finderhome | Delayed starting | ||
Does anyone know what causes the car not to start and then will start a few minutes later.
Posted on: 2012/8/28 4:20
vetteoz | Re: Delayed starting | ||
More info needed It won't crank over , it cranks over but won't fire up , it cranks and kicks up but won't stay running it fires up but dies straight away ............ |
Posted on: 2012/8/28 5:09
bogus | Re: Delayed starting | ||
I assume this is the 93 LT1?
Posted on: 2012/8/28 5:15
Matatk | Re: Delayed starting | ||
What vetteoz said...if we get some more specific info, we can try to pinpoint the problem!
Posted on: 2012/8/28 11:34
BillH | Re: Delayed starting | ||
+1 And you also need to pull the codes. |
Posted on: 2012/8/28 13:14
If you need any help with the above requests, let me know.
Posted on: 2012/8/28 14:23
finderhome | Re: Delayed starting | ||
It will not crank over. It doesn't even click. Then in about three minutes it starts and runs perfectly. Could it have something to do with the security system????
Posted on: 2012/9/1 4:08
Sure can . http://www.thirdgen.org/vats_passkey_system If the resistor pellet on the key is not read correctly because it or the the contacts in Ign switch that read it are dirty or worn ;the VATS system shuts the starter ( and injectors ) down for 4 minutes Got a spare key to try? |
Posted on: 2012/9/1 5:54
Again, pull the codes.
A VATS problem will usually show up in module 1.1 as a Pass Key Error, 61, 62, 63. |
Posted on: 2012/9/1 13:40
Finderhome,
We can only help those that help themselves... All we need to know is year! That will help a ton. Codes would be nice, and I even offered to come over and help you pull them. Please... help us, help you. |
Posted on: 2012/9/1 23:41
1993
Posted on: 2012/9/1 23:57
I thought so, but was hoping for some confirmation...
Posted on: 2012/9/2 0:48
RickAnthony | Re: Delayed starting | ||
ASE Master Certified
first thing, check the battery connections..
Posted on: 2012/9/2 16:05
Yes It has no response not even a click and then it turns over a few minutes later with no problem
Posted on: 2012/9/11 15:04
Thanks for all your help I will go buy a new key today and see if that is the problem and next I will check the codes.
Posted on: 2012/9/11 15:07
1Fast04Vert | Re: Delayed starting | ||
VATS is ridiculously easy to diagnos. If you turn the key on and the security light to the left of the speedometer lights and stays lit you have a VATS issue. Clean the key pellet off really good (brakeclean, alcohol, etc.), wait a few minutes and try again.
Posted on: 2012/9/11 15:58
if you need help, reach out. I am in San Pedro!!!
Posted on: 2012/9/11 16:09
The nominal VATS timer (for the starter relay) is 10 minutes, some will run as long as 15.
IF you try and start the car before the timer runs out, it will reset the timer and you have to wait another 10-15. Again and again - see post # 5 & #9. Buying parts before you diagnose is a waste of your money. |
Posted on: 2012/9/12 1:40
