141 user(s) are online (107 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
Danspeed1 Who has attempted their own port work???
Mooresville, North Carolina
1121 Posts
And has had success??? Just wondering?? Pro's don't count!
DG
Posted on: 2009/1/12 6:00
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Matatk Re: Who has attempted their own port work???
22811 Posts
flyboy did some on his intake, I believe.
PS - can we really consider Ron a "pro"? (JK Ron)
Posted on: 2009/1/12 11:48
Jeffvette Re: Who has attempted their own port work???
Posted on: 2009/1/12 12:29
Midnight85 Re: Who has attempted their own port work???
Streator, IL.
264 Posts
I did extensive grinding on my intake & plenum, then I matched the runner openings to the manifold & plenum using gaskets as a template. I also bought the dent removal kit off ebay for the runners, it smooths them out and opens them up just a tad. I don't have any pics but I must have done something right, the car runs like a raped ape. You have to be REAL careful using a die grinder and carbide burr on aluminum, it works real fast.
Posted on: 2009/1/12 15:18
cuisinartvette Re: Who has attempted their own port work???
:chissle:
Posted on: 2009/1/12 16:37
Danspeed1 Re: Who has attempted their own port work???
1121 Posts
I was thinking of buying an intake manifold and giving it a try, but its so inexpensive to have a pro do it (an intake manifold that is) I am not sure if its worth the trouble.
DG
Posted on: 2009/1/12 19:56
1996 Ford Explorer
2009 Cadillac CTS-v
Problem is knowing what to buy, how to use it and too many hours to learn. Unless youre obsessed with learning its cheaper to pay someone.
Posted on: 2009/1/12 20:06
BrianCunningham Re: Who has attempted their own port work???
If you really want to learn, go to a rebuild shop or yard and find a set of junker heads.
But the newer CNC'd castings are so much better than the older stuff. By the time you add up the cost of rebuilding, you're better off with the new stuff.
cuisinartvette wrote:
:chissle:
LOL
Posted on: 2009/1/12 20:25
Schrade Re: Who has attempted their own port work???
:chissle:
I've read a few web pages about doing this yourself.
They seem to say that matching ports is not too difficult. Opening the entire port up is MUCH more difficult - keeping flow identical in each port.
Posted on: 2009/1/12 22:24
tpi421vett Re: Who has attempted their own port work???
Salt Lake City Utah
125 Posts
I personally think the more expensive the head or intake the less you want to mess with it. Some stock casting with rough cut machining in the pocket area is one thing to smooth out the rough edges. But to try to improve on state of the art cnc high dollar heads is asking for problems. Blending intake ports is much easier than reworking high dollar heads. The closer to the valve you get, the more important it gets.
Posted on: 2009/1/14 4:46
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
Salt Lake City Utah
125 Posts
By the way... Ron (Cuisinartvette) does some nice work!!!
Posted on: 2009/1/14 4:53
1121 Posts
So I've heard...
Posted on: 2009/1/14 5:11
1996 Ford Explorer
2009 Cadillac CTS-v
Thanks Jim. I agree about not grinding on new (expecially CNC stuff). Ive done it and had decent results but it is extremely risky, most times you go backwards for any little gain or worse yet put a hole in something. BTDT.
Posted on: 2009/1/14 5:20
