295 user(s) are online (247 user(s) are browsing Forums)
jsup Chrome Plating
1778 Posts
Doing this build I went total utility. Tried to buy the best parts for the application. I put my money IN the motor, not on it.
Now, I'm thinking perhaps to get a couple pieces plated so I don't have to take it apart agian.
The AC compressor bracket, and the air pump eliminator bracket.
Does anyone know the price of doing this? Is plating expensive?
Thanks.
Posted on: 2008/2/6 0:28
CFI-EFI RE:Chrome Plating
Top of Utah
372 Posts
Isn't the A/C compressor bracket aluminum or pot metal? I have no clue as to what your smog pump eliminator bracket is made of. You can't chrome plate aluminum or pot metal. They can be anodized or painted/powder coated.
I am CFI-EFI, and I approve of this post.
RACE ON!!!
Posted on: 2008/2/6 1:57
jsup RE:Chrome Plating
1778 Posts
RACE ON!!!
I can powder coat it. Maybe I'll get it done shiny black..It is aluminum.
PC is cheap too. I think chrome plating is expensive.
Here's the bracket I purchased. It's aluminum...
.Resized Image
Maybe PC is the ticket.
Posted on: 2008/2/6 2:06
sprint7677 RE:Chrome Plating
Oxford, Pa
127 Posts
You can buff the Aluminum, the pot metal does not polish / buff well
Posted on: 2008/2/6 2:13
1984 Corvette mostly stock, many new parts
1778 Posts
I am fairly certain that the bracket is aluminum...I don't have the tools to polish AL. Is that expensive?
My wife is giving me crap about the money at this point...and I still have to get the exhaust done. She doesn't get putting $5k into a perfectly good car. Then there's the boat, and the other boat, so price is the issue for now.
Posted on: 2008/2/6 2:21
Alcee1 RE:Chrome Plating
Los Angeles
277 Posts
Go to a good chrome shop and you can get aluminum chromed, I already did it.
Posted on: 2008/2/6 2:58
1Fast04Vert RE:Chrome Plating
Otherwise there would be no chromed sawblades.
Posted on: 2008/2/6 3:03
MK 82 RE:Chrome Plating
Palm Beach Gardens, FL
439 Posts
Aluminum can be chromed.
96 CE Roadster LT4
Midnight85 RE:Chrome Plating
Streator, IL.
264 Posts
Aluminum CAN be chromed, I just had my fuel rails done, along with the base of the AFPR. I had other things done but these were the only aluminum parts.
Posted on: 2008/2/6 3:04
1778 Posts
What's the cost say relative to powder coating?
Posted on: 2008/2/6 3:07
439 Posts
As a wild ass guess I would say at least double the powder coating price due to the labor involved. You can get powdercoat that closely resembles chrome.
Posted on: 2008/2/6 3:27
96 CE Roadster LT4
1778 Posts
That's not too bad. Under $100. I can get it PCd for under $50 for both pieces.
Posted on: 2008/2/6 3:30
BillH RE:Chrome Plating
Good chrome plating is 3 to 4 times the cost of PC.
Posted on: 2008/2/6 16:09
jhammons01 RE:Chrome Plating
Chrome plating aluminum is slightly different than plating steel. First, we should define what a "show chrome" finish is. Show chrome is a three to four step plating process. That is why show chrome (or decorative chrome) is sometimes called "triple chrome." OK, show chrome is: copper plating, then nickel plating (sometimes two layers of nickel) and finally chrome plating. When you look at chrome, you are actually seeing mostly the nickel plate. Chrome is thin and transparent, and really serves to protect nickel from corrosion. So really you don't see the chrome although chrome does slight;y "color" the final product.
Aluminum is zincated because it deoxidizes the aluminum and insulates it so it cannot oxidize before and during plating. When the part is plated, as it is lowered into the solution, the zinc is dissolved and the bare aluminum is plated.
OK, so back to the original question. Why don't you see chrome on aluminum. Outside of the above explanations, aluminum requires an extra plating step in that it must first be plated with zincate (Zinc) so that copper plating will bond, then nickel, then chrome.
Long story short, plating aluminum is more expensive than chrome plating steel, and aluminum can be treated cosmetically with cheaper methods.
Posted on: 2008/2/6 22:24
Top of Utah
372 Posts
I stand corrected. Sorry.
I am CFI-EFI, and I approve of this message.
RACE ON!!!
Posted on: 2008/2/7 2:19
Oxford, Pa
127 Posts
There is Bare Aluminum and Clad Aluminum (sheet stock). The Clad Aluminum can be buffed to a very smooth and shiney surface. Almost chrome like, little different in color and depth.
Posted on: 2008/2/7 3:00
1778 Posts
I think I'm going PC, shiny black. The valve covers are chrome, and the Super Ram is polished to a chrome like finish. Some black in there wouldn't be the end of the world.
Posted on: 2008/2/7 3:03
