276 user(s) are online (206 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
jsup Hey Bugus, you stink.....
1778 Posts
Remember in one thread you said "the AC bracket will crack"? Well, you were right!!!!! You jinxed me!!!!
Anyway, I'm just giving Andy a hard time....
Anyone know where I can get an AC Bracket for a 1990 L98?
I'm this> < close to getting this done. Would have been finished today if not for this......
Can anyone help me out?
Now I'm like this with myself....
Posted on: 2008/2/3 18:15
red_johnny RE:Hey Bugus, you stink.....
Man that sucks. Sorry to hear about that. No clue where you could get one quick. Ebay comes to mind for some used stuff.
Posted on: 2008/2/3 18:35
MK 82 RE:Hey Bugus, you stink.....
Palm Beach Gardens, FL
439 Posts
I have a pair of EM coated headers for my LT4. The folks at Exotic Muscle said that I would have to eliminate the AC brace. They claim it will be OK. I haven't installed them yet but will fabricate something to replace the brace.
Posted on: 2008/2/3 18:45
96 CE Roadster LT4
94z07 RE:Hey Bugus, you stink.....
94 Posts
Email Jason at parts@vette2vette.net
Posted on: 2008/2/3 18:47
Business makes progress. Fortune passes everywhere.
jsup RE:Hey Bugus, you stink.....
1778 Posts
Done.
Anywhere else I should look? I understand these things are discontinued.
Posted on: 2008/2/3 18:49
1778 Posts
Works fine with the L98. I was tightening the screws on the Water pump when this ugly snapping noise happened.
I have taken to using a 1/4 inch drive ratchet as to avoid over tightening certain things. Couldn't do that on this....
Posted on: 2008/2/3 18:51
bogus RE:Hey Bugus, you stink.....
Damn, John, that sucks... That bracket doesn't like being tweeked one bit, as you learned.
I agree, www.vette2vette.com is a great start.
IF the 1990 bracket is aluminum, you can get it welded... but I suspect it's pig metal. Pig metal isn't very strong, it's strength is totally engineered into the shape and structure, so if you load it against the expected design parameters, snap it goes.
DropTop - the 1990 AC bracket is totally different than the 1992+ bracket. First off, I know ours is cast aluminum. Secondly, the 1990 put the accessories on both sides of the engine, the AC is on the passengers side, whereas the alternator is on the drivers. The 1992+ design as all the belt driven accessories on the drivers side.
Posted on: 2008/2/3 19:29
1778 Posts
You know what really sucks? That I had that dam thing off four or five times for mock up. No problems.
This was the last time I'd have to deal with the dam thing and SNAP.
Posted on: 2008/2/3 20:48
BlkCpe RE:Hey Bugus, you stink.....
Georgia
23 Posts
Good advice ,mine broke also ,had it welded up,the guy that I had do it said it was ''pot metal'' aka shit, it held untill I found a used one.I wouldn't trust very long thou.
Posted on: 2008/2/3 23:16
for future reference, they sometimes require washers on the head and or block points to make sure the bracket stays level.
Posted on: 2008/2/4 0:04
1778 Posts
I put some washers in since I didn't like how it sat. The issue was it wasn't sitting flat. Rather than disconnect the thing and figure it out, I chose to put a little force behind it and let the nuts pull it down. bad idea.
In my haste, I just realized, I left out the bracket which attaches to the AC bracket. forcing the nut on the water pump too far down. If the bracket was in there it wouldn't have tightened that far, and probably wouldn't have broken.
I'm kicking myself...over and over and over.....dammit.
Posted on: 2008/2/4 0:14
fnsblum RE:Hey Bugus, you stink.....
Nothern Utah
32 Posts
Take it to a good welder for evaluation before trashing it. You just learned a lesson in the school of hard knocks. It takes many years to graduate. Later! Frank
Posted on: 2008/2/4 4:54
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
Qack RE:Hey Bugus, you stink.....
274 Posts
Never heard of anyone actually graduating ... Guess I must hang around with the wrong croud; they all have the last name -- Murphy.
Posted on: 2008/2/4 5:30
Graduating? Geez... I must have 843 credits towards graduation... the problem is that the required number of credits is always one more than you have.
I donno about welding the stuff... Pig metal doesn't weld well... Then come the reality - that bracket sits pretty close to the block, if there is a raise due to the weld bead, I am afraid it would throw everything off.
I wonder... would it be practical to get some made from cast aluminum? I bet you could make a living off of that.
Posted on: 2008/2/4 5:58
1778 Posts
I'll be taking advance orders for AL ones tomorrow......
I think it would be pretty expensive.
I'd rather replace than weld it. I have too much time and money into this at this point to depend on a welded joint.
Posted on: 2008/2/4 13:49
1778 Posts
Vette2Vette had one. Ordered it today. Maybe I can finish this up this week. At least I'll have it done for spring...
Posted on: 2008/2/4 16:33
274 Posts
Wow. You REALLY like to tempt fate.
Posted on: 2008/2/4 16:36
1778 Posts
You're right..........I should learn when to STFU...
Posted on: 2008/2/4 16:58
smooth RE:Hey Bugus, you stink.....
Formerly "Aquavet" in Pa.
386 Posts
For future reference heres another place for parts in Bristol Pa. Contempory Corvette
They have a yard full!
www.contemporarycorvette.com/about.html
Posted on: 2008/2/4 20:01
Alan
2001 Navy Blue Metallic
439 Posts
I have dealt with them several times with good results!!
Posted on: 2008/2/5 2:02
96 CE Roadster LT4
CasetheCorvetteman RE:Hey Bugus, you stink.....
Yes, do that, dont go without the brace. Make sure whatever you put in its place will be at least equal or better than stock.
Look in my sig below, go to my mate's website, get his number, call him sometime after 9am weekdays Colorado time, and tell him what you need.
Posted on: 2008/2/6 8:23
