131 user(s) are online (113 user(s) are browsing Forums)
Ultraman, more...
Driver Information Center.
finderhome Delayed starting
Redondo Beach
17 Posts
Does anyone know what causes the car not to start and then will start a few minutes later.
Posted on: 2012/8/28 4:20
vetteoz Re: Delayed starting
More info needed
It won't crank over ,
it cranks over but won't fire up ,
it cranks and kicks up but won't stay running
it fires up but dies straight away ............
Posted on: 2012/8/28 5:09
bogus Re: Delayed starting
I assume this is the 93 LT1?
Posted on: 2012/8/28 5:15
Matatk Re: Delayed starting
What vetteoz said...if we get some more specific info, we can try to pinpoint the problem!
Posted on: 2012/8/28 11:34
BillH Re: Delayed starting
+1
And you also need to pull the codes.
Posted on: 2012/8/28 13:14
If you need any help with the above requests, let me know.
Posted on: 2012/8/28 14:23
finderhome Re: Delayed starting
Redondo Beach
17 Posts
It will not crank over. It doesn't even click. Then in about three minutes it starts and runs perfectly. Could it have something to do with the security system????
Posted on: 2012/9/1 4:08
Sure can .
http://www.thirdgen.org/vats_passkey_system
If the resistor pellet on the key is not read correctly because it or the the contacts in Ign switch that read it are dirty or worn ;the VATS system shuts the starter ( and injectors ) down for 4 minutes
Got a spare key to try?
Posted on: 2012/9/1 5:54
Again, pull the codes.
A VATS problem will usually show up in module 1.1 as a Pass Key Error, 61, 62, 63.
Posted on: 2012/9/1 13:40
Finderhome,
We can only help those that help themselves...
All we need to know is year! That will help a ton. Codes would be nice, and I even offered to come over and help you pull them.
Please... help us, help you.
Posted on: 2012/9/1 23:41
Posted on: 2012/9/1 23:57
I thought so, but was hoping for some confirmation...
Posted on: 2012/9/2 0:48
RickAnthony Re: Delayed starting
ASE Master Certified
Downers Grove, IL
703 Posts
first thing, check the battery connections..
Posted on: 2012/9/2 16:05
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
Redondo Beach
17 Posts
Yes It has no response not even a click and then it turns over a few minutes later with no problem
Posted on: 2012/9/11 15:04
Redondo Beach
17 Posts
Thanks for all your help I will go buy a new key today and see if that is the problem and next I will check the codes.
Posted on: 2012/9/11 15:07
1Fast04Vert Re: Delayed starting
VATS is ridiculously easy to diagnos. If you turn the key on and the security light to the left of the speedometer lights and stays lit you have a VATS issue. Clean the key pellet off really good (brakeclean, alcohol, etc.), wait a few minutes and try again.
Posted on: 2012/9/11 15:58
if you need help, reach out. I am in San Pedro!!!
Posted on: 2012/9/11 16:09
The nominal VATS timer (for the starter relay) is 10 minutes, some will run as long as 15.
IF you try and start the car before the timer runs out, it will reset the timer and you have to wait another 10-15.
Again and again - see post # 5 & #9.
Buying parts before you diagnose is a waste of your money.
Posted on: 2012/9/12 1:40
