Browsing this Thread:
2 Anonymous Users
84bluec4 | 16" tire question..will it fit? | ||
I have been pricing tires for a while, and as we are all aware, the 16 inch 255 50 has a limited amount of choices. I have heard of people running a 245 50 16 tire, but has anyone mounted 265 50 16's on their vette? Any Rubbing? Any Issues?
Posted on: 2008/1/25 20:38
CentralCoaster | RE:16" tire question..will it fit? | ||
That depends.
Do you have 16x9.5s or 16x8.5s? Z51s came with 9.5s, except 84s that only had 9.5s in rear. Check tirerack.com for recommended fitment. 9.5" is usually good up to 275s 8.5" is usually good up to 255s. I've had 275s on a 8.5" and it was a stretch, that was a 17" wheel though. 16s won't be as bad. I'd say a 265 will work fine for you. |
Posted on: 2008/1/25 21:25
84bluec4 | RE:16" tire question..will it fit? | ||
I am currently have the 8.5 and 9.5 wheels (z51 pkg) and I also have a additional set of 8.5's (just incase I wanted to rotate tires)
I just don't know how much room I have to play with by going 265 but staying in the 50 series profile. I know on some other vehicles I have had it was no problem going one size bigger but those tires were not as wide. Thanx |
Posted on: 2008/1/25 22:49
M Moore 1984 Lt blue/Med blue, z51, automatic, 3.07 350 crossfire blue cloth interior, Bose stereo, everything still stock (for now) |
Notorious | RE:16" tire question..will it fit? | ||
265 shouldn't be a problem on an 8 1/2" wheel. As far as rubbing, I wouldn't worry. I've got a friend who runs 335/30/17s on the front of an '85 race car. They only rub at full lock. Not a problem on the track.
Posted on: 2008/1/25 23:13
Rubbing won't be a concern.
Posted on: 2008/1/25 23:19
CFI-EFI | RE:16" tire question..will it fit? | ||
[quote]:withstupid]
That is only 5 silly little millimeters on each side of the tire. If you want to see something strange, I have some 245/50/16 tires mounted on 9.5" wheels. RACE ON!!! |
Posted on: 2008/1/25 23:48
Thanks everyone. I just couldn't figure out, if it was just the width, the height of the sidewall or both that changed.
Posted on: 2008/1/26 22:03
RollaMo-LT4 | RE:16" tire question..will it fit? | ||
Trivia Winner
NOTE: Different tire brands might be slightly different, but they all will be close. No, actually, the overall diameters are VERY close to what the calculation puts em at. This is important since the tires need to replace oem stuff without screwing up speedo accuracy and traction control. The actual treadwidth can vary quite a bit though even for the same size. |
Posted on: 2008/1/26 22:51
sprint7677 | RE:16" tire question..will it fit? | ||
Tire Rack has the 255/50 r16 tires
72.00 up to 185.00 I'll let you know how the 72.00 ones work by next week. |
Posted on: 2008/1/30 3:25
I just got the 265's, Now to get them mounted. They are BFG Radial's they are not Z rated but I don't care. $250 plus shipping delivered FedEx ground in just 2 days. :thumbleft:
Posted on: 2008/2/3 2:03
pappyfreebird | RE:16" tire question..will it fit? | ||
sounds like a groovy price deliverd...
Posted on: 2008/2/3 2:20
