175 user(s) are online (126 user(s) are browsing Forums)
pappyfreebird best outer winder door seal
1028 Posts
and are they much hassel to install ?mine are bout shot...any tips and how tos out there
ps n who has the best n fair priced ones
Posted on: 2008/4/21 12:04
xccter Re: best outer winder door seal
Downtown Annapolis, MD
461 Posts
I got mine from Eckler's about 3 years ago and they still appear new.
If I recall correctly, I had to drill out 2 rivets, 1 on each end to remove the old ones.
The new ones snap onto place with several clips, and I never replaces the rivets. No issues.
Posted on: 2008/4/21 13:46
´71 350/270 L48 Coupe
NCRS #48337
pappyfreebird Re: best outer winder door seal
1028 Posts
thank you sir!!! so never hadda taak anythin apart window inner door trim etc?
Posted on: 2008/4/21 14:39
461 Posts
Nope. Just lower the window all the way.
Posted on: 2008/4/21 15:42
NCRS #48337
1028 Posts
far out ,,,thanks alot,,i ll have ta order me some n git er done
Posted on: 2008/4/21 17:12
jhammons01 Re: best outer winder door seal
Pappy, I've been contemplating doing mine as well. Here is the situation. If you have the old ribbon style window regulators, they are going to break soon. Mine already broke.
I was thinking......I've already had to go in there once to replace a broken locking linkage for the door key. well this time, I want to take the door panel off, replace all of the following while I have the door apart....
1. Window Regulator
2. outer window seal
3. Lock button on the inside
4. Wiper switch
5. That strip along the top of the door panel
6. run a wire for the keyless entry system I just installed
You see? there is a list of crap that you could do.....I should have done it when it when I had the panel off the first time.....how would I know I needed to fix so many things AFTER I buttoned it all back together?
just my .02
Posted on: 2008/4/22 6:07
CasetheCorvetteman Re: best outer winder door seal
My 87 had the ribbon type regs and i never had an issue. Its WAY cheaper to replace an $8 ribbon than to install a used reg which i dont reckon is a better reg in the first place. Its like the 88-96 headlights, anyone who thinks they are a better design than the 84-87 units are playing with themselves.
If it aint broke, dont throw it away and waste money on stuff you dont need, especially when it could be perfectly reliable for many years yet.
Posted on: 2008/4/22 7:00
Midnight85 Re: best outer winder door seal
Streator, IL.
264 Posts
1. Window Regulator
4. Wiper switch
just my .02
Pappy, jhammons has given you some very good advice, the later model regulators are far superior to the ribbon style. All I can add is to get quality w/strip. GM, Corvette Rubber are two of the best. Stay away from Metro.
Posted on: 2008/4/22 12:05
1028 Posts
thanks fellas...my door has new reg ..least its way faster then passenger side
Posted on: 2008/4/22 12:12
CentralCoaster Re: best outer winder door seal
I think I got mine from Ecklers. Was great except the end rivets were too big, I used some I had laying around instead.
I don't know who produces it for Ecklers... probably the same guys make it for all the vette catalogs.
Posted on: 2008/4/22 14:54
1028 Posts
so they purty good to deal wid cc.. figure id call my order in n use a credit card..fast shipping?
Posted on: 2008/4/22 17:30
Matatk Re: best outer winder door seal
I just ordered my new outer door seals from Corvette Recycling (a vendor on CF) They have NOS outer seals for a good price. There's a discount code, "DoorSeal", so they are $60 total.
http://209.61.166.115/SearchResults.asp?Cat=90
Posted on: 2008/4/22 19:23
EcoVette Re: best outer winder door seal
Planet Earth
31 Posts
Awsome tip "doorseal" just ordered mine. Been looking for a while, thanks Matatk
Posted on: 2008/4/23 18:42
Its like DajaVu all over again
No, Ecklers sucks. They are overpriced and have worse customer support. Try other places first.
Posted on: 2008/4/23 19:47
NC Kid Re: best outer winder door seal
North Carolina
1671 Posts
Ecklers is the only place *I* prefer. I dealed with midamerica and they are jackasses. I ordered a interior screw kit, 2months went by and still not kit. They said sorry they just got them in when I called and said they would ship them out the next day. I paid for express delivery*more shipping*, cancelled the order and they sent me back the money for the kit but kept my shipping even though I never got the part. Ecklers is always fast and have never had to call them about any problems. Midamerica may give out free magazines but their prices are sky high. Regardless ecklers is more expensive than other places on certain items.
Posted on: 2008/4/23 20:19
1028 Posts
well ive emailed jason at vette2vette n he seems cool,,,did git my inner rear winder trim from them n fast shippin fer sure...he said 50 fer gm per side and 60 fer aftermarkets fer pr.n 30 fer set of the winder blocks anti rattle thingies (driverside is wiggely n 12 fer shippin ,,,so i prolly go that route
Posted on: 2008/4/24 13:21
1028 Posts
has anybody ever made or remade the anti window rattle blocks??? like just used rubber or foam etc over origanal brackets??? hey 30 bucks is 30 bucks n some of this stuff a handy fool maybe could duplicate
Posted on: 2008/4/24 15:25
