Browsing this Thread:
2 Anonymous Users
klkordzi | Re: Camber-brace and Roadracing | ||
While looking for information on the AFSB Targa Bar I came across this article. Very interesting read
http://www.vetteweb.com/tech/0209vet_ ... rt_bar_install/index.html |
Posted on: 2008/7/16 0:33
BrianCunningham | Re: Camber-brace and Roadracing | ||
It's IMMEDIATELY apparent that having the roof ON in those videos stiffens that car up, you don't have to go 10sec into the videos to see that. But my best times are with it OFF.
Measuring chassis stiffness has nothing to do with the type of event your running, the car's not even moving when you do it. But if you want to get into that arguement we can go ahead and start another thread. If you want data on whether having the roof ON or OFF helps or hurts at road race event, then your going to have to find an event that lets you run w/o the roof on. But I really don't think your going to find it. I've tried different camera mounting positions on the car. Take a look at my other videos. I really need a Wide angle lens. If you got data, please be my guest and post it. I figured I'd get the ball rolling. |
Posted on: 2008/7/16 3:39
CentralCoaster | Re: Camber-brace and Roadracing | ||
Thank you! |
Posted on: 2008/7/16 7:13
your welcome!
Posted on: 2008/7/16 7:38
pianoguy | Re: Camber-brace and Roadracing | ||
Is this always true, or did running your first sets with the top on influence the outcome? What I mean is, you ran the course a number of times before taking the top off, so could familiarity explain the better times? |
Posted on: 2008/7/16 10:32
Yes, that's what I'm thinking as well.
That and I can see eaiser with the roof off, otherwise my helmet hits the roof when I'm trying to look ahead. I was waiting for someone to ask the all important question: WHY? |
Posted on: 2008/7/16 19:15
NC Kid | Re: Camber-brace and Roadracing | ||
Posted on: 2008/7/16 19:42
SpectatorRacing | Re: Camber-brace and Roadracing | ||
Come on, Brian, you help a lot of people with good information, don't turn this into a life lesson. I am also interested in the results, and am also an engineer, but 1) I can't watch youtube where I do much of my posting 2) even if I could, I wouldn't want to watch videos when I could simply read your results. I would have preferred a post that said "In my experience I ran faster lap times without it. Check out the chassis flex evident in this video clip." Then it's up to me to spend 10 minutes on a video or not. Quickly getting to the point is also part of being a good engineer. Not reprocessing reams of data that someone else has already processed to get the same result. |
Posted on: 2008/7/17 19:28
aka Scaryfast |
Ok, I got off my lazy ass and went through the data. I stuck a post-it on my screen and marked the total vertical deflection of the corner of dash, since it was easy to see in both vids and would show twisting of the front end. No discernable difference. I did notice it shakes mostly on right hand turns and over bumps, and is very stable on left handers. My conclusion is your camera setup is useless for trying to measure chassis deflection. |
Posted on: 2008/7/17 20:59
Anyone interested in reading the article?
Posted on: 2008/7/18 0:51
Yeah, I read through that, and it seems to agree with the observations of others. But it's merely anecdotal, and seems very vendor-biased to me.
I thought this thread was about the Camberbrace, sorry for dragging it out off topic. |
Posted on: 2008/7/18 1:43
I didn't want to post my conclusions because I actually wanted to see what others thought.
Thanks for taking the time to go through it. |
Posted on: 2008/7/18 3:51
The camber brace really made my car feel better in corners... |
Posted on: 2008/7/18 13:58
aka Scaryfast |
Cool! It really helped with my bowel movements. They are much more rigid and predictable now when I get on the gas.
Posted on: 2008/7/18 18:59
Glad I could help.
That's the last thing you want to worry about while driving around the track, especially with a tight racing harness. |
Posted on: 2008/7/18 19:09
Steve40th | Re: Camber-brace and Roadracing | ||
Was there any data ever done on this camber brace? I havent read the hole thread. Sorry
Posted on: 2008/8/1 0:49
Ko'u ohana aia ku'a ikaika |
Nope just bitching and moaning.
Posted on: 2008/8/1 3:51
Aardwolf | Re: Camber-brace and Roadracing | ||
I was looking at a C4 with a camber brace earlier this week at a track event. The owner said he noticed less inside wear on the front tires and thought it was helpful for that. He wouldn't say the brace helped his lap times.
My car was getting lots of wear on the front inside edge at my last event. Then in the afternoon without an instructor in the car, the accelerated wear went away. I had my father sit in the car while I had a level on the tire, the bubble moved quite a bit. Could a camber brace make your car less sensitive to weight changes like that? |
Posted on: 2008/8/16 15:54
BillH | Re: Camber-brace and Roadracing | ||
Probably not. Cornering forces will be much higher than the force of someone in the seat.
Posted on: 2008/8/17 14:49
