149 user(s) are online (111 user(s) are browsing Forums)
Antilock Braking System.
88BlackZ51 Gears and Transmission for the 421 and Top Speed.
481 Posts
Right now the car sits stored in the garage with the 4+3, and 3.07’s gears. My motor is not far away from being completed so I need to think what gears it’s going to like with the black tag ZF6 I purchased. I have been talking to Vic’89, and I am pretty sure I am going to purchase his old 3.45’s. I am not sure if it’s the optimized gear for the car, but I am sure it will be better then the 3.07’s. I also have a friend that has a set of 3.33’s that I am going to get.
I might leave the 4+3 in the car and see if it will handle the torque, or I might just do both of them at once. The latter seems like the smartest thing, then maybe I cam recoup some money selling the 4+3 since it has no issues what so ever.
With the ZF6 here is the MPH from http://www.f-body.org/gears/ I am hoping this site is accurate, and I think it is. I plan on shifting at 6300, but that is on paper.
3.07’s
1stGear-58 MPH
2ndGear-86MPH
3rdGear-120 MPH
4thGear-155 MPH
5thGear-207 MPH
6thGear-1200 RPM at 60 MPH (wow!)
3.33’s
1stGear-53 MPH
2ndGear-80 MPH
3rdGear-111 MPH
4thGear-143 MPH
5thGear-191 MPH
6thGear-1300 RPM at 60 MPH
3.45’s
1stGear-52 MPH
2ndGear-77 MPH
3rdGear-107MPH
4thGear-138MPH
5thGear-184MPH
6thGear- 1400 RPM at 60 MPH
3.73’s
1stGear-48 MPH
2ndGear-71 MPH
3rdGear-99 MPH
4thGear-128 MPH
5thGear-170 MPH
6thGear- 1500 RPM at 60 MPH
It appears that my top speed with 3.45’s will be 184 MPH. Do you think I will have an issue getting to that speed? It looks like for pure top speed the 3.07’s gear would be the one to go with, but since I can’t drive on the airport strip every day, the 3.07’s doesn’t make sense, but 0-60mph (6400 shift) would be neat in one gear.
If I went with 3.07 gears, do you think the car would be capable of reaching speeds close to 200 mph? Or do you think it would need more power?
For all out ¼ mile it appears that the car would run the strongest with 3.73’s as it would be capable of trapping 128 mph on the big end in 4th, but if I am going to put a 100-150 shot on the car, the 3.73’s would be too much, and the 3.45’s would be more in the cards since 138 mph would be top of 4th. I am thinking the 3.73’s “might” be too much for the street. With the miniram it will have a very flat TQ curve, and make in the area of 400-420rwtq at 2000 rpm’s so I don’t need a gear to get the car rolling especially with the smaller cylinder head ports.
It’s a very interesting decision. I will probably go with the 3.45’s as they seem like the best overall gear. But then again, I won’t know foresure until I drive the car.
I also don't think there is a perfect gear with the ZF6.
Have a good one guys!
Posted on: 2008/11/13 17:39
bogus Re: Gears and Transmission for the 421 and Top Speed.
You might come close... but I kinda doubt it... aero drag is a bitch.
Posted on: 2008/11/14 1:34
pr0zac Re: Gears and Transmission for the 421 and Top Speed.
my car would hit 138 like it was its job stock in 4th. and have done 150 stock fairly easily. since geting a ticket for 95 in a 45 and since i haven't bothered going that fast. i now have 4.10's so i don't know how that is going to be with the new motor. haven't driven it except on and off the trailer at the exhaust shop.
Posted on: 2008/11/14 1:49
cuisinartvette Re: Gears and Transmission for the 421 and Top Speed.
Gear it where the cam is going to like it the most, dont do it for top or cruising speed.
Posted on: 2008/11/14 1:53
88BlackZ51 Re: Gears and Transmission for the 421 and Top Speed.
481 Posts
Come close to what 200 mph?
Wonder how much power it takes for a C4 to reach 190'ish?
Not really worried about 200. I know it won't have that kind of power!
Posted on: 2008/11/14 1:56
481 Posts
That is probably 3.73's. 4.10's would be way to much for the stroker.
The issue is the 3.73's will be great at the track with a hook. I bet it would get deep in the 11's, but I have never been worried about e.t.
It will be fun anyways. Nothing like a manual tranny with over 500hp, and shifting like you stole it.
Posted on: 2008/11/14 1:57
CentralCoaster Re: Gears and Transmission for the 421 and Top Speed.
With the right gearing, 200 doesn't take as much as you think.
I posted the breakdown somewhere else, I'll see if I can't find it.
http://www.corvette-guru.com/modules/ ... =ASC&type=&mode=0&start=0
My posts in that thread have 200mph happening at about 450rwhp in a C4 with proper gearing and enough track.
Posted on: 2008/11/14 2:05
481 Posts
You have about 600hp as well, lol!!
Kevin did you get my email. I'd would think Jim will get back to us with the dyno graph.
Posted on: 2008/11/14 2:11
jsup Re: Gears and Transmission for the 421 and Top Speed.
1778 Posts
If this is a street car, why not street gears...just wonderin...
The goals seem to be all over the place...1/4 mile, top end, street...
Pick one and go with it. There is no one all around solution.
Posted on: 2008/11/14 2:29
481 Posts
Probably just go with the 3.45's. That way I have room to grow if I ever decide to spray it. The bottom end will certainly handle it!
3.73's would be fun however!
Posted on: 2008/11/14 2:36
1778 Posts
That sounds as close as you're going to get to an "all around" gear, from what I understand, which, ain't much.
Posted on: 2008/11/14 2:43
481 Posts
Not following you. What "ain't much"?
Posted on: 2008/11/14 2:52
1778 Posts
What I understand, ain't much.
I hear the 6 speed guys saying 3.45 works for them, anecdotal, but seems to work.
Is there not an expert you can find locally on the issue?
Someone who's core business is trans and rear service?
Posted on: 2008/11/14 2:57
What does your builder recommend?
Personally Id go for 3.73s on drag radials at all times. 3.45 may get you by though.
Forget about all that top speed crap, its going to pull 5th well anyway due to sheer CI size.
Posted on: 2008/11/14 3:10
1778 Posts
Why would he ask an engine builder? Do you mean in terms of getting the engines operational range of the cam to match the gears?
Wouldn't it make more sense to go to a trans/rear guy?
He said all along it was a "street car" which I would assume would not be on drag radials. If the goal is streetable, 3.45, no? I think he said "occasional" track use.
Posted on: 2008/11/14 3:19
Im sure 3.45s would work well....Recommended he consult his builder as he apparently does a lot of these 420/421 cube motors and probably knows where it will like to run better than most would is my guess.
Posted on: 2008/11/14 3:29
Top speed is never a consideration, just a "what if"
A good 1/4 mile gear (assuming you finish in 4th) will also be a good street and highway gear.
But I need a dyno curve before I can be your gearing "expert".
Posted on: 2008/11/14 3:44
481 Posts
Sent!
Posted on: 2008/11/14 4:05
pulling 5th isn't the problem... it's pulling 6th.
5th is ~.75:1 OD, that is where top speed is seen; 6th is ~.50:1, the amount of torque needed to overcome that gear is staggering.
Posted on: 2008/11/14 15:22
True..from what I understand they dont recommend topping these out in 6th as some damage reults, something about the reverse gear seizing up. Sure ZF doc can explain it better.
Posted on: 2008/11/14 15:49
LT4BUD Re: Gears and Transmission for the 421 and Top Speed.
52 Posts
Sent!
Can you post it???
Posted on: 2008/11/14 16:55
481 Posts
Don't know how 2. I sent it to CentralCoaster.
Posted on: 2008/11/15 0:47
My simulation with a ZF6, 26" tires, 3400 lb race weight, 1.70 60ft:
Shift point: 6350 RPM
3.45 rear: 10.56 @ 128.4, top speed 191mph in 5th
3.55 gear: 10.56 @ 128.5, top speed 188mph in 5th
3.73 gear: 10.61 @ 128.3, top speed 193mph in 6th
3.90 gear: 10.65 @ 127.2, top speed 196mph in 6th
4.11 gear: 10.70 @ 127.0, top speed 199mph in 6th
Anything above that requires shifting into 5th.
Posted on: 2008/11/15 3:49
481 Posts
Kev thanks!
Is it possible for the car to pull in 6th?
What 60 foot did you use?
Thanks again. That was cool!
Posted on: 2008/11/15 4:01
1778 Posts
My simulation with a ZF6, 26" tires, 3400 lb race weight:
3.45 rear: 10.98 @ 127.5, top speed 191mph in 5th
3.55 gear: 10.94 @ 127.7, top speed 188mph in 5th
3.73 gear: 10.87 @ 127.8, top speed 193mph in 6th
3.90 gear: 10.82 @ 127.4, top speed 196mph in 6th
4.11 gear: 10.77 @ 126.1, top speed 199mph in 6th
Anything above that requires shifting into 5th. Even with 4.11s, you have to ride it out to 6700rpm.
Stupid question, on a 6350 shift, aren't you testing the limits of a hydraulic roller?
I believe 6500 is about the hairy end of an HR setup. Riding it to 6700 isn't about the capacity of HR? Or am I just over cautious?
For the time differences, and since this was built as a street car, I'd go 3.45, the gains aren't enough on the other gears to tool around at high RPMs.
Posted on: 2008/11/15 4:03
My sim isn't good at figuring 60' times, because in reality dumping the clutch puts a lot more energy to the rear wheels, more than than the peak torque of the engine, and I haven't figured out how to model that yet.
I went back and edited them all to a 1.7 60' and see which wins out. Makes more sense this way, as the 4.11s were way past the power curve.
How does gearing effect the 60'? Is a shorter gear always better?
Posted on: 2008/11/15 7:15
Josh Re: Gears and Transmission for the 421 and Top Speed.
I think deeper gears will be more fun, so I would go 3.9XX or 4.09. For me, fun = number 1. Everything else is secondary to how fun the car is to drive.
If you drag race, I think the deeper gear will be faster, regardless of what the sim says. The steeper gears make wheel spin infinitely more manageable, and makes the car much easier to launch effectively. If you put a sticky tire under it that can handle a 4-5K clutch drop, the 3.45's might be faster, but even then I have my doubts.
Posted on: 2008/11/15 14:54
1778 Posts
He's maintained this is a street car first, pulling 3K on the highway isn't attractive to me, but it's his car.
Also, this thread asks about top speed. So it's hard to tell where his head is at. Do we believe his original claim of street car, his thread on top speed, or his current position of 1/4 mile.
It's all so confusing to me.
Posted on: 2008/11/15 14:59
AKS_Racing Re: Gears and Transmission for the 421 and Top Speed.
62 Posts
Although I agree that with a 6 speed the deeper gears are more fun around town, I ran into issues with running out of gear in the 1/4 mile. I have a set of 3.54s, a 3.7 and a 4.10 all spare chunks, and I could make none of them work. With the tires I run at the track, if I get much faster, I will have to go to a 3.33D44 (which I really don't want to do).
Aaron
Posted on: 2008/11/15 15:10
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft:
jsup wrote:He's maintained this is a street car first, pulling 3K on the highway isn't attractive to me, but it's his car.
3,000 RPM's and a 4.09 gear works out to 116 MPH in 6th gear with a ZF6. No one cruises the freeway at 116 MPH. At a more reasonable 75 MPH he would be turning an entirely livable 1950 RPM's. If he goes 3.92, 75 MPH would be 1875 RPM's, which is also entirely livable.
Where do you come up with 3K? He could run a 4.88 gear and still only be turning 2350 RPM's at 75 MPH. To see 3,000 RPM at 75 MPH he would have to run a 6.13 rear gear.
Posted on: 2008/11/15 16:41
1778 Posts
ooops, You're right, my frame of reference is my 700R which runs about 2200 RPMS with the 3.07..at about 70ish
I find more than that annoying...Sorry, frame of reference issue, gotta get my head out of the auto.
Posted on: 2008/11/15 16:45
No worries man. :cheers:
As far as him running out of gear in the 1/4 mile, as long as he is willing to turn 6500 he should be able to go 130 or so in 4th with the 3.9XX or 4.XX gear.
Posted on: 2008/11/15 16:57
I still question the ability of the 6th gear to do much... even with more rear gear...
Posted on: 2008/11/15 18:18
I don't think it'll pull it in 6th regardless of rear gear.
Posted on: 2008/11/15 18:35
481 Posts
I don't think so either, but then again it's going to have a very flat tq curve.
Topspeed isn't really important, but I do have an airport near by that has a very long runway. I was on it 2 years ago, but the car was mainly stock.
It would be cool however for it to do in the 19x mph mark, and run the 1/4 somewhere in the 11's. Somewhat sleeper territory if you ask me.
Posted on: 2008/11/15 19:24
Remember... the new ZR1 has 640hp/575ft-lbs and still gets to 205 in 5th.
Posted on: 2008/11/16 2:00
That's ridiculous. The engine doesn't care how many teeth are in the trans, all it sees is the overall ratio. The numbers I posted pretty much show that 6th overtakes 5th if the rear is short enough. Obviously it'll take forever to get that last few mph though.
Posted on: 2008/11/16 3:41
All I meant was that 6th gear has a torque reduction/speed increase as opposed to speed decrease/torque increase like the lower gears. I realize 5th does the same thing, but I've never seen 6th gear actually used for top speed. You've shown that it is doable though, so I apologize for the ambiguous statement that I made.
In our particular application, 6th gear can't be used as the top speed gear due to design issues with the ZF6 transmission, so it's really a moot point for this discussion.
Posted on: 2008/11/16 16:27
481 Posts
Did you have any issues with the 3.07's/ZF6 combo?
Posted on: 2008/11/18 10:35
Way too tall. You couldn't use 6th until about 85mph. So I ended up driving 90 everywhere whether I wanted to or not!
Its first gear is a little taller than the 4+3 also, better suited to a 3.33/3.45/3.55. I went with the 3.45 as it made the most sense in the 1/4 mile and does 75 mph at 1800 rpms. In the 1/8th I would've been better off taller.
Posted on: 2008/11/18 15:12
