81c3 | Ruby is almost out of the ER | ||
Wow.....I have really done a crapload of work to this ole girl! I'm not going to list the in-betweens......ie:cleaning,painting, tightening & lubing parts etc., but heres the shortlist.
New harmonic balancer New Opti-spark New plugs New ignition wires New water pump New front brake rotors New front brake pads New hatch weatherstrip New B pillar weatherstrip New driver door weatherstrip New shift plate surround Good used gear indicator window Good used driver A/C vent Good used driver door panel Good used steering wheel Good used right side speaker grill Paid to have car buffed & polished Remove stupid Viper alarm Repair console lid Connect the 6 cd changer properly (run wires under console) but hey...the power antenna worked great!!! I have really learned allot on the weatherstrip work & interior work. This is the first time on any C4 that I had to get into these areas. If not for the cost of the weatherstrip, the job was actually fairly easy. If anyone needs help, post up & I'll try my best to give pointers. |
Posted on: 2008/6/19 22:18
Matatk | Re: Ruby is almost out of the ER | ||
It's like a whole new car! Nice work.
Matthew |
Posted on: 2008/6/19 22:39
pianoguy | Re: Ruby is almost out of the ER | ||
You've been busy! I have a box of weatherstripping sitting here, so if you have some pointers, I'm all ears ;-)
Posted on: 2008/6/19 22:56
CSS996 | Re: Ruby is almost out of the ER | ||
Mega Guru
Nice! I was gonna rive you a ring tonight around 7 to see how your restoration project was going!
Might still bug ya, even with this update. ;) |
Posted on: 2008/6/19 22:57
Currently "Between Vettes". |
81c3 | Re: Ruby is almost out of the ER | ||
I'm actually still waiting for my water pump to arrive....but thats the last engine component before the initial start-up. Actually, I did start the engine w/o the water pump on to check the Opt-Spark operation & plug wire placement....thumbs up!!
No prob Chris! Oh yea, I settled a deal with a forum member (CF) for my mismatched RR wheel. |
Posted on: 2008/6/20 0:39
CentralCoaster | Re: Ruby is almost out of the ER | ||
It's gonna feel like a new car. Now, to make yourself feel even better, call the local GM dealer and get an estimate for all the work you just did.
BTW, I'm not fond of GM weatherstripping. I have a 6-month old A-piller piece that's already starting to fall apart. |
Posted on: 2008/6/20 0:40
Patience & cleanliness are the keys. You need to get ALL the old weatherstrip & adhesive out of the channels and surfaces you removed them from. I used wire brushes, sandpaper, scotchbrite pads little screwdrivers, pics, wood chisels...and anything else that would fit into the little channels to scrape out the junk. Once 99% of the junk was removed, I used 3M adhesive remover and micrfiber towels to get the channels clean. I assembled everything slowly with 3M black adhesive. I used my thumbs and an old kithen rounded edge knife to push the new weatherstrip into place. |
Posted on: 2008/6/20 0:46
That's exactly why I ordered mine from Willcox - I figured if the OEM stuff rotted so easily, why would I want to buy it again? BTW, somebody recommended Leslie's Pool & Spa Lube as a weatherstripping protectant, so I also bought a tube of that for around $6. |
Posted on: 2008/6/20 0:52
Jeffvette | Re: Ruby is almost out of the ER | ||
Wilcox and many of the other brands are not much better. The rubber is so hard it doesn't seal, or it's to short in certain places or the push pins are located incorrectly. Whereas the GM stuff fits perfect with no excuses and it seals. Pool and spa lube works, as does dielctic grease. Just make sure you wipe it down so it doesn't smear all over the windows. |
Posted on: 2008/6/20 1:32
bogus | Re: Ruby is almost out of the ER | ||
awesome!!!!
Posted on: 2008/6/21 17:55
Randyj75 | Re: Ruby is almost out of the ER | ||
What brand of w/s did you use? Randy |
Posted on: 2008/6/25 6:22
TommyT-Bone | Re: Ruby is almost out of the ER | ||
You've been very busy.
I have the weatherstripping project on the horizon. Where is the best place to pick up the GM product? |
Posted on: 2008/6/25 12:54
I used GM. Its NOT cheap! Get it from Jeffvette (above)....he's the local "dealer" |
Posted on: 2008/6/25 13:12
Mega Guru
I hope to tackle the hatch strip soon. Mine is pretty much non-existent at the corners...
Good to know I've got a pro with experience up the street! |
Posted on: 2008/6/25 14:37
Dont know if doing just one makes me a pro...but I will help with yours when your ready. Its the second easiest one, doors being the easiest. |
Posted on: 2008/6/25 19:32
