179 user(s) are online (108 user(s) are browsing Forums)
Also known as the DIC.
NelsonV Seat Easy Entry = ON
Sunny Southern CA
245 Posts
I was sitting in the drive-thru waiting for my food last night, engine idling in drive, foot on the brake, when the seat began to move backward into the egress position.
It was kinda spooky. Anyone encounter this? I’ve never had this happen before nor heard of it either (but then I didn't really look).
NBV
[PS: First C5 tech post!]
Posted on: 2008/3/12 21:30
MAXXWRENCH Re: Seat Easy Entry = ON
COLORADO
118 Posts
OH YEAH...IT DID IT TO ME ONCE ABOUT 2 YEARS AGO...TURNED OUT IT WAS THE MEMORY SWITCH....I FOUGHT WITH FIGURING IT OUT FOR ALMOST A MONTH B4 JUST PUTTING IN A SWITCH & IT HAS BEEN FINE SINCE...ALTHOUGH IT COULD BE SOME KIND OF POWER ISSUE BECAUSE THE EASY EXIT OPTION DOESEN'T HAPPEN UNTIL IGNITION IS TURNED OFF OR THE BUTTON IS PRESSED...GOOD LUCK NELSON
[2ND C5 TECH POST LOL]
Posted on: 2008/3/13 1:59
ONE SHOT, ONE KILL, I WIN
Notorious Re: Seat Easy Entry = ON
Did you take all of your meds? Could you be having a flashback from your free-wheeling, psychoactive days of experimentation with controlled substances?
If you have any issues getting in and out of a C5, then it's time to start picking out your nursing home.....
Posted on: 2008/3/13 2:48
I hate sporks...
COLORADO
118 Posts
DID THE STEERING WHEEL MOVE TOO NELSON??
Posted on: 2008/3/13 3:39
NelsonV Re: Seat Easy Entry = ON
Sunny Southern CA
245 Posts
Nothing out of the ordinary happened except for the seat going back. And my hands were nowhere near any of the buttons or controls. I'm gonna check the codes tonight and see if anything got stored (SCM or BCM).
Thanks-
Nelson V.
Posted on: 2008/3/13 22:18
COLORADO
118 Posts
WHAT DID YA FIND NELSON? ANY CODES?
Posted on: 2008/3/14 4:19
Sunny Southern CA
245 Posts
No codes... and no recurrence of the problem.
Nelson V.
Posted on: 2008/3/14 4:32
COLORADO
118 Posts
GREMLINS...GOODLUCK
Posted on: 2008/3/14 5:28
brian Re: Seat Easy Entry = ON
193 Posts
my elbow has it them once.
Posted on: 2008/3/14 6:43
Sunny Southern CA
245 Posts
[I actually figured this out (finally) a few days ago. But I've been too busy/lazy/tired/forgetful to post an update.]
(The other day) I pulled the car into a stall, with my foot on the brake placed the shifter in park, then reached for the key to shut off the ignition. Just as I placed my fingers on the key (but before I could grasp and turn it) the seat started to move rearward toward egress.
Suspecting a bad ignition switch/key cylinder, I drove the car on an clear, open road and jiggled the key in the ignition and voila! The seat started to move back. And yes, this was while driving down the road (slowly)! Apparently, I have a bad ignition lock cylinder.
It's amazing there isn't some safety consideration to lockout the "auto-seat-egress-position" feature when the car is not in park/neutral (i.e. fail-safe). Fortunately, the seat doesn't move too rapidly, but it can be dangerous at the wrong place/time.
So, until I can replace the lock cylinder, it's now: Seat Easy Entry = OFF!
Nelson V.
Posted on: 2008/3/28 4:44
Alcee1 Re: Seat Easy Entry = ON
Los Angeles
277 Posts
Good job nelson.
Posted on: 2008/3/30 2:55
Travis93 Re: Seat Easy Entry = ON
Cleveland Ohio
205 Posts
Sounds to me like you have an issue that should be taken care of under a safety recall. Is there a procedure for average Joe to get a recall started?
Posted on: 2008/3/30 3:35
Josh Re: Seat Easy Entry = ON
Die.
That's pretty much the average guys only option for getting GM to recall something. Once enough of us die, they will issue the recall.
Posted on: 2008/3/30 3:59
CSS996 Re: Seat Easy Entry = ON
Mega Guru
Central PA
3644 Posts
This incredibly dangerous situation needs to be brought to the forefront of the car buying public immediately!!!
So I can afford a C5.
Posted on: 2008/5/23 14:51
Currently "Between Vettes".
Matatk Re: Seat Easy Entry = ON
22806 Posts
Haha...you and me both, brother.
Nelson glad you got it worked out. I've heard of the ignition switch causing all kinds of weird electrical problems.
Posted on: 2008/5/23 14:55
