324 user(s) are online (232 user(s) are browsing Forums)
tjpreul brakes won't fully release
When hot the front brakes release slow. After using the brakes my car will have a shutter and out slowly goes away. I was checking to make sure everything was tight and realized my front wheels would not turn freely. After they cooled it was fine. Then I pressed the brakes again and it was back, but not as bad. I tried this again when fully cooled and no issue.
Posted on: 2014/12/27 22:30
Matatk Re: brakes won't fully release
22803 Posts
I would check the hoses first. The inside can collapse.
Posted on: 2014/12/28 4:47
BrianCunningham Re: brakes won't fully release
check the caliper pin
I'd bleed it, may have something trapped in there
when's the last time you changed the fluid?
if all that fails, check the caliper pistons
Posted on: 2014/12/28 17:46
bogus Re: brakes won't fully release
you don't mention miles... also, what pads?
If you use cheap pads, they can stick to rotors when hot.
I agree with checking the pin and flushing out the fluid. It won't hurt...
It sounds to me like the entire brake system needs a once over.
Posted on: 2014/12/28 21:15
tjpreul Re: brakes won't fully release
They are ceramic pads with about 4kon them. The fluid was flushed at this time too. Today after a bit of driving I released the pressure with the bleeder and the wheel spun free, so that rules out the caliper or pads sticking. I pumped them back up and released the hose from the line and the wheel spun free again. I did this several times at both locations. So I am leaning towards the master cylinder.
Posted on: 2014/12/31 17:38
sounds like a dying master cylinder...
order one from RockAuto... tons cheaper than anywhere else.
Posted on: 2014/12/31 19:18
Could be the ABS
Posted on: 2014/12/31 21:30
CorvetteBob Re: brakes won't fully release
1409 Posts
I don't consider myself one of the smartguys around here, but it'd seem to me that it could either be the ABS, or my 1st thought the hoses. (These are questions as much as suggestions)If the master, wouldn't the pedal remain in a depressed position? Or would it refill from the reservoir and remain in the upwardmost position? If this were the case, is it possible the hoses are collapsing, allowing fluid to remain trapped and the master to be overfilled. Once the master would get overfilled and then pressed again, that could cause thes excess fluid in the master to be forced back past the piston, helping to cause a leakage/failure issue? If the ABS, would the system be energized and making some noise as if in operation?
Again, just questions as much as anything.
Posted on: 2015/1/3 18:42
22803 Posts
Are both front wheels sticking or one side? I guess I missed that in your original post.
Posted on: 2015/1/3 22:48
teebee Re: brakes won't fully release
12364 Posts
Could be the pistons are sticking in the cylinders, I've had that happen on a pickup.
Posted on: 2015/1/4 1:16
CentralCoaster Re: brakes won't fully release
Booster pushrod adjustment. Not sure how it can go out of adjustment, but it sounds like what's happening, and the fluid heating up causes the brakes to drag.
Remove the reservoir cap and have someone jab the pedal, you should see some fluid geyser up. If not, the reservoir port is blocked due to the pushrod being too long.
When you take the MC off, there's a little screw sticking out of the booster pushrod end that can be tightened in. You'll have to get a firm grip on the pushrod with some vicegrips, but protected with rubber or rags to avoid chewing up the shaft.
Posted on: 2015/1/4 21:39
I have a new master cylinder to install. The old one is full of crud. On the new reservoir it doesn't have a prime hose connection. I've tried to clean the old one, but cannot get to all of it. I'm thinking of getting a brass fitting and attach it to the new reservoir.
Posted on: 2015/2/21 23:29
all that separates the 2 circuits is an o-ring, which fails
Posted on: 2015/2/23 0:06
22803 Posts
I've heard of guys using rocks, pebbles, marbles, etc in various reservoirs and shaking them around with cleaner in them. Might that be possible?
Posted on: 2015/2/23 14:29
Schrade Re: brakes won't fully release
Lines collapsed? If so, bleeding is in vain...
Posted on: 2015/4/24 12:53
