253 user(s) are online (197 user(s) are browsing Forums)
-=Jeff=- Improved Stopping Power
Bartlett, IL
573 Posts
Found a deal so I am swapping my C5 brakes for these..
But some fluid got on the paint and the paint came off. Talking to Brembo these need to be painted no PC'ed So I decided to paint them to match the rears
Here are what they look like now
I will be finishing up my 4.10 install tonight and tomorrow then in a week or so I will get the Brakes done
Posted on: 2012/10/14 22:15
-=Jeff=-
1990 Corvette ZR-1 #1051
jaa1992 Re: Improved Stopping Power
Stone Mtn, GA (near Atlanta)
187 Posts
Why can't I find these deals on big brakes
How are you going to mount them?
Posted on: 2012/10/15 1:06
BillH Re: Improved Stopping Power
They'll make C5 calipers look silly.
Posted on: 2012/10/15 1:12
bogus Re: Improved Stopping Power
those are bad ass.
Posted on: 2012/10/15 2:35
Matatk Re: Improved Stopping Power
22808 Posts
Are they direct swap? What type of adapter, etc is necessary? Stock size rotors?
Posted on: 2012/10/15 3:28
-=Jeff=- Re: Improved Stopping Power
Bartlett, IL
573 Posts
Yes Direct swap, I got 2 pc rotors with them and the brackets for the install..
These were previously installed on a 1992 ZR-1.. he went with 2012 GS 6 piston Calipers
Posted on: 2012/10/15 3:50
-=Jeff=-
Bartlett, IL
573 Posts
Here is a picture with the bracket
Rotors
Posted on: 2012/10/15 4:00
-=Jeff=-
BrianCunningham Re: Improved Stopping Power
Sweet!
Posted on: 2012/10/15 15:38
22808 Posts
Nice setup! I'm jealous!
Posted on: 2012/10/15 17:35
Bartlett, IL
573 Posts
I cannot wait to get them installed
Posted on: 2012/10/19 4:11
-=Jeff=-
Bartlett, IL
573 Posts
Waiting on a couple parts but starting the install.
I ended up painting the "Brembo" and logo on the caliper in place of the vinyl decals
Posted on: 2012/11/7 1:57
-=Jeff=-
Bartlett, IL
573 Posts
Mock up while waiting for longer wheel studs
Posted on: 2012/11/8 5:14
-=Jeff=-
jonszr1 Re: Improved Stopping Power
Lone Pine, CA
shre did you get the brake pads. o am having trouble finding pads for my brembos
Posted on: 2012/11/8 16:02
Bartlett, IL
573 Posts
I have Hawk HB194 ferro-carbon Pads.. ready to go for mine..
Posted on: 2012/11/8 16:13
-=Jeff=-
Bartlett, IL
573 Posts
Posted on: 2012/11/11 3:05
-=Jeff=-
22808 Posts
Longer wheel studs? Does the brake rotor side farther outboard? Does it affect the wheel?
Posted on: 2012/11/11 3:27
Bartlett, IL
573 Posts
The hub is thicker (.75")
so it is about 3/16 more then the other rotor and a 1/4" spacer
it will push the wheel out more, but with my wheels I should still be fine and it should not stick out
You can see the hub thickness here
Posted on: 2012/11/11 4:32
-=Jeff=-
CentralCoaster Re: Improved Stopping Power
What size pistons in those suckers? Hopefully not too much bigger than stock.
Posted on: 2012/11/11 7:39
Bartlett, IL
573 Posts
I did not measure them but I could get an approx size from the markings on the old pads..
Brakes are done and bled, but I can't drive it.. weather is way too crappy here right now
Posted on: 2012/11/11 22:32
-=Jeff=-
SpectatorRacing Re: Improved Stopping Power
Where are the bleeder screws on those?
Looks good, be careful with brakecleen. I painted mine once with good hi-temp paint and the first time I sprayed them in was gone...oops.
Posted on: 2012/11/13 15:01
