180 user(s) are online (119 user(s) are browsing Forums)
BillH High Horsepower Build
We gots yer domed pistoms........but it seems to me the doms are pointes the wrong way,
[URL=http://s830.photobucket.com/user/Billhet/media/2015-02-28%2011-02-20_0002_zps6gsmsdam.jpg.html]Resized Image[/URL]
We gots yer roller rockers........well, the rockers roll on a piece of pipe.
[URL=http://s830.photobucket.com/user/Billhet/media/2015-03-06%2015-35-34_0006_zps379gez8m.jpg.html]Resized Image[/URL]
Posted on: 2015/3/7 14:34
BillH Re: High Horsepower Build
I put in an aftermarket crank scraper, not great but it will work for now.
The damn Scat Nodular Iron crank cost $899.00.
jpg  2015-03-05 12-45-12_0002.JPG (470.83 KB)
881_54fb0cc5ed7b3.jpg 1600X1200 px
Posted on: 2015/3/7 14:35
Degreeded in the cam, set it to 3 degrees retard to put the power band in the upper RPM.
jpg  2015-03-05 14-11-49_0004.JPG (561.01 KB)
881_54fb0d5bea5f4.jpg 1600X1200 px
Posted on: 2015/3/7 14:38
I'll be setting the max. valve lift today, pain in the ass because the rocker arm pads (that contact the valve stems) have to be ground at the front or rear to change the valve lift. This is done as part of the blueprint and to keep the lift below the max. legal limit.
jpg  2015-03-06 15-35-20_0005.JPG (598.02 KB)
881_54fb0e2e48636.jpg 1600X1200 px
Posted on: 2015/3/7 14:41
Hope to hit 106 horsepower but 108 would be nice.
Throw on the drysump pump and fuel pump and will get it in the car today.
Engine install is 45 minutes.
jpg  2015-02-16 14-29-24_0002.JPG (564.45 KB)
881_54fb0eddbf5bc.jpg 1600X1200 px
Posted on: 2015/3/7 14:44
pianoguy Re: High Horsepower Build
Lookin' good!
Posted on: 2015/3/7 15:39
Matatk Re: High Horsepower Build
22806 Posts
What happened to the other 4 cylinders?
Posted on: 2015/3/7 15:56
Don't need em to beat your Corvette.
Posted on: 2015/3/7 16:37
EngineDoctor Re: High Horsepower Build
La Habra Ca.
791 Posts
Nice build there Bill !! what no nitrous?
Posted on: 2015/3/7 20:33
Taint legal.
Posted on: 2015/3/8 1:48
bogus Re: High Horsepower Build
Ford Kent motor? wow... what's the redline on that sucker?
Posted on: 2015/3/8 2:02
I'll keep this driver at 6,800, pretty much above that, the power drops off.
The thing is that it will run a 1/2 hour race and never drop below 5,300.
Also, Ford began casting these blocks again, I can run over to Summit and pick one up.
Posted on: 2015/3/8 2:10
La Habra Ca.
791 Posts
Whats your calculated comp.ratio ?
Posted on: 2015/3/8 2:15
rklessdriver Re: High Horsepower Build
Allowed to do anything different with the Pistons or Rods?
Posted on: 2015/3/8 3:34
I'd have to look in the rule book again, it's basically a stock motor, not much you can do except deck the block, the rules don't allow anything else. And the engine rules are very close to what they were in the 1960's.
Probably around 9:1.
The big thing is to get the valve lift equal and within .001 of the legal max (.356 Int and .358 Ex.) and all of them equal.
There's a lot of guess work when you grind the rocker arm pads to change the lift. And every time you grind the rockers (even if it's just one) the rocker shaft hast to be pulled and dissembled.
I made up a 3 page build sheet for the blueprints quite a few years ago.
Posted on: 2015/3/8 3:54
Edited by BillH on 2015/3/8 4:30:20
Edited by BillH on 2015/3/8 4:33:07
Both are weight limited to stock weight. Balancing is allowed.
The cylinder squirt hole in the rods can be closed (which I do have done)
The Scat crank is much stronger than stock (should be for $899).
Forged pistons were approved 4 years ago but are identical dimensionally to the stock ones. 4 of them cost $520 plus $150 for oversized rings (so you can set the gaps).
Forged rods (Crower with ARP bolts) $550 are legal but identical to stock.
Flywheel lightened to 15.5 lbs.
Pertronix is legal, vacuum advance removed, points mounting plate locked (using a Sun machine).
2 barrel Weber (modified)
Porting & polishing legal if you stay under the legal port opening sizes.
Crank scrapers and smoothing the block bottom for oil return are legal. The oil pan holds less that 1/2 quart.
Using these better components has doubled the engine life to around 40 hours before a rebuild.
Posted on: 2015/3/8 4:14
Edited by BillH on 2015/3/8 4:31:07
La Habra Ca.
791 Posts
Sounds great & a lot of fun... Except for setting up your valve train geometry & lift......That takes time with shaft mounted rockers!
jpg  10982476_386791798170075_5242200907264409029_n (2).jpg (37.10 KB)
7794_54fbdbdeb9762.jpg 524X350 px
Posted on: 2015/3/8 5:10
Building's fun
Driving's even better
Posted on: 2015/3/8 14:58
La Habra Ca.
791 Posts
Cool Video..... Thanks for the share !!
Posted on: 2015/3/8 22:21
BrianCunningham Re: High Horsepower Build
Nice factory support
As far as I know there's only ONE builder that can make the most HP
at least that's the reason they're giving to allow Honda Fit engine
Posted on: 2015/3/8 22:46
Guess the other 5 or 6 guys that build winning motors are really worried.
That's hardly the reason for the Honda.
Posted on: 2015/3/9 1:15
Edited by BillH on 2015/3/9 2:02:25
Got the engine in and bolted up in 15 minutes.
Built all new hoses for the dry sump, probably fire it up tomorrow.
jpg  2015-03-08 14-49-28_0001.JPG (635.66 KB)
881_54fcffc68ee64.jpg 1600X1200 px
jpg  2015-03-08 14-49-38_0002.JPG (662.60 KB)
881_54fcffd032979.jpg 1600X1200 px
Posted on: 2015/3/9 2:05
La Habra Ca.
791 Posts
I'm not worried ;)
BTW..... It looks great Bill !
Posted on: 2015/3/9 2:06
EngineDoctor wrote:
I'm not worried ;)
Thanks David, these would be a pretty simple build for you or Wil.
We still have a bunch to do on the car before March 20.
And I have a fuel pump (in the fuel cell) to change on the Atlantic and rewire the harness. There's a lot of disassembly to get the pump out.
jpg  2014-05-10 13-22-25_0008.JPG (695.64 KB)
881_54fd05509061c.jpg 1600X1200 px
jpg  2014-05-10 09-50-44_0006.JPG (675.49 KB)
881_54fd055b027cc.jpg 1600X1200 px
Posted on: 2015/3/9 2:28
