140 user(s) are online (97 user(s) are browsing Forums)
Driver Information Center.
84bluec4 16" tire question..will it fit?
Grass Lake, Michigan 49240
65 Posts
I have been pricing tires for a while, and as we are all aware, the 16 inch 255 50 has a limited amount of choices. I have heard of people running a 245 50 16 tire, but has anyone mounted 265 50 16's on their vette? Any Rubbing? Any Issues?
Posted on: 2008/1/25 20:38
CentralCoaster RE:16" tire question..will it fit?
That depends.
Do you have 16x9.5s or 16x8.5s? Z51s came with 9.5s, except 84s that only had 9.5s in rear.
Check tirerack.com for recommended fitment.
9.5" is usually good up to 275s
8.5" is usually good up to 255s.
I've had 275s on a 8.5" and it was a stretch, that was a 17" wheel though. 16s won't be as bad. I'd say a 265 will work fine for you.
Posted on: 2008/1/25 21:25
84bluec4 RE:16" tire question..will it fit?
65 Posts
I am currently have the 8.5 and 9.5 wheels (z51 pkg) and I also have a additional set of 8.5's (just incase I wanted to rotate tires)
I just don't know how much room I have to play with by going 265 but staying in the 50 series profile.
I know on some other vehicles I have had it was no problem going one size bigger but those tires were not as wide.
Thanx
Posted on: 2008/1/25 22:49
M Moore
1984 Lt blue/Med blue, z51, automatic, 3.07
350 crossfire
blue cloth interior, Bose stereo,
everything still stock (for now)
Notorious RE:16" tire question..will it fit?
265 shouldn't be a problem on an 8 1/2" wheel. As far as rubbing, I wouldn't worry. I've got a friend who runs 335/30/17s on the front of an '85 race car. They only rub at full lock. Not a problem on the track.
Posted on: 2008/1/25 23:13
Rubbing won't be a concern.
Posted on: 2008/1/25 23:19
CFI-EFI RE:16" tire question..will it fit?
Top of Utah
372 Posts
[quote]:withstupid]
That is only 5 silly little millimeters on each side of the tire. If you want to see something strange, I have some 245/50/16 tires mounted on 9.5" wheels.
RACE ON!!!
Posted on: 2008/1/25 23:48
65 Posts
Thanks everyone. I just couldn't figure out, if it was just the width, the height of the sidewall or both that changed.
Posted on: 2008/1/26 22:03
M Moore
350 crossfire
RollaMo-LT4 RE:16" tire question..will it fit?
Trivia Winner
Rolla, Missouri
422 Posts
NOTE: Different tire brands might be slightly different, but they all will be close.
No, actually, the overall diameters are VERY close to what the calculation puts em at. This is important since the tires need to replace oem stuff without screwing up speedo accuracy and traction control. The actual treadwidth can vary quite a bit though even for the same size.
Posted on: 2008/1/26 22:51
sprint7677 RE:16" tire question..will it fit?
Oxford, Pa
127 Posts
Tire Rack has the 255/50 r16 tires
72.00 up to 185.00
I'll let you know how the 72.00 ones work by next week.
Posted on: 2008/1/30 3:25
65 Posts
I just got the 265's, Now to get them mounted. They are BFG Radial's they are not Z rated but I don't care. $250 plus shipping delivered FedEx ground in just 2 days. :thumbleft:
Posted on: 2008/2/3 2:03
M Moore
350 crossfire
pappyfreebird RE:16" tire question..will it fit?
1028 Posts
sounds like a groovy price deliverd...
Posted on: 2008/2/3 2:20
