biggrizzly | Last Call for header choices - I'm pulling the trigger this weekend! | ||
OK - I finally got the money to order my LT headers.
I have pretty much decided on the EM LT from Merle. but the Stainless Works headers are enticing too, and about the same price. I am planning on buying the Long Tube header, connecting pipes with Random Tech cats and then plumbing this into my existing LT1 center resonator and out through straight pipes. I have no mufflers since I cut them off five years ago. Later if I don't like the sound I can put another kind of Cat-back on it. Last chance to give me advice! Good, bad, or indifferent I don't care - hit me with it. Cheers |
Posted on: 2008/7/3 3:09
Matatk | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
Sounds good! Do you have a cat on there now? The LTs will make it louder, but the cats should cut down on it a little bit. I figure if you already cut off the mufflers, you won't mind it loud.
Can't wait for pics. Matthew |
Posted on: 2008/7/3 3:11
pianoguy | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
I am happy with my SW, particularly the stainless aspect. But I've heard plenty of good things about the EM headers, and with their ceramic coating, I'm sure they'll look nicer (I didn't get any coating on mine).
Posted on: 2008/7/3 3:17
biggrizzly | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
Yes - I have been running around with the factory LT-1 exhaust system sans the mufflers for five or so years. Quote:
I havn't minded the sound. Matter of fact I hope it will be more aggressive with the headers and bullet cats. |
Posted on: 2008/7/3 3:25
Mekanic | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
If you can afford SW I would go with them
Posted on: 2008/7/3 3:43
You aint gonna get away with that! Why |
Posted on: 2008/7/3 4:12
-=Jeff=- | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
I have heard goods things of both Stainless works and Melrose headers.. Melrose also sells a system and all you need to add to it are mufflers.
Posted on: 2008/7/3 13:23
Lichen | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
I vote for the EM's. I have them with their hi-flow cats and a 3" B&B. They are a very high quality product.
Posted on: 2008/7/3 15:04
JonnyAngle | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
I like Hookers. THey look very nice and have a nice growl. I cannot say how they sound with cats, but I have true duals and 2 borla mufflers for tips.
Posted on: 2008/7/3 18:38
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
You may want to search around and compare notes on install issues, too - each has its own peculiarities, I'm sure. I've seen mention of frame grinding, switching around motor mounts, etc. with various brands. Here are the SW instructions:
http://www.stainlessworks.net/cart/in ... LATION%20INSTRUCTIONS.doc and a thread that illustrates a SW install: http://forums.corvetteforum.com/showt ... ess+Works+headers+install My install went pretty much as the one in the thread. I also kept my AIR pump connections - I wound up having to cut the driver's side AIR pipe a little shorter and re-flare it, as it sat up higher with the headers and interfered with my ASR box. I also had gasket problems - I originally tried the Mr. Gasket copper gaskets, but they leaked like a sieve, so I swapped the stock ones back in - no problems after that. PS - I also had to pull a coolant sensor on the passenger side in order to snake the header up there. Be prepared to lose some coolant ;-) |
Posted on: 2008/7/4 0:46
okay lol. I'll elaborate
Stainless > Other lol Any header, coated, uncoated, or painted, if its not stainless WILL rust eventually. Stainless also helps even more in retaining heat. Also the install on the SW seems better than most, I could say the same for EM as well. But if I could afford the SW, thats what I would go with |
Posted on: 2008/7/4 1:13
Notorious | Re: Last Call for header choices - I'm pulling the trigger this weekend! | ||
I originally tried the Mr. Gasket copper gaskets, but they leaked like a sieve, so I swapped the stock ones back in - no problems after that. That's odd. I ran SW headers and Mr. Gasket coppers for 2 or 3 years with no problems. I even had them off and on more than once, reusing the gaskets with no problems. I'm still using the same gaskets after switching back to my DRM headers. |
Posted on: 2008/7/4 1:34
