Schrade | What's the part? | ||
It's an electrical part in the blower housing of my '98 Jimmy, and it 'seizes' sometimes, and it takes a light knock with a knuckle on the housing to get the fan circuit closed.
Anybody know the part? Replacement time? And what about the 'cut-on-dotted-line' marking on the housing? I'm not into hackin' the box blind... The notation says, "Cut here for service". Cut the whole box? |
Posted on: 2008/11/16 18:02
LT5, Marc Haibeck ECM module, AUTOMATIC!!! ![]() |
jsup | Re: What's the part? | ||
Relay? Maybe the fan itself is sticking.
Posted on: 2008/11/16 18:10
Schrade | Re: What's the part? | ||
Could be a relay there jsup... I'm not sure. Not the fan itself tho', I'm sure of that. But anytime it doesn't come on, just a little hit, and its spinnin'. I know the broken part is in the housing; I haven't cut the box yet. ??? |
Posted on: 2008/11/16 19:15
THere was no pic before...now that I see it, can't be a relay, they would make a relay accessible.
No idea. |
Posted on: 2008/11/16 20:28
pianoguy | Re: What's the part? | ||
No idea. I remember a couple of my old Pontiac Grand Prix's had scribed lines in the fender well to cut to change the blower motor.
Posted on: 2008/11/16 21:08
Matatk | Re: What's the part? | ||
I'm guessing it's some blower control module. Why don't you write down the part number and google it - that should tell you what it is.
From the pics it looks like you can remove it, there's a screw there. Matthew ps - also looks like it's cracked? |
Posted on: 2008/11/16 21:11
TommyT-Bone | Re: What's the part? | ||
I call it "The Thing".
Posted on: 2008/11/16 22:50
pr0zac | Re: What's the part? | ||
the only way to get in there easily is to cut it off then patch it back up..if you pull the motor its easy to get to but if its 4wd its harder then hell to pull the engine. everything is crammed in there.
Posted on: 2008/11/17 0:35
bogus | Re: What's the part? | ||
I would call Chris May at Superior Chevy (1.800.728.8267), tell him the Guru sent ya... you can even mention my name.
I am SURE he can direct you. |
Posted on: 2008/11/23 5:47
crash | Re: What's the part? | ||
the only parts inside the case are the heater core and evaporatror core by hitting the housing you are jarring either the blower motor are something else attached to the evap housing is it a atc or manaul system is the blower motor mounted inside or out on the of the vehicle check the blower motor ground and connections
Posted on: 2008/11/23 12:17
IM NOT COMPLETELY USELESS I CAN BE USED AS A BAD EXAMPLE |
Well, it ain't the part at the question mark that's faulty.
I took it out of the housing, connected, gave it a tap, and no go. Tapped the housing itself, and started right away. Anybody? |
Posted on: 2008/11/24 21:33
CentralCoaster | Re: What's the part? | ||
First I'd check the wires to the motor for voltage when it's supposed to be running but not.
The Haynes manuals have a crude wiring schematic in the back that might show you what goes between the control head and the blower. |
Posted on: 2008/11/24 23:25
Well I started hackin', and it ain't the part on the motor side either. Cut the box, tapped, and nogo. Tapped the other side, and spin-up yup.
I think that leaves only the fan itself. Brushes worn? Pull the fender to get to the blower? UGH. If the fan cage itself had camo, I don't think it would be any harder to get to in there GRRR... |
Posted on: 2008/11/27 13:42
Post 2, I could have saved you a lot of time.
Posted on: 2008/11/27 13:46
Yeah, stupid me. I should have listened. |
Posted on: 2008/11/27 14:58
Not to rub it in, but troubleshooting is a lost art. I would have pulled the motor and checked for power, turning the power on and of 10, 20 times. If I got power every single time, motor. If not, work my way back to see where I lost power. |
Posted on: 2008/11/27 15:07
No better troubleshooter than me. NONE. Bank it.
Or see for yourself: http://forums.corvetteforum.com/showthread.php?t=2069247 You've NEVER seen such in-depth T/S. For this thing, I started with the easy stuff. Part at 'question mark', then the part on the motor side. Fan cage is least accessible part to test. I already know voltage is there, since a tap starts it spinnin'. Voltage is there, and the blower works when it gets thru'. Edit: You're a funny guy. NO ONE tells ME about troubleshootin'. Tips, tricks, experience; I'm listenin'. Troubleshootin'? Diagnostics? Just do like they did in the CF thread I linked (and there's a couple more if you want). Listen, bookmark (like at LEAST 2 posted they were doin'), and watch, and hit 'save' yup. ![]() Tellin' me about troubleshootin'. Pfft. |
Posted on: 2008/11/27 20:36
