238 user(s) are online (176 user(s) are browsing Forums)
PeteK Some old video's
From the good old days. Mid 90's approx. 1st 11 second run.
And another clip. That car always seems to hook well.
Posted on: 2009/1/11 14:01
1Fast04Vert Re: Some old video's
Nice, makes me wish I could take it to the track today. Come on spring time.
Posted on: 2009/1/11 14:45
PeteK Re: Some old video's
Up here, spring is a long way off. Racetrack will not likely open before the end of April.
Posted on: 2009/1/11 14:59
TommyT-Bone Re: Some old video's
33768 Posts
Were you running a line lock Pete? Just wondering, with Vettes, do most just toast there rear pads and smoke em'?
Posted on: 2009/1/11 15:02
No line lock. The rear pads are about 10 years old, and the burnouts don't seem to hurt them at all.
Posted on: 2009/1/11 15:03
BrianCunningham Re: Some old video's
Cool
Do you have them on tape?
You can wire the VCR directly into the digital one.
That would eliminate the video of a video.
Posted on: 2009/1/11 15:36
BrianCunningham wrote:
Cool
Thanks,
I will mention that to my buddy. He owns them. That makes it easier for sure.
Posted on: 2009/1/11 15:41
pianoguy Re: Some old video's
Excellent - helluva jump on that second vid!!
Posted on: 2009/1/11 15:51
xccter Re: Some old video's
Downtown Annapolis, MD
461 Posts
Pretty Cool stuff there.
Posted on: 2009/1/11 17:24
´71 350/270 L48 Coupe
NCRS #48337
BeachBum Re: Some old video's
751 Posts
Cool Beans
Posted on: 2009/1/11 17:35
I think I was still running recap tires back then. In the early days of drag radials, the BFG's had to be bought direct from BFG, and were almost always back ordered. I ran a yokahama autocross tire, but the outer 3rd was smooth, therefore always caught the tech inspector eye, and I usually was accused of running a worn out tire. The solution was to run a performance recap from a place in Tennessee. Laugh if you will, but they hooked like glue, and never needed much weight to balance. Good in the rain, and got approx 5-7k out of a set. Best 60' on one was 1.550. I won my 2 track championships on recaps. Like I said, the good old days
Posted on: 2009/1/11 17:42
