer on them. Are you sure its ok to install them without additional thread sealer? I have read where no additional thread sealer is needed. I just want to double check.
Posted on: 2011/4/9 3:11
pianoguy | Re: Re-Installing Knock Sensors on an LT1 | ||
I've had mine out a few times and have never added any thread sealer, just whatever was on there.
Posted on: 2011/4/9 3:24
bogus | Re: Re-Installing Knock Sensors on an LT1 | ||
it's not sealer... it's anti-seize.
More isn't gonna hurt. |
Posted on: 2011/4/9 3:29
biggrizzly | Re: Re-Installing Knock Sensors on an LT1 | ||
Cool! Thanks guys.
Posted on: 2011/4/9 3:42
BillH | Re: Re-Installing Knock Sensors on an LT1 | ||
I've had mine out twice and didn't add anything.
But, I did use a torque wrench. |
Posted on: 2011/4/9 12:23
95Vert | Re: Re-Installing Knock Sensors on an LT1 | ||
Oh, the flashbacks to my adventure with a stuck knocksensor stud in the block. Extremely painful if you guys remember! Finally had to take it to the local garage on the lift to have it taken out.
Antiseize...really? I thought it was thread sealer as well. I should use the antiseize and then torque to spec? |
Posted on: 2011/4/13 13:32
I'll have to respectfully disagree with Andy. I think it's sealer. And these are pipe threads so, be careful torquing them. Plus using antisieze would require a 30 to 50% reduction in the torque spec. |
Posted on: 2011/4/13 13:51
Aardwolf | Re: Re-Installing Knock Sensors on an LT1 | ||
The knock sensor is one of several that do not get sealant. If needed use a little toward the very base of the sensor so the beginning threads are uncoated and can make a good ground.
Posted on: 2011/4/13 14:28
ittlfly | Re: Re-Installing Knock Sensors on an LT1 | ||
Pay special to the torque spec. As I *recall*, it can be the cause of other problems.
Posted on: 2011/4/13 23:51
PLRX | Re: Re-Installing Knock Sensors on an LT1 | ||
The ones on my 95 are stuck, I was on a hurry because I had a run to Lone Pine so I left it alone and just added new Dexcool and water. One of these days I'll need to use a pipe wrench to get them out. One of these days... The knock sensors use sealant and torqued. |
Posted on: 2011/4/14 19:09
[IMG]http://i119.photobucket.com/albums/o130/Aardwolfki/Electrical/KS.jpg[/IMG] |
Posted on: 2011/4/14 22:41
I use a socket and 1/2 in. breaker bar to loosen the first 1/8th turn with a lot of pressure on the socket with my left hand. When you do it, stick a hose nozzle in the hole and blast it, you'll be amazed at the crap that comes out. Mine have been out twice reusing the factory sealant, torqued, no leaks. |
Posted on: 2011/4/15 1:14
14ft.lbs is, like nothing. I did 14 but could not resist to give it a pinch more.
It's pipe thread, 14 & a pinch will do. |
Posted on: 2011/4/15 1:18
Matatk | Re: Re-Installing Knock Sensors on an LT1 | ||
I've heard of guys using a little teflon tape or sealant to reduce the sensitivity of the KS, but that's bubbafied. |
Posted on: 2011/4/15 2:30
