319 user(s) are online (275 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
cli59vette Help!!! Upper Control Arm Geometry
16 Posts
Hello all,
I am new to the forum/site and hope i am posting this in the correct area.
I have a C1 corvette that I want to modify and graft in the suspension from a 1990 C4. I was wondering if I could get two questions answered here.
1) What is the degree angle from front to back of the upper control arm where it bolts to the cradle. I was told 15 degress but would like that confirmed.
2) What is the angle of the bracket that holds the two dog bones in place (on the frame) at the rear suspension.
Remember the refernce angle should be that the ground is level.
I'll be making up a cad profile and will share for all to see when I'm done. hopefully it'll be helpfull to all who want to upgrade and update their rides.
Thank you for the help.
Posted on: 2011/12/6 18:47
Durango_Boy Re: Help!!! Upper Control Arm Geometry
Sounds like a very ambitious project. Make sure you document what you're doing, and I know a lot of us would appreciate a thread detailing your project car as a whole...kind of an introduction.
Welcome to the forum.
Posted on: 2011/12/6 20:20
Churchkey Re: Help!!! Upper Control Arm Geometry
69 Posts
So you want the front upper arm anti dive angle? Will check the 90 for you after dinner.
As far as the squat/anti squat instant center rear goes I believe DRM makes different front mounts for the dog bones & changes that angle for the better. I do not have DRM brackets so cannot help with that aspect. All I'm saying is that if your making brackets might as well make the ones that locate the components in a better place than stock.
Might try a search for roll center heights, changes etc.. I have seen some cad illustrations on the net but do not recall if the control arm / dog bone angles were specified.
Chow time.
Posted on: 2011/12/6 23:41
69 Posts
Lf upper = 14.3* down
Rf upper = 14.2* down
For a base line: also checked the chassis front/rear angle at the sill plates..
.2 degrees high in the rear.
Luck with your project.
Posted on: 2011/12/7 1:05
CentralCoaster Re: Help!!! Upper Control Arm Geometry
I think brian cunningham has some sketches that may show these angles and pivot points, he's a nerdy engineer and loves that stuff.
He's on here every now and then.
Posted on: 2011/12/7 1:44
tjpreul Re: Help!!! Upper Control Arm Geometry
I would also recommend looking at the Banski products. They reduce binding that occurs. The adjustment can also help with angles.
http://banskimotorsports.com/
Posted on: 2011/12/7 2:42
cli59vette Re: Help!!! Upper Control Arm Geometry
16 Posts
I'd be interested in seeing cunningham's sketches. Does any one know how to get a hold of him? I'm also a geeky engineer that enjoys doing this to lol.
Posted on: 2011/12/7 18:03
BrianCunningham Re: Help!!! Upper Control Arm Geometry
Here's all the files I have
http://s242.photobucket.com/albums/ff87/swiftwood/Corvette/hubs/
I actually made a CAD file
Photobucket
Posted on: 2011/12/8 1:16
Pot? Kettle calling
Posted on: 2011/12/8 1:17
16 Posts
Brian,
Thank you. I sent you a PM. Would you be willing to forward me the CAD dwgs. I use the program myself. It'll help with my build.
Posted on: 2011/12/8 18:36
I'll send it over
It's a big file, so I'll have to use YouSendIt.com
Posted on: 2011/12/9 22:45
vetteoz Re: Help!!! Upper Control Arm Geometry
cli59vette wrote:2) What is the angle of the bracket that holds the two dog bones in place (on the frame) at the rear suspension.
May be of some help
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/Diff/antisquat-1.jpg[/IMG]
Posted on: 2011/12/10 4:38
Churchkey wrote: I believe DRM makes different front mounts for the dog bones & changes that angle for the better.
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/Diff/DRM1.jpg[/IMG]
Posted on: 2011/12/10 4:40
vetteoz wrote:
[quote]
Same mounting angle to frame
Changes angle of the dog bones to each other.
"DRM brackets alter the trailing arm mounting point locations to promote better geometry. The additional weight transfer results in improved traction."
Posted on: 2011/12/10 4:43
16 Posts
Thanks Brian,
Haven't received it yet. Give me a heads up so I know to look out for it.
Posted on: 2011/12/11 19:44
16 Posts
Also, since this is a C4 forum, can any one tell me what the ride height, as in the bottom of the frame to the floor clearence is?
Thanks again for the info guys.
Posted on: 2011/12/11 19:46
file sent
Posted on: 2011/12/12 0:52
