200 user(s) are online (142 user(s) are browsing Forums)
Also known as NHMS....
BrianCunningham Any tips to removing 17yo brake hoses
Yeah the original lines are still on it.
These came in Wednesday
http://www.summitracing.com/parts/WIL-220-8338
My 6pot Wilwoods fit my CCW wheels though I am going to need a 1/4in spacer. So I'm going to mount them up.
Though I decided to tackle taking apart the 17yo brakes hose until a weekend I'm not autocrossing.
(instead of 2 days before)
Posted on: 2012/5/18 0:47
Matatk Re: Any tips to removing 17yo brake hoses
No trick I know of...pb blaster is what I would start with.
Posted on: 2012/5/18 1:08
BillH Re: Any tips to removing 17yo brake hoses
PB won't do much.
Absolute must - use line wrenches not standard wrenches.
A little heat on the connection won't hurt anything.
When loosening the line to frame tube connection the position of the wrenches must be where you can squeeze the 2 wrenches together with 2 hands, this will help prevent rounding off the fitting heads.
Posted on: 2012/5/18 2:01
bogus Re: Any tips to removing 17yo brake hoses
What Bill said. I ran into some issues with seized up threads when I did my SS lines.
It isn't pretty.
I also ran into issues with the lines on Bastets 87... so bad, I had to cut the line and flare it.
Posted on: 2012/5/18 2:43
MK 82 Re: Any tips to removing 17yo brake hoses
Palm Beach Gardens, FL
439 Posts
BFH!
Posted on: 2012/5/18 3:05
96 CE Roadster LT4
normally, I would agree... but hammers and hoses don't seem to function well together.
Posted on: 2012/5/18 4:11
RickAnthony Re: Any tips to removing 17yo brake hoses
ASE Master Certified
Downers Grove, IL
703 Posts
I would soak them in PB blast, definitely use line wrenches as stated.. and I would heat the fittings up before even trying to turn them. I bought one of these tools and I use it just about every day...
http://www.youtube.com/watch?v=_YO_snrzYrs
Works awesome on lines like this! there is a used one of the 1st generation of this tool on e-bay right now for about $300
Posted on: 2012/5/18 4:36
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
That's really cool Rick.
Very pricy though.
Posted on: 2012/5/18 13:27
seriously cool... but also pretty expensive... but for what you do, it has to be invaluable. And no need to worry about being out of gas!
Posted on: 2012/5/19 1:58
I saw that tool Rick has in action....it's awesome. Out of my price range for a toy, but Rick uses it in a professional manner.
Posted on: 2012/5/19 2:37
klkordzi Re: Any tips to removing 17yo brake hoses
Pittsburgh, Penna
152 Posts
Disconnect the hose and remove the retaining clip the rotate the hose around the hard line. A vise grip on the hard line makes sure the flats on the nut don't get rounded off.
Posted on: 2012/5/27 0:30
flyboy Re: Any tips to removing 17yo brake hoses
1:29 into this demonstration, he says it draws 1000 amps?
Think he means 1000 watts?
http://www.youtube.com/watch?v=hcVYYVGCt5M&feature=related
He also says not to look into the LED bulb.
Salesman ought to get his facts straight.
Posted on: 2012/5/27 3:29
