273 user(s) are online (223 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
crazytigr96vet383 newby with a thirst for corvette knowledge
Covington , ga
8 Posts
i have a 96 collectors edition that has some work done to it.AFR 210 CC Heads,lt4 intake, comp 280 xfi cam,headers,egr,air delete,programmed by pcm4less ,recent tranny rebuild.they had the car for 6 weeks,took them 3 times to get it done,paid for shift kit but cant tell any difference,went with stock stall.msd opti.58mm throttle body,forged internals,msd 8.5 wires,10.7:1 compression ratio.stock gears(whatever that is,in od im 2200 rpm at 80 mph.custom valve covers,7qt canton oil pan,hydrolic roller lifters,1.6 rocker arms,and on and on. i have a book of receipts from previous owner.i know hardly nothing about the car so any suggestions are appreciated. chasis dyno last week best pull was 365hp 480lb torque @5100 rpm. does this sound accurate? motor has 9k miles since build in 09.
jpg  corvette motor 1.jpg (0.00 KB)
Posted on: 2012/6/16 18:39
crazytigr96c4/383
Matatk Re: newby with a thirst for corvette knowledge
Welcome to the site! Sounds like a great build. I would say those are healthy numbers and right in line with your mods.
Posted on: 2012/6/16 18:44
1Fast04Vert Re: newby with a thirst for corvette knowledge
Look in the storage compartment behind the passenger seat and you will find your RPO codes, which will tell you the rear end ratio. GM1 is 2.59, G-92/G-44 is the 3.07. Sorry I can't help you with the tranny problems. Perhaps pcm4less can tell you if it is a programming problem.
Posted on: 2012/6/16 18:47
crazytigr96vet383 Re: newby with a thirst for corvette knowledge
Covington , ga
8 Posts
the only one of those numbers i saw that matched was the GM1. There is proably 20 sets of numbers there. thanks for that info. i got another question for ya.i want to go to a 373 gear,is it worth it and would i have to change more than gear ratio or would the dana 36 hold up to the motor.
Posted on: 2012/6/16 19:18
crazytigr96c4/383
With your HP, 3.73 gears and sticky tires I would doubt if the D36 would last very long. There is a guy near us in Acworth that parts out C4s and could set you up with a D44 and 3.45 gears. His name is Chris and phone is 770-546-3504 (weekdays during regular business hours). Otherwise you could probably find a D36, 3.07 rear ready to drop in for under $500.
Posted on: 2012/6/16 20:12
Covington , ga
8 Posts
will do thanks again.
Posted on: 2012/6/16 20:46
crazytigr96c4/383
bogus Re: newby with a thirst for corvette knowledge
welcome aboard!
I agree, too much power and too much traction, the D36 well not be long for this world!!!
The engine sounds pretty stout, but with an ODBII computer, I see no reason to ship it out for programming. You need to find someone local - and you ain't far from Atlanta - who can dyno tune that beast. I will bet money you will find some more power that way.
Also, check with your local hot rod and Corvette clubs to see who they recommend.
Posted on: 2012/6/17 2:56
Covington , ga
8 Posts
my main problem is when at the redlight im idling so rough my voltage hand is jumping all around,how can i raise the idle up when im in at redlight, but not cause it to jerk foward when i put it in first?
Posted on: 2012/6/20 2:24
crazytigr96c4/383
Ultraman Re: newby with a thirst for corvette knowledge
14747 Posts
Welcome to the show.....plenty of knowledge on tap here...Pics of the car when you get a chance....
Posted on: 2012/6/20 3:13
djxib Re: newby with a thirst for corvette knowledge
North Georgia
456 Posts
Raising the idle isnt straightforward physically - you have to do it in the tune. However, according to comp the XFI280 cam has a strong idle so I wouldnt expect it to be rough like you describe. Before you look at idle speed I recommend you do some basic troubleshooting, maybe start a new thread over in C4 Tech. Could be anything from arc-ing plug wires (check in a dark garage) to a vacuum leak to old injectors to a poor tune.. start from the basics and work upwards.
Oh - and congrats on the car - nice numbers!
Posted on: 2012/6/20 12:01
Andy
Trae1976 Re: newby with a thirst for corvette knowledge
Johnson City, TN
832 Posts
Welcome crazytigr!  hello2
Sorry, I can't help with the knowledge part.  laughing6
Posted on: 2012/6/20 12:26
EngineDoctor Re: newby with a thirst for corvette knowledge
La Habra Ca.
791 Posts
Welcome aboard, and nice numbers !
Posted on: 2012/6/20 19:40
Covington , ga
8 Posts
thanks guys,can anyone explain to me why i only did 365rwhp on the chassis dyno but had 480lbs of torque?? i was told this motor was capable of 500 hp. which is better, hp or torque when it comes to taking it to the track?
Posted on: 2012/6/20 21:22
crazytigr96c4/383
La Habra Ca.
791 Posts
IMHO it's all in the combo !
Let's see wat the other guys think ?
Posted on: 2012/6/20 21:41
BillH Re: newby with a thirst for corvette knowledge
Drags - horsepower for mid track to top end.
Roadrace - torgue - always
Posted on: 2012/6/20 21:56
La Habra Ca.
791 Posts
X 2 on that !
Posted on: 2012/6/20 22:18
North Georgia
456 Posts
I'd need to see the actual graph, but 'typically' a much higher torque number than HP is a characteristic of a motor with a small turbo or nitrous. If your 365hp figure is at 5500 RPM then I would say maybe the heads are restricting higher end horsepower.
However - your torque number is very very nice for a NA motor.. I bet that thing pulls hard! Personally I wouldnt mess with anything except to try and fix your poor idle.
Posted on: 2012/6/21 12:29
Andy
