216 user(s) are online (177 user(s) are browsing Forums)
BrianCunningham Any tips to removing 17yo brake hoses
Yeah the original lines are still on it.
These came in Wednesday
http://www.summitracing.com/parts/WIL-220-8338
My 6pot Wilwoods fit my CCW wheels though I am going to need a 1/4in spacer. So I'm going to mount them up.
Though I decided to tackle taking apart the 17yo brakes hose until a weekend I'm not autocrossing.
(instead of 2 days before)
Posted on: 2012/5/18 0:47
Matatk Re: Any tips to removing 17yo brake hoses
No trick I know of...pb blaster is what I would start with.
Posted on: 2012/5/18 1:08
BillH Re: Any tips to removing 17yo brake hoses
PB won't do much.
Absolute must - use line wrenches not standard wrenches.
A little heat on the connection won't hurt anything.
When loosening the line to frame tube connection the position of the wrenches must be where you can squeeze the 2 wrenches together with 2 hands, this will help prevent rounding off the fitting heads.
Posted on: 2012/5/18 2:01
bogus Re: Any tips to removing 17yo brake hoses
What Bill said. I ran into some issues with seized up threads when I did my SS lines.
It isn't pretty.
I also ran into issues with the lines on Bastets 87... so bad, I had to cut the line and flare it.
Posted on: 2012/5/18 2:43
MK 82 Re: Any tips to removing 17yo brake hoses
Palm Beach Gardens, FL
439 Posts
BFH!
Posted on: 2012/5/18 3:05
96 CE Roadster LT4
normally, I would agree... but hammers and hoses don't seem to function well together.
Posted on: 2012/5/18 4:11
RickAnthony Re: Any tips to removing 17yo brake hoses
ASE Master Certified
Downers Grove, IL
703 Posts
I would soak them in PB blast, definitely use line wrenches as stated.. and I would heat the fittings up before even trying to turn them. I bought one of these tools and I use it just about every day...
http://www.youtube.com/watch?v=_YO_snrzYrs
Works awesome on lines like this! there is a used one of the 1st generation of this tool on e-bay right now for about $300
Posted on: 2012/5/18 4:36
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
That's really cool Rick.
Very pricy though.
Posted on: 2012/5/18 13:27
seriously cool... but also pretty expensive... but for what you do, it has to be invaluable. And no need to worry about being out of gas!
Posted on: 2012/5/19 1:58
I saw that tool Rick has in action....it's awesome. Out of my price range for a toy, but Rick uses it in a professional manner.
Posted on: 2012/5/19 2:37
klkordzi Re: Any tips to removing 17yo brake hoses
Pittsburgh, Penna
152 Posts
Disconnect the hose and remove the retaining clip the rotate the hose around the hard line. A vise grip on the hard line makes sure the flats on the nut don't get rounded off.
Posted on: 2012/5/27 0:30
flyboy Re: Any tips to removing 17yo brake hoses
1:29 into this demonstration, he says it draws 1000 amps?
Think he means 1000 watts?
http://www.youtube.com/watch?v=hcVYYVGCt5M&feature=related
He also says not to look into the LED bulb.
Salesman ought to get his facts straight.
Posted on: 2012/5/27 3:29
