140 user(s) are online (91 user(s) are browsing Forums)
Transverse Leaf Spring
81c3 Ruby is almost out of the ER
Colorado
143 Posts
Wow.....I have really done a crapload of work to this ole girl! I'm not going to list the in-betweens......ie:cleaning,painting, tightening & lubing parts etc., but heres the shortlist.
New harmonic balancer
New Opti-spark
New plugs
New ignition wires
New water pump
New front brake rotors
New front brake pads
New hatch weatherstrip
New B pillar weatherstrip
New driver door weatherstrip
New shift plate surround
Good used gear indicator window
Good used driver A/C vent
Good used driver door panel
Good used steering wheel
Good used right side speaker grill
Paid to have car buffed & polished
Remove stupid Viper alarm
Repair console lid
Connect the 6 cd changer properly (run wires under console)
but hey...the power antenna worked great!!!
I have really learned allot on the weatherstrip work & interior work. This is the first time on any C4 that I had to get into these areas. If not for the cost of the weatherstrip, the job was actually fairly easy. If anyone needs help, post up & I'll try my best to give pointers.
Posted on: 2008/6/19 22:18
Matatk Re: Ruby is almost out of the ER
It's like a whole new car! Nice work.
Posted on: 2008/6/19 22:39
pianoguy Re: Ruby is almost out of the ER
You've been busy! I have a box of weatherstripping sitting here, so if you have some pointers, I'm all ears ;-)
Posted on: 2008/6/19 22:56
CSS996 Re: Ruby is almost out of the ER
Mega Guru
Central PA
3644 Posts
Nice! I was gonna rive you a ring tonight around 7 to see how your restoration project was going!
Might still bug ya, even with this update. ;)
Posted on: 2008/6/19 22:57
Currently "Between Vettes".
81c3 Re: Ruby is almost out of the ER
Colorado
143 Posts
I'm actually still waiting for my water pump to arrive....but thats the last engine component before the initial start-up. Actually, I did start the engine w/o the water pump on to check the Opt-Spark operation & plug wire placement....thumbs up!!
No prob Chris!
Oh yea, I settled a deal with a forum member (CF) for my mismatched RR wheel.
Posted on: 2008/6/20 0:39
CentralCoaster Re: Ruby is almost out of the ER
It's gonna feel like a new car. Now, to make yourself feel even better, call the local GM dealer and get an estimate for all the work you just did.
BTW, I'm not fond of GM weatherstripping. I have a 6-month old A-piller piece that's already starting to fall apart.
Posted on: 2008/6/20 0:40
Colorado
143 Posts
Patience & cleanliness are the keys. You need to get ALL the old weatherstrip & adhesive out of the channels and surfaces you removed them from. I used wire brushes, sandpaper, scotchbrite pads little screwdrivers, pics, wood chisels...and anything else that would fit into the little channels to scrape out the junk.
Once 99% of the junk was removed, I used 3M adhesive remover and micrfiber towels to get the channels clean.
I assembled everything slowly with 3M black adhesive. I used my thumbs and an old kithen rounded edge knife to push the new weatherstrip into place.
Posted on: 2008/6/20 0:46
That's exactly why I ordered mine from Willcox - I figured if the OEM stuff rotted so easily, why would I want to buy it again?
BTW, somebody recommended Leslie's Pool & Spa Lube as a weatherstripping protectant, so I also bought a tube of that for around $6.
Posted on: 2008/6/20 0:52
Jeffvette Re: Ruby is almost out of the ER
Wilcox and many of the other brands are not much better. The rubber is so hard it doesn't seal, or it's to short in certain places or the push pins are located incorrectly. Whereas the GM stuff fits perfect with no excuses and it seals.
Pool and spa lube works, as does dielctic grease. Just make sure you wipe it down so it doesn't smear all over the windows.
Posted on: 2008/6/20 1:32
bogus Re: Ruby is almost out of the ER
awesome!!!!
Posted on: 2008/6/21 17:55
Randyj75 Re: Ruby is almost out of the ER
MD
129 Posts
What brand of w/s did you use?
Randy
Posted on: 2008/6/25 6:22
TommyT-Bone Re: Ruby is almost out of the ER
33766 Posts
You've been very busy.
I have the weatherstripping project on the horizon. Where is the best place to pick up the GM product?
Posted on: 2008/6/25 12:54
Colorado
143 Posts
I used GM. Its NOT cheap! Get it from Jeffvette (above)....he's the local "dealer"
Posted on: 2008/6/25 13:12
Mega Guru
Central PA
3644 Posts
I hope to tackle the hatch strip soon. Mine is pretty much non-existent at the corners...
Good to know I've got a pro with experience up the street!
Posted on: 2008/6/25 14:37
Colorado
143 Posts
Dont know if doing just one makes me a pro...but I will help with yours when your ready. Its the second easiest one, doors being the easiest.
Posted on: 2008/6/25 19:32
