299 user(s) are online (256 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Schrade Interior resonance / exhaust drone...
Who put on new exhaust, and got more drone inside than they were countin' on? Did you do anything (besides changing hardware) about it?
What did you do?
I put a layer of 3/16" styrofoam under the roof panel pad, in the new painted top, and it helped a little, on a media player recording on the PC, with an EQ, then a layer of cork under the rear cargo carpet, and got a little lower reading.
Now I'm running wrap further on the pipes. Had it to the back of the tranny, and gettin' ready to install the X-section, and 2 x 18" length after that, and gonna' run it all the way to the Power Effects mufflers next, to try to take off a little more drone here...
Posted on: 2014/8/21 0:38
Matatk Re: Interior resonance / exhaust drone...
22803 Posts
My magnaflows were pretty bad. I put on an LT4 exhaust and the factory mufflers sound great to me.
Posted on: 2014/8/21 4:02
-=Jeff=- Re: Interior resonance / exhaust drone...
Bartlett, IL
573 Posts
on my 89 I had more exhaust system then I can count..
on my 90 Z I have had 3
-Stock
-Borla Challenge (with stock manifolds, then headers, no cats)
-Corsa (with headers and cats)
I am happy with corsa.. no drone. Borla was not bad either but the resonator was necked down
If I were to change again, I think i would do a stock exhaust for my 90, with a 1996 resonator and some type of muffler
Oh yeah.. I would keep my headers and cats
Posted on: 2014/8/21 12:09
-=Jeff=-
1990 Corvette ZR-1 #1051
bogus Re: Interior resonance / exhaust drone...
I am a fan of Corsa.
The problem is that the C4 storage area is one big resonance chamber. It really amplifies the boom.
My ears are very sensitive, and the boom about killed me when I was running muffler eliminators. Never do that again!
Posted on: 2014/8/21 22:15
j3studio Re: Interior resonance / exhaust drone...
The other thing to keep in mind is making sure that the new exhaust isn't even fractionally shorter than the stock exhaust.
Don't ask me how I know ...
Posted on: 2014/8/22 0:04
jonszr1 Re: Interior resonance / exhaust drone...
Lone Pine, CA
the best way I found to keep the drone down was to extend the tips of the exhaust 2in past the rear valance. a buddy who has been doing exhaust for 30years got me to try it and the difference is amazing . might not look quite as pretty as flush mounted . but my 23 in system in cruise mode is almost as quiet as stk. my system is headers no cats 3in with x pipe and dyno max 3 in super turbos with dual exits
Posted on: 2014/8/22 15:41
Lone Pine, CA
opps should be 3 in not 23 in sorry .finger malfunction
Posted on: 2014/8/22 15:42
DrDyno Re: Interior resonance / exhaust drone...
St. Petersburg, FL
45 Posts
What did you do?
Hi Schrade,
I swapped out the stock mufflers on my '96 LT1 for a set of Allen Stainless "chambered" muffler eliminators. The exterior sound is incredible but... so, too, was the interior sound!
Researching "Corvette drone" and "Corvette resonance" on the web, I learned that resonance can be cancelled out with either a "resonance canister" attached to each exhaust run (on dual exhausts) or, by attaching a pipe between the two runs to help cancel out the individual resonance. I chose the latter, as the following pics will show. The holes drilled are 1/2" (as one of the web posts had suggested) and the "H" Pipe (as the muffler folks call it) is 1-1/2" diameter.
I still have some drone but now it's about 1,000 RPM higher up the scale and much "softer" than before the mod. For $50.00 at my local muffler shop, I'm very happy with the results!
EDIT - Not sure why the pics didn't show up... just click on "torn" image.
jpg  IMAG0817.jpg (96.51 KB)
21152_53f9120f07228.jpg 640X475 px
jpg  IMAG0818.jpg (109.70 KB)
21152_53f912246611f.jpg 640X475 px
jpg  IMAG0819.jpg (98.39 KB)
21152_53f9123383cda.jpg 640X475 px
jpg  IMAG0820.jpg (89.42 KB)
21152_53f912421654b.jpg 640X475 px
Posted on: 2014/8/23 22:15
John G.
St. Petersburg, FL
"If it seems like you're in control... you're not going fast enough!" Mario Andretti
St. Petersburg, FL
45 Posts
Here's a link to another thread with pics and more info...
http://forums.corvetteforum.com/c4-ge ... nance-control-w-pics.html
Posted on: 2014/8/23 22:37
John G.
St. Petersburg, FL
Schrade Re: Interior resonance / exhaust drone...
That's VERY interesting there DD... VERY INTERESTING.
I just got done wrapping the end section an hour ago (besides the X section, and 2 x 18" sections) - gotta' see what that does, if anything...
As you can see here DD, I DO have an X-section, and I DON'T have a resonator.
What effects might that have, already existing, with the new crossover section added in the rear?
Ronnie, at FlowMaster, gave me a bunch of phone time one day last week, without pimpin' his own FM hardware as my drone / resonance fix. I told him that I think my X section makes it sound like an exhaust leak (I KNOW there is NO LEAK); he said YUP - it can do that, but an H pipe will NOT do the same...
Posted on: 2014/8/24 1:10
Lone Pine, CA
the 96 cars had the rear crossover from the factory
Posted on: 2014/8/24 17:58
Did they do it only for drone? Anyone owned a '96, and also an earlier LT1, and noticed how much less?
Got the sound link there DD - really sounds great. http://forums.corvetteforum.com/1586970204-post6.html
Didn't notice if you had Before N After, with the cross-over section???
ed.:
THis is what I have now: (can't get the link right here - Matt - help? )
http://s446.photobucket.com/user/2man ... c28f4.mp4.html?sort=3&o=2
The vid is the hardware on another guy's Z, same year, same headers, same no mods, exact same everything, almost ID mileage too - 35k, +/- a few.
Like I was saying, outside sounds pretty slick, not even TOO loud, ESPECIALLY considering it's straight pipes.
But inside is not pretty at all...
Posted on: 2014/8/24 18:38
Edited by Schrade on 2014/8/24 18:56:29
Edited by Schrade on 2014/8/24 18:58:22
Edited by Schrade on 2014/8/24 18:58:53
hcbph Re: Interior resonance / exhaust drone...
269 Posts
So the other question is with that much wrapping, did it help reduce heat to the floorboards?
Posted on: 2014/8/24 20:11
St. Petersburg, FL
45 Posts
My '96 LT1 CE had no crossover pipe that I saw.
Exhaust Manifolds -> Cats -> Resonator -> Mufflers.
Unless you mean the central resonator (seen on the right in the pic, below), there was no other connection between the two sides and, I can't find an internal schematic of the resonator.
jpg  IMAG0816.jpg (868.03 KB)
21152_53fa56a0b5dff.jpg 2048X1520 px
Posted on: 2014/8/24 21:13
John G.
St. Petersburg, FL
Never noticed heat there hc, although I never put my hand on the rear cargo floor to see. Or the center console, on the tunnel...
But heat IS a big deal, because my motor is running MUCH cooler now. Marc H chip, set for on @ 205, has NOT come on once this summer. (I haven't done stop n go with A/C tho').
Posted on: 2014/8/25 1:13
pianoguy Re: Interior resonance / exhaust drone...
The factory exhaust on my '96 has a little H-pipe just ahead of where the support bolts up behind the resonator:
Posted on: 2014/8/25 1:34
St. Petersburg, FL
45 Posts
[quote]
Not my LT1... click on my pic, above, (Post #14) for a full sized view.
Posted on: 2014/8/25 3:44
John G.
St. Petersburg, FL
Maybe it's an LT4 thing?
Posted on: 2014/8/25 5:10
22803 Posts
As far as I know it's an LT4 thing, my exhaust is from a 96 LT4 and has it.
Posted on: 2014/8/25 11:44
St. Petersburg, FL
45 Posts
You LT4 Guys get all the good stuff!
Posted on: 2014/8/25 12:28
John G.
St. Petersburg, FL
Ultraman Re: Interior resonance / exhaust drone...
14738 Posts
When I had my 90 L98 I put headers on it with 3" cats hooked to the collecters and then down to 2.5" back into an X pipe and on out to Sound Master mufflers from NAPA....not very sexy on the mufflers but it sounded good and had no drone at any rpm......and only 96 bucks each for the sound masters......of course LT1's are a different cat altogether......
Posted on: 2014/8/25 12:39
BillH Re: Interior resonance / exhaust drone...
No drone.............no mufflers.
jpg  881_4a93f8847570e.jpg (571.22 KB)
881_53fb464b374e0.jpg 1408X1056 px
Posted on: 2014/8/25 14:21
St. Petersburg, FL
45 Posts
WHAD'YA SAY???
Posted on: 2014/8/25 15:12
John G.
St. Petersburg, FL
DrDyno wrote:
WHAD'YA SAY???
Ha, it's an interesting system (chambered cat back).
Under 2,800 it's quiet enough that neighbors/police officers don't even glance at the car when I go by.
When it hits 2,900, it's like a valve opened, sound level doubles. And sounds really good.
At 70mph in 5th or 6th, it's not much louder that stock, hardly noticeable.
And no drone.
Posted on: 2014/8/25 15:29
Lone Pine, CA
on both my zr1s I extended the tips 2 in past the valance ,and that was the single best thing I did to quiet down the exhaust. I also think the super turbo mufflers work great with the 3 in exhaust to keep things in a decent level without costing any power
Posted on: 2014/8/25 17:35
I like those tips.
If I could put them on the PE muffler ends, I wouldn't think twice...
Posted on: 2014/8/25 21:03
Drone is almost gone. Wrap did a great job, much more so than I thought it would...
I don't know if a cross pipe behind the diff, or Peel N Seal can improve what I got now.
Posted on: 2014/8/28 5:12
269 Posts
One thing I don't know if ever has been addressed. Many years back wrapping the exhaust with asbestos tape to cut down on heat also seemed to cause the exhaust system to rust and wear out quicker than if nothing was used.
Admittedly this was simple steel exhaust pipe but wondering if the same issue persists?
Posted on: 2014/8/28 12:33
One of the techs at FlowMaster that I talked to said that wrap is bad because of heat buildup / cooldown cycling. Said it can cause them to crack after time.
Also said moisture / rust was NOT an issue.
If he WAS right, I can't imagine that OBX - being pretty heavy-duty Stainless hardware, is susceptible, as is lower $ stuff.
Don't know either way, for certain here.........
Posted on: 2014/8/29 1:15
I cut to the chase... I went with Corsa.
This was in 2002!
I have been impressed and satisfied with Corsa. They have a good warrantee and they back it up. I had the resonator section rot out (known problem with the first version) and they sent me new forward pipes and resonator to fix it, because I had welded it up.
The Corsa system works. It does reduce drone... at 80mph in 6th, the engine is no longer the noise maker; the tires are. And we have lots of loud concrete roads around here! Get on asphalt and it's totally quiet.
Expensive? YES. Does it work? DAMNED STRAIGHT!
Posted on: 2014/8/30 14:26
GRIS Re: Interior resonance / exhaust drone...
OKLAHOMA
7645 Posts
This was in 2002!
DARLING WIFE WAS COMPLAINING ABOUT THE DRONE IN THE '96. TOLD HER I COULD MAKE IT GO AWAY FOR ABOUT $1500. SHE DECLARED THAT IT WAS NOT SO BAD, AFTER ALL. THE BUMBLEBEE STILL DRONES :-)
Posted on: 2014/8/30 23:11
