210 user(s) are online (184 user(s) are browsing Forums)
Also known as NHMS....
LD85 New Rear LED tail lamps.
Indianapolis, Indiana
784 Posts
Pricey, but I love them.
Posted on: 2012/3/29 19:07
Edited by LD85 on 2012/3/29 19:23:57
2005/Z51
LD85 Re: New Rear LED tail lamps.
784 Posts
Halo
jpg  halo 1.jpg (0.00 KB)
jpg  halo 2.jpg (0.00 KB)
Posted on: 2012/3/30 2:13
2005/Z51
784 Posts
from 20 feet
Posted on: 2012/3/30 2:17
2005/Z51
pianoguy Re: New Rear LED tail lamps.
Them babies is bright!
Posted on: 2012/3/30 3:08
bogus Re: New Rear LED tail lamps.
that is SERIOUSLY bright.
I rather like... then again, I just put on blink-blink, so...
Posted on: 2012/3/30 3:34
istter1 Re: New Rear LED tail lamps.
Bakersfield Ca
2336 Posts
LD85 wrote:
from 20 feet
who did you buy them from , what was the price and what years do they fit?
Posted on: 2012/3/30 4:01
Carol Burnett
Posted on: 2012/3/30 5:32
784 Posts
My wife was following me in the day time on our way to the Dyno tuner, and I got ahead of here @ 1/2 mile in the traffic, she told me,, "I could see your tail lamps even from a distance so I knew where you were going". That was in the day time.
The Halo kit is $210, a little pricey but very worth it since the 85 model year does not have a 3rd tail light, it makes up for it.
I also put the LED interior lights in the cabin, much brighter!
http://www.corvettehid.com/cart/index ... in_page=index&cPath=73_74
The Halo lamps are brigher than the Ecklers due to the roudn Halo
Posted on: 2012/3/30 12:40
2005/Z51
jhammons01 Re: New Rear LED tail lamps.
NOTE: When replacing all four taillight with LED taillights both the turn flasher and warning flasher must be replaced.
what are they talking about?
Posted on: 2012/3/30 15:44
The LED circuitry has a different load rating and you need to replace the flasher relays to support that load rating.
Posted on: 2012/3/30 16:49
784 Posts
Yes, it is basically a higher amp unit and it has aground wire on it so you can run it to the chassis. It was $5 or something at AZ.
Posted on: 2012/3/30 17:44
2005/Z51
Is it one part or is it two?? Their website shows only one related part.
Posted on: 2012/3/30 20:13
784 Posts
The electronic flasher is one part
The Halo tail lamp is a sealed one piece assembly
http://www.corvettehid.com/cart/index ... duct_info&products_id=253
Posted on: 2012/3/30 20:17
2005/Z51
CorvetteArchives Re: New Rear LED tail lamps.
65 Posts
There are 2 flashers you need for 2 different purposes(at least on an 84.)
One is the tail light flasher (located in 84 on the passenger side below the "breadbox"). The one I bought from Eckler's had an additional ground wire.
and the other is the Hazard Flasher which on 84 is behind the DIC(Driver Info Cluster-warning lights). I didnt buy this from Eckler's because at the time they didnt warn me I needed a second one... so I eventually bought one at autozone and it worked fine :-)
Hope that helps your application and an idea of what you may need to disassemble :-)
Posted on: 2012/4/2 2:48
Matatk Re: New Rear LED tail lamps.
I like those lights, I just can't bite the bullet for the cost right now
Now it's time to do your third brake light as an LED if you haven't already
Posted on: 2012/4/2 11:33
captmike13 Re: New Rear LED tail lamps.
Hillsboro Mo
2166 Posts
Nice thing is the 85's don't have the third brake light.
Reminds me I need to put mine in too. They do look good.
Posted on: 2012/4/2 15:11
13 GMC 3500 dually
captmike13@yahoo.com
flyboy Re: New Rear LED tail lamps.
I really like the instant on feature of LED's.
It's like a slap in the face to the texter/cell yakker that's bearing down on your rear bumper.
Posted on: 2012/4/2 15:33
