116 user(s) are online (60 user(s) are browsing Forums)
mojo92 SLP air intake ????
Tifton,Ga.
58 Posts
Can I use the SLP triple air intake made for 92-96 on my 91?
Posted on: 2008/6/15 20:27
Mekanic Re: SLP air intake ????
Tampa Bay Florida
827 Posts
I don't believe so, the radiator shroud is on a different angle
Posted on: 2008/6/15 22:21
~Rich
Polo LT4
bogus Re: SLP air intake ????
Is it? I thought the new radiator stack came into production in 1991. That is the new look rad, at an angle, with the surge tank off passengers side firewall.
Posted on: 2008/6/16 0:36
Jeffvette Re: SLP air intake ????
New rad stack design came out in 90.
You should be able to use it no problem as your intake duct has the huge oval in it.
Posted on: 2008/6/16 8:25
CasetheCorvetteman Re: SLP air intake ????
No its not.
It came into production in 89 for the 90 model.
Yep, 90 it is (or was) all the same since then apart from the duct work.
Posted on: 2008/6/16 9:29
CentralCoaster Re: SLP air intake ????
The better question, is....
why would you want to use it?
Posted on: 2008/6/16 16:50
SpectatorRacing Re: SLP air intake ????
And do you want to buy a camberbrace?
Posted on: 2008/6/16 19:39
Why not?
Posted on: 2008/6/16 20:21
CasetheCorvetteman wrote:
Why not?
Cuz it's expensive and provides no cold-air, and uses crappy K&N or similar filters with the same filter area as stock.
Someone may disagree, but when I see those type of parts on a car, I see a sucker behind the wheel.
Posted on: 2008/6/16 21:38
So do i, but its not going to hamper performance, some people might like the look, i personally dont, but cant see any good reason not to use it if thats what he likes. Itll flow alot more air than his engine can ever take in.
Posted on: 2008/6/16 22:27
biggrizzly Re: SLP air intake ????
All do respect for opinions, but I installed the triple cone air inlet simply because when I saw one on another Vette I liked the appearance over the factory looking air-box. If one waits long enough, you can pick one up like I did on one of the forum classified lists, or "fleaBay". I got mine shipped for around $75 several years back. As far as surface area, I'm sure it has been beat to death, but I think I could easily measure and try to calculate the area based on the folds, but I would suspect my cones have at least as much surface area and probably more than the stock shaped K&N sitting in a box on my shelf. I really think it is solely an aesthetic point of view and if someone wants to spend the money on it well, who are we to say anything.
I think we should have a good discussion of the benefits of airfoils, wings, shift knobs, etc.
I'm a Sucker! LOL :me2:
Posted on: 2008/6/16 22:39
biggrizzly wrote:
I'm sure it has been beat to death, but I think I could easily measure and try to calculate the area based on the folds, but I would suspect my cones have at least as much surface area and probably more than the stock shaped K&N ...
I wouldn't bother, it's already been measured out before.
I guess I just wanted to get the thread starter's attention and make sure he checks out the feedback beyond SLP's catalog and knows what to expect for his money.
Posted on: 2008/6/16 23:27
1Fast04Vert Re: SLP air intake ????
Well said!! Exactly why and how I bought mine. HP gains were never the issue, I like the look and have no regrets about my decision. I don't appreciate being called a sucker by someone with a limited and apparently closed perspective.
However, I will consider the source and ignore it.
Posted on: 2008/6/16 23:31
Tampa Bay Florida
827 Posts
I got mine cause I liked the looks, I liked the added sound, and on back to back dyno runs they have showed a 7whp gain over stock on an LT1.
I got mine for 125 shipped on brand x about a year ago with real K&N's on it
Posted on: 2008/6/16 23:36
~Rich
Polo LT4
But I like suckers. Resized Image
If you're putting a part on your car for looks, then its all subjective and none of that applies anyways.
Ive never seen one with cone shaped filters on it, all the triples ive seen have cylindrical filters.
Posted on: 2008/6/17 0:26
pianoguy Re: SLP air intake ????
I like mine, but I'd never have paid $300 for it. I bought the body used for $60 on fleabay, and got new filters for around $72.
Posted on: 2008/6/17 1:02
Case,
You're partially correct. Mine are cylindrical, but have a slight taper.
Posted on: 2008/6/17 2:00
eh. an engine will only pump what it can pump. a better filter won't make a lick of difference.
I did K&N cause it's not gonna fill up the landfill.
Posted on: 2008/6/17 5:09
