288 user(s) are online (206 user(s) are browsing Forums)
daddue11 Van motor to Corvette.
Mountain View, Southern Mo.,
131 Posts
Hello folks,
I have a 1996 g20 sportvan with a 350 c.i.d engine with just over 28,000 orogional miles,
The question that I have is-Would the engine and or tranny fom the van fit in my 84 Corvette? and what would the h.p. difference be between the Corvette motor and the van motor?
If it is a can do situation than I'll just take out the motor and tranny for a spare for when the Vette needs a new one and sale the van body to a friend that's been wanting it.
Thank you. daddue.
Posted on: 2008/10/2 16:42
Aint no amount of gold in any ole mine,that would be enough to take away this car of mine.-beach boys
red_johnny Re: Van motor to Corvette.
I dunno if it will work. I know that from certain years might have worked but the internals are differant. I am sure the heads are differant. I think 82-92 had the same blocks for chevy. Anyone got a website that has a parts list for blocks with applications?
Posted on: 2008/10/2 18:59
bogus Re: Van motor to Corvette.
The blocks changed in 1987 when they went to a 1 piece rear main. This would effect the clutch, if it's a manual.
The heads could be different, especially if they are Vortec's.
Otherwise, plug and play.
Posted on: 2008/10/2 19:25
daddue11 Re: Van motor to Corvette.
131 Posts
Both the van and Vette are automatics.
Would the tranny from the van fit underneath the Vette also?
Posted on: 2008/10/2 20:13
1Fast04Vert Re: Van motor to Corvette.
Is it a 4L60E? If so it is a direct fit, but your would need the PCM from the van to control it. I see a lot of wiring problems here (sensors to computer, gauges, etc). I would sell the van engine/trans and use the $$ to mod your stock engine.
Posted on: 2008/10/3 2:41
131 Posts
That sounds about right to me.
I really don't want to keep it for years and finally find out that it needs a bushle load of modifying even before the install.
I'll just sell the van and modify the Vette, a body makeover and paint job would be nice for the spring.
Thanks everybody,I probably would have had a headache on my hands.
Posted on: 2008/10/3 4:30
CentralCoaster Re: Van motor to Corvette.
And you'd have to swap the tail housing too.
Posted on: 2008/10/3 7:33
PeteK Re: Van motor to Corvette.
And cut the output shaft 11/16 of an inch.
Posted on: 2008/10/4 22:39
131 Posts
Man!!! I'm really glad I asked this question,I probibly would have pulled this motor and saved it thinking "It's a 350 cid and tranny,it'll fit".
Thanks my friends for the info. It really helped.
Posted on: 2008/12/6 4:26
Sawzall!
Posted on: 2008/12/6 4:27
jsup Re: Van motor to Corvette.
1778 Posts
Sawzall!
And a real steady hand?
Posted on: 2008/12/6 4:33
pr0zac Re: Van motor to Corvette.
i would hold on to that motor. would be a basis for a sweet build. you could just reuse your stock transmission in your vette. it wouldn't be hard to make it work.
Posted on: 2008/12/7 17:15
