240 user(s) are online (99 user(s) are browsing Forums)
biggrizzly Last Call for header choices - I'm pulling the trigger this weekend!
OK - I finally got the money to order my LT headers.
I have pretty much decided on the EM LT from Merle.
but the Stainless Works headers are enticing too, and about the same price.
I am planning on buying the Long Tube header, connecting pipes with Random Tech cats and then plumbing this into my existing LT1 center resonator and out through straight pipes. I have no mufflers since I cut them off five years ago. Later if I don't like the sound I can put another kind of Cat-back on it.
Last chance to give me advice! Good, bad, or indifferent I don't care - hit me with it.
Cheers
Posted on: 2008/7/3 3:09
Matatk Re: Last Call for header choices - I'm pulling the trigger this weekend!
22812 Posts
Sounds good! Do you have a cat on there now? The LTs will make it louder, but the cats should cut down on it a little bit. I figure if you already cut off the mufflers, you won't mind it loud.
Can't wait for pics.
Posted on: 2008/7/3 3:11
pianoguy Re: Last Call for header choices - I'm pulling the trigger this weekend!
I am happy with my SW, particularly the stainless aspect. But I've heard plenty of good things about the EM headers, and with their ceramic coating, I'm sure they'll look nicer (I didn't get any coating on mine).
Posted on: 2008/7/3 3:17
biggrizzly Re: Last Call for header choices - I'm pulling the trigger this weekend!
Yes - I have been running around with the factory LT-1 exhaust system sans the mufflers for five or so years.
I havn't minded the sound. Matter of fact I hope it will be more aggressive with the headers and bullet cats.
Posted on: 2008/7/3 3:25
Mekanic Re: Last Call for header choices - I'm pulling the trigger this weekend!
Tampa Bay Florida
827 Posts
If you can afford SW I would go with them
Posted on: 2008/7/3 3:43
~Rich
Polo LT4
You aint gonna get away with that! Why
Posted on: 2008/7/3 4:12
-=Jeff=- Re: Last Call for header choices - I'm pulling the trigger this weekend!
Bartlett, IL
573 Posts
I have heard goods things of both Stainless works and Melrose headers.. Melrose also sells a system and all you need to add to it are mufflers.
Posted on: 2008/7/3 13:23
-=Jeff=-
1990 Corvette ZR-1 #1051
Lichen Re: Last Call for header choices - I'm pulling the trigger this weekend!
Scottsdale, Arizona
166 Posts
I vote for the EM's. I have them with their hi-flow cats and a 3" B&B. They are a very high quality product.
Posted on: 2008/7/3 15:04
JonnyAngle Re: Last Call for header choices - I'm pulling the trigger this weekend!
Minneapolis, MN
151 Posts
I like Hookers. THey look very nice and have a nice growl. I cannot say how they sound with cats, but I have true duals and 2 borla mufflers for tips.
Posted on: 2008/7/3 18:38
You may want to search around and compare notes on install issues, too - each has its own peculiarities, I'm sure. I've seen mention of frame grinding, switching around motor mounts, etc. with various brands. Here are the SW instructions:
http://www.stainlessworks.net/cart/in ... LATION%20INSTRUCTIONS.doc
and a thread that illustrates a SW install:
http://forums.corvetteforum.com/showt ... ess+Works+headers+install
My install went pretty much as the one in the thread. I also kept my AIR pump connections - I wound up having to cut the driver's side AIR pipe a little shorter and re-flare it, as it sat up higher with the headers and interfered with my ASR box. I also had gasket problems - I originally tried the Mr. Gasket copper gaskets, but they leaked like a sieve, so I swapped the stock ones back in - no problems after that.
PS - I also had to pull a coolant sensor on the passenger side in order to snake the header up there. Be prepared to lose some coolant ;-)
Posted on: 2008/7/4 0:46
Tampa Bay Florida
827 Posts
okay lol. I'll elaborate
Stainless > Other
lol
Any header, coated, uncoated, or painted, if its not stainless WILL rust eventually.
Stainless also helps even more in retaining heat.
Also the install on the SW seems better than most, I could say the same for EM as well.
But if I could afford the SW, thats what I would go with
Posted on: 2008/7/4 1:13
~Rich
Polo LT4
Notorious Re: Last Call for header choices - I'm pulling the trigger this weekend!
That's odd. I ran SW headers and Mr. Gasket coppers for 2 or 3 years with no problems. I even had them off and on more than once, reusing the gaskets with no problems. I'm still using the same gaskets after switching back to my DRM headers.
Posted on: 2008/7/4 1:34
