pr0zac | hey check out this budget motor. | ||
Posted on: 2008/11/29 15:17
pr0zac | Re: hey check out this budget motor. | ||
Posted on: 2008/11/29 15:19
Posted on: 2008/11/29 15:21
88BlackZ51 | Re: hey check out this budget motor. | ||
Was your thread deleted?
Posted on: 2008/11/29 18:03
PeteK | Re: hey check out this budget motor. | ||
Click the words, and they take you to the linked site. |
Posted on: 2008/11/29 18:05
BrianCunningham | Re: hey check out this budget motor. | ||
440chp on a stock bottom end is pretty
Not a bad showing for the iron head vortecs either. I've heard the stock iron head LT1's outflow their AL counterparts. |
Posted on: 2008/11/29 19:24
BeachBum | Re: hey check out this budget motor. | ||
Ahhh... thats better. I like em all.... my favorite is the $ 2000 385 HP motor.... maybe swap the intake or something and find yourself another 15hp for a 400 HP motor for $ 2200 or so..... not a bad deal for a street cruiser of some sort. |
Posted on: 2008/11/30 0:19
brut | Re: hey check out this budget motor. | ||
I am doing a iron Vortec build for my '76. I was thinking of going to a 383....but that 355 sounds enticing with 400+ HP.
Posted on: 2008/11/30 0:45
'71 Nevada Silver Coupe '76 Bright Yellow 4-Speed Coupe '88 Midnight Blue Coupe -SOLD- '02 Harley Davidson Heritage Softail Classic '07 Hummer H3 |
cuisinartvette | Re: hey check out this budget motor. | ||
Sounds identical to Bluewasps LT4 on CF, used LE heads, same cam and 11:1 447 rwhp? |
Posted on: 2008/11/30 1:26
Schrade | Re: hey check out this budget motor. | ||
HEADS From here: http://www.9c1.com/technical/LT1_rebuild/ar99928.htm If accurate, that means head flow was nearer to LT4. |
Posted on: 2008/11/30 6:26
Posted on: 2008/11/30 7:43
