293 user(s) are online (239 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Angelsword LT-4 Double Row Timing Set
Southeast of Disorder
6 Posts
Has any one replaced the single row set with a double row set? Cloyes is the only aftermarket set I have found. A bit pricey at $355.00…Without the need for a cam driven water pump gear, there must be others that will fit.
It’s just a small block Chevy…
Posted on: 2008/2/14 5:26
bogus RE:LT-4 Double Row Timing Set
good question... but there are other differences.
Cloyes and GMPP both offer the double roller for the LT4, IIRC.
Posted on: 2008/2/14 7:05
Notorious RE:LT-4 Double Row Timing Set
On a '96 I'm not sure what you might run into re/ the crank sensor. But I do know that if necessary, it can be eliminated and programmed out of the PCM. Other than that, once you eliminate the water pump drive, you can use the Cloyes 9-3145 which is under $100. It's what I have in my '95.
Posted on: 2008/2/14 13:44
I hate sporks...
pianoguy RE:LT-4 Double Row Timing Set
Cloyes is good stuff - I used to put them in my Pontiacs 30+ years ago after the factory timing set failed (which they always did).
Posted on: 2008/2/14 14:54
Angelsword RE:LT-4 Double Row Timing Set
6 Posts
Thanks for the feedback guys.
Notorious, I was not sure what you thought could interfere with the crank sensor. So, I took a walk out to my shop…You’re right. A double row sprocket might move the reluctor ring out of sight of the sensor. I’ll take some careful measurements before I make a decision.
Bogus, you mentioned “other differences”, am I overlooking something else?
Pianoguy, thanks for the endorsement of Cloyes. I’ve used their timing sets on fast revving Ford small blocks without problems.
Thanks again! I’ll confirm with my favorite source for such information…Summit Racing…and let ya'll know what I find.
Posted on: 2008/2/15 2:06
Back in the 80s, I raced a Ford stock car on dirt for a few years. I used a Cloyes DR in my 351 Cleveland engines. Although I used more than one engine over those years, the same Cloyes timing set was used over and over again in each engine. Needless to say, when I need a timing set, it's always a Cloyes.
Posted on: 2008/2/15 2:20
Josh RE:LT-4 Double Row Timing Set
For the cam gear, you'll have to clearance the inside of the timing cover.
Posted on: 2008/2/15 3:53
smooth RE:LT-4 Double Row Timing Set
Formerly "Aquavet" in Pa.
386 Posts
...Well now I'm confused. if you go to summit and check the specs for a 94-96, it sends you to the 9-3151 which is the $355 one. And in the notes section says
"Timing chain has a 1/2 in. pitch. Can be installed on Generation 1 LT1, if the OptiSpark is updated to the new, second design. This will require new ignition, new front cover, and cam change to second design cam, the nose is different. The older OptiSpark"
It makes no note of the crank sensor issue. Why would you even bother with this one in the first place? It sounds like you have to spend more than just the $355 to make it work.Is the one you noted (9-3145) just a heavy duty direct swap in for the 94-96 LT1? "cause if it is, sounds like a no brainer. But Summitt's site says that this part (9-3145) is for Gen I engine family and "won't clear the plastic timimg cover" ?
WHAT GIVES?
Posted on: 2008/2/15 4:53
Alan
2001 Navy Blue Metallic
LT4BUD RE:LT-4 Double Row Timing Set
52 Posts
The Cloye's double roller works with an electric water pump. On the LT4 the best way is to remove the reluctor ring and reprogram to ignore misfire signals...PCMforLess did mine. The double roller and reluctor ring will not work together on the LT4 as they are manufactured.
This is what I did, much better than the single roller and stock waterpump....plus as you have found out, you get the double roller/electric water pump for the price of the single roller set
BTW if you are not talking about a LT4 the above is not going to be true. A upgraded LT1 will be different....I don't see where you say what you are actually dealing with??? I assumed it is a 96 LT4
Posted on: 2008/2/15 14:34
MK 82 RE:LT-4 Double Row Timing Set
Palm Beach Gardens, FL
439 Posts
You can get the LT4 timing set with both gears and a water pump drive for about $250. I have never heard of a failure of this setup in a street application. When I do my new cam, this is what i will use. I prefer to stay with the stock water pump.
http://store.summitracing.com/partdet ... mp;N=115&autoview=sku
Posted on: 2008/2/16 2:43
96 CE Roadster LT4
Nothing wrong with that if that's your preference. But single roller sets will stretch more and sooner than a DR set-up, thus altering your cam timing. And if you're worried about the reliability of an electric water pump, my HD Meziere is still going strong at 32K miles and counting. And if they do ever fail, they won't puke coolant onto your opti as a mechanical pump will. This is but one of the many advantages of an EWP.
Posted on: 2008/2/16 3:13
439 Posts
Hah!! You're not getting me in that debate. Made up my mind and that's that!!
:thumbleft: :thumbright:
Posted on: 2008/2/16 5:21
96 CE Roadster LT4
JAKE266 RE:LT-4 Double Row Timing Set
Kempner, Texas
22 Posts
I went with the Cloyes set from Summit and left everything else as stock; water pump, reluctor, etc.
I considered going with an electric W/P, but decided against it, even though I had already bought a Cloyes True-Roller set. I just sold the T/R to another Forum member who was happy to get it at such a super price.
Jake
Posted on: 2008/2/16 23:00
__________________
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
6 Posts
Aquavet, I’m still suffering some confusion also…I’ve seen some traffic about this same question on another forum, and I still have no clear answer.
LT4BUD has the best answer I’ve seen so far.
The Meziere is ready to be installed. I hadn’t considered a new timing set until took a good look at the one I took out. About 50,000 miles on a 383 that was built in 96, when the car was new….By the way, LT4BUD, if it’s an LT4, it can only be a 96.
I’ll keep ya’ll posted on what I finally do…maybe I’ll respond to the thread on that other forum..maybe.
Posted on: 2008/2/19 0:37
