LD85 | New Rear LED tail lamps. | ||
Pricey, but I love them.
Posted on: 2012/3/29 19:07
Edited by LD85 on 2012/3/29 19:23:57 |
2005/Z51 |
LD85 | Re: New Rear LED tail lamps. | ||
Halo
Attach file: halo 1.jpg (0.00 KB) halo 2.jpg (0.00 KB) |
Posted on: 2012/3/30 2:13
2005/Z51 |
from 20 feet
Posted on: 2012/3/30 2:17
2005/Z51 |
pianoguy | Re: New Rear LED tail lamps. | ||
Them babies is bright!
Posted on: 2012/3/30 3:08
bogus | Re: New Rear LED tail lamps. | ||
that is SERIOUSLY bright.
I rather like... then again, I just put on blink-blink, so... |
Posted on: 2012/3/30 3:34
istter1 | Re: New Rear LED tail lamps. | ||
who did you buy them from , what was the price and what years do they fit? |
Posted on: 2012/3/30 4:01
Posted on: 2012/3/30 5:32
My wife was following me in the day time on our way to the Dyno tuner, and I got ahead of here @ 1/2 mile in the traffic, she told me,, "I could see your tail lamps even from a distance so I knew where you were going". That was in the day time.
The Halo kit is $210, a little pricey but very worth it since the 85 model year does not have a 3rd tail light, it makes up for it. I also put the LED interior lights in the cabin, much brighter! http://www.corvettehid.com/cart/index ... in_page=index&cPath=73_74 The Halo lamps are brigher than the Ecklers due to the roudn Halo |
Posted on: 2012/3/30 12:40
2005/Z51 |
jhammons01 | Re: New Rear LED tail lamps. | ||
NOTE: When replacing all four taillight with LED taillights both the turn flasher and warning flasher must be replaced.
what are they talking about? |
Posted on: 2012/3/30 15:44
The LED circuitry has a different load rating and you need to replace the flasher relays to support that load rating.
Posted on: 2012/3/30 16:49
Yes, it is basically a higher amp unit and it has aground wire on it so you can run it to the chassis. It was $5 or something at AZ. |
Posted on: 2012/3/30 17:44
2005/Z51 |
Is it one part or is it two?? Their website shows only one related part.
Posted on: 2012/3/30 20:13
The electronic flasher is one part
The Halo tail lamp is a sealed one piece assembly http://www.corvettehid.com/cart/index ... duct_info&products_id=253 |
Posted on: 2012/3/30 20:17
2005/Z51 |
CorvetteArchives | Re: New Rear LED tail lamps. | ||
There are 2 flashers you need for 2 different purposes(at least on an 84.)
One is the tail light flasher (located in 84 on the passenger side below the "breadbox"). The one I bought from Eckler's had an additional ground wire. and the other is the Hazard Flasher which on 84 is behind the DIC(Driver Info Cluster-warning lights). I didnt buy this from Eckler's because at the time they didnt warn me I needed a second one... so I eventually bought one at autozone and it worked fine :-) Hope that helps your application and an idea of what you may need to disassemble :-) |
Posted on: 2012/4/2 2:48
Matatk | Re: New Rear LED tail lamps. | ||
I like those lights, I just can't bite the bullet for the cost right now
Now it's time to do your third brake light as an LED if you haven't already |
Posted on: 2012/4/2 11:33
captmike13 | Re: New Rear LED tail lamps. | ||
Nice thing is the 85's don't have the third brake light.
Reminds me I need to put mine in too. They do look good. |
Posted on: 2012/4/2 15:11
flyboy | Re: New Rear LED tail lamps. | ||
I really like the instant on feature of LED's.
It's like a slap in the face to the texter/cell yakker that's bearing down on your rear bumper. |
Posted on: 2012/4/2 15:33
