rklessdriver | Carbon Fiber Rocker Cover review | ||
I've had a million people asking me about these rocker covers ever since I let the first pics of my new LTX engine slip out a few months ago.
Well here they are in the car. [IMG]http://i50.photobucket.com/albums/f303/rklessdriver/Corvette/DSC00841.jpg[/IMG] [IMG]http://i50.photobucket.com/albums/f303/rklessdriver/Corvette/DSC00842.jpg[/IMG] On the engine stand. [IMG]http://i50.photobucket.com/albums/f303/rklessdriver/Corvette/100_0340.jpg[/IMG] [IMG]http://i50.photobucket.com/albums/f303/rklessdriver/Corvette/100_0341.jpg[/IMG] So after a full 2 weeks of driving the car around, my opinion of them can be described in only 2 words. THEY SUCK. They looked nice when new but they quickly spread out and started leaking. They will not stop leaking. They have bowed in at the top and the rails have spread out so far they will no longer hold the gasket in place on the head. The carbon weave is bubbling and seperating from the clear resin. I could go on and on about how bad they suck... Do yourselves a favor and save the $370.00 for some nice rocker covers made from some type of metal. To replace these I bougt a set of the premiter bolt (18 degree style) Moroso fabricated alum valve covers with 1/4" billet rails and am in the process of chopping the front corner of the drivers side one up for the required dreaded LTX Alt clearance. Such a shame to cover up all this beauty... [IMG]http://i50.photobucket.com/albums/f303/rklessdriver/Corvette/DSC00849.jpg[/IMG] I will post up some new pics when I've got them on the car. Will |
Posted on: 2008/10/22 19:01
BrianCunningham | Re: Carbon Fiber Rocker Cover review | ||
WOW good to know.
I bought some chrome covers for my build, I might stick with the stockers though. |
Posted on: 2008/10/22 19:22
biggrizzly | Re: Carbon Fiber Rocker Cover review | ||
That's why I decided finally to stick with the factory composite covers. I broke the tabs off to clear my rockers and I have had no problems with them at all.
Posted on: 2008/10/22 19:32
bogus | Re: Carbon Fiber Rocker Cover review | ||
damn. That's a poor product.
The quality of carbon fiber depends on the epoxy... it sounds like they used cheap junk. How sad. |
Posted on: 2008/10/22 21:34
CSS996 | Re: Carbon Fiber Rocker Cover review | ||
Mega Guru
How EXPENSIVE!!! Jeebus! I'd be super pissed. Thanks for the heads up!
Posted on: 2008/10/23 0:05
Currently "Between Vettes". |
Matatk | Re: Carbon Fiber Rocker Cover review | ||
Sounds like a few broads I knew.... Sorry to hear about your troubles. Matthew |
Posted on: 2008/10/23 0:11
pianoguy | Re: Carbon Fiber Rocker Cover review | ||
Hahahaha! That is a bummer that they didn't hold up. |
Posted on: 2008/10/23 0:18
AKS_Racing | Re: Carbon Fiber Rocker Cover review | ||
I had really considered those covers as a replacement to the factory panted covers. I too am running shaft rockers, but run spacers to get the factory covers high enough of the head to work. Thanks for the heads up. Also, your intake looks remarkably similar to mine. [IMG]http://i55.photobucket.com/albums/g151/AKS_Racing/100_0118.jpg[/IMG] I hope whoever built your intake used something besides 10/28 screws to hold the rails to the intake elbow. I recently wrote the horror episode on CF about the hackjob that I was sold. But mine looks nice and works very well after lots of rework. [IMG]http://i55.photobucket.com/albums/g151/AKS_Racing/100_0928.jpg[/IMG] Aaron |
Posted on: 2008/10/23 2:27
CentralCoaster | Re: Carbon Fiber Rocker Cover review | ||
The hot oil must be breaking down the epoxy. CF doesn't do to well with harsh chemicals.
Posted on: 2008/10/23 3:25
rklessdriver | Re: Carbon Fiber Rocker Cover review | ||
Arron,
My fuel rails are held on with 1/4" stainless allen head cap screws. I've got 42psi idling and haven't noticed any flex in the tubing pieces he welded to the intake and mounted the fuel rail to. Who built yours? Mine needed a lot of re-work as well... Will |
Posted on: 2008/10/23 21:20
Will, With regard to who built my intake unit originally, I prefer not to publicly post that up, as he is usually lurking (actually people call him by that name) in the background. The intake is definitely either a JB "knockoff", or a knockoff of someone else's work that JB copies as well. I do not know. My fuel rails were held in place with 10/28 tapered head screws that were ~ 1 3/4" long (through the rail and the sleeves) and screwed into the elbow baseplate (only ~ 3-4 threads worth) when I received it. There was a lot of flex in the set-up that was exacerbated by the fact that it was not "level" with the injector bungs. When the AFPR saw boost, it pushed two injectors out of the rails and sprayed fuel everywhere. Fortunately I made it home without the car catching fire (it was ~ 6 blocks, and I knew something was wrong, but did not even stop to check under the hood, just wanted to get it home). It now has bosses that are beefed up on the elbow at the correct location to allow ~ 0.020" clearance between the rails and the injectors, with the injectors being fully bottomed in the bungs. The bungs had to be machined to a common "level" height across all four on each side. I also used 1/4" x 20 countersunk allen bolts that recess nicely into the rails. The bolts thread into the new boss and the baseplate ~ 3/4". It is much stronger, as I can pick up the complete manifold assy by the rails with no signs of flex. After looking at pics of yours, I would say that the welds on the elbow panels of your intake look much better than mine did originally, but my base and injector bung welds looked much better than your intake. I cleaned some up and ground some out and re-welded (tig) them. I will not even go into the MB that was included in the deal that would not close (held open ~3/8"; potential high idle issue???), that AS&M said had a bent throttle shaft (they wanted ~$300 for those repairs). Again, some guys will say anything to make a sale. I was over talking to a bud this evening, and I may be making up a new "raised runner" intake, so maybe this one will hit the market. Aaron |
Posted on: 2008/10/24 0:16
mseven | Re: Carbon Fiber Rocker Cover review | ||
Aaron I remember whom you speak of, and the stand off between him and JB......as well as his claim to be the first and doing them for a number of years. Glad you posted, what it was upon purchase. that sux on the c.fiber v.covers. Sheet metal v,covers are inexpensive nowadays. Places like speedway sell imported ones that are machine welded, 1/4" billet plate, polished out, and in various styles (including the moroso, or canton style) for 100. or less. They are straight, sit flat, look great and are actually an excellant product. |
Posted on: 2008/10/24 13:53
