242 user(s) are online (166 user(s) are browsing Forums)
Also known as NHMS....
red_johnny Bathroom remodel
Welp, here is the low down. I took out all the tile, dry wall, toilet, sink and stuff and under the tile floor was this. Oh, and its even worse under the tub.
Then here is the damage in the living room....YUCK!!
Posted on: 2009/1/21 23:04
pianoguy Re: Bathroom remodel
Amazing how wet it gets behind there. I don't know that I'd do another tile shower wall after seeing what one of mine looked like.
Posted on: 2009/1/21 23:14
Matatk Re: Bathroom remodel
Don't worry, John, I've seen worse
Sometimes it's easier just to rip it all out and start from scratch. I'm assuming the living room wall is on the opposite side of bathroom, hence the water damage?
What's under the house? Crawl/basement/slab?
Posted on: 2009/1/21 23:15
Danspeed1 Re: Bathroom remodel
Mooresville, North Carolina
1121 Posts
I just detailed my bathroom.... AH YUP.... Got out the old Makita, a polishing pad, and went to work with some cutting cream on the tub and counter tops. Polished those suckers out to a mirror finish! Then I top coated it with some 303 Aerospace Protectant.
DG
Posted on: 2009/1/21 23:59
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
red_johnny Re: Bathroom remodel
Nah the living room is a seperate project and thats termite damage. Not to worry, them suckers are long dead but the prior owner covered up the damage with plywood. The floor in the bathroom is very unstable but I can still walk on it. I have a crawl space under the house but I should not need it. Once I am down to the joists I am going to access the damage, make repairs and refloor. The studs are too easy to replace so I aint worried about them.
Posted on: 2009/1/22 0:04
In the one pic that shows the living room floor it seems like there is a water mark. Ever have water problems on that wall?
As for as the joists, you're right that once you get the floor up you can inspect the joists, sister them as necessary. A new subfloor will make a clean start to the project.
Keep us posted.
Posted on: 2009/1/22 1:55
I think there was water damage at some point but it was not much. Tomorrow I am going to pull up the junk and install a new subfloor.
Posted on: 2009/1/22 2:02
bogus Re: Bathroom remodel
how old is that house?
Posted on: 2009/1/22 3:43
Schrade Re: Bathroom remodel
You gonna' do any mods in your 'library'?
Might need a little protection from the stinky fingers
Posted on: 2009/1/22 4:23
1121 Posts
Blade_1 wrote:
Might need a little protection from the sticky fingers
You need one of those anyway if you spend a lot of time on the guru. With all the avatars on this site, never know when your going to be feeling a little feisty.
DG
Posted on: 2009/1/22 5:02
1996 Ford Explorer
2009 Cadillac CTS-v
cuisinartvette Re: Bathroom remodel
Just wipe it on the carpet and post away its like teflon sealer .
Posted on: 2009/1/22 6:35
Epimax Re: Bathroom remodel
Wilmington, NC
1814 Posts
Oh Boy...I've seen that before......
I've got a soft spot in the 1/2 bath downstairs now...right beside the sink cabinet area...
It appears to be old water damage from a leak, etc...
Still will have to pull everything up to put down new subfloor...
At least it's only a 1/2 bath though...Still...yuck...
Good Luck!
Posted on: 2009/1/22 11:37
Wilmington, NC
1814 Posts
Posted on: 2009/1/22 11:39
The house was built in 52 or 53 I think. So I expected something like this. No biggie. Just takes a little more time and money.
Posted on: 2009/1/22 12:52
Johnny is gonna have his own show on HGTV pretty soon ;-)
Posted on: 2009/1/22 12:55
BillH Re: Bathroom remodel
DG
Funny, I just did all the shower tile with my orbital and Meguiars Cleaner Wax. Goodby soap scum.
Posted on: 2009/1/22 15:16
1121 Posts
BillH wrote:
DG
Works like a charm right?
I topped it off with Some 303 Aerospace. I was going to wax it but i was worried about the floor being to slick if I did. The 303 seems to be working quite well in keeping the soap scum and rust off the walls (well water).
DG
Posted on: 2009/1/22 17:20
1996 Ford Explorer
2009 Cadillac CTS-v
Danspeed1 wrote:
BillH wrote:
Funny, I just did all the shower tile with my orbital and Meguiars Cleaner Wax. Goodby soap scum.[/quote]
DG[/quote]
I have county water but the county just owns the wells.
Here's a trick to remove the rust stains (or the green stains). Mix some Creme of Tarter (the cake frosting chit) and some peroxide up and apply. Works well.
Posted on: 2009/1/22 17:29
ARRGGGHHHH.....I am beat down. I got off of work around 530PM and went right home, changed and to lowes where I picked up some supplys and came right back and jumped on the bathroom. I pulled up all the old flooring, only the joists are showing now. I have some small repair work to do and then I can put flooring back down. My hope was to get the flooring laid tonight but its too late now and I dont want the law called in from me making too much noise plus I got to run 3 miles at 530AM so I need to hydrate and rest.
Posted on: 2009/1/23 2:29
Sounds good, John. I know how hard it is to come home after work and then do projects for hours. It'll happen, don't worry brother.
Posted on: 2009/1/23 2:33
I hear ya, tonight I WILL get the floor in. Should take me about 2 hours.
Posted on: 2009/1/23 11:34
Danspeed1 wrote:
BillH wrote:
DG
DG
Sounds like we need a bathroom subsection in the Detailing forum ;-)
Posted on: 2009/1/23 13:31
subfloor is in. Just need layer two and I will be good to go and can start doing the electrical and drywall. Monday the plumber has a few things to do and we get an estimate for the brick glass window so those places I cant mess with the dry wall yet. After the tub is in and the window I will finish the dry wall, get it tapped and sanded, primered and maybe painted then comes the tile floor. After that I can install the toilet and sink. Then I should be done.
Posted on: 2009/1/24 0:54
Layer two is in and guess what? It fits FLUSH with the parts that did not need replacing...IE Hallway, closet! Thats AWSOME! Now I got to frame up a window in the living room where the termite damage is so when the window guy comes he can give us a good estimate. I think I will finish that after dinner.
Posted on: 2009/1/25 21:49
C4DERF Re: Bathroom remodel
332 Posts
More like on SPEED TV "The Home Addition"
Johhny, best of luck on your SWA deployment.
Posted on: 2009/1/25 22:20
Thanks!
Posted on: 2009/1/25 22:31
Where are the pics, Johhny?
Posted on: 2009/1/25 23:37
[IMG]http://i66.photobucket.com/albums/h244/red_johnny/DSC00766.jpg[/IMG]
[IMG]http://i66.photobucket.com/albums/h244/red_johnny/DSC00767.jpg[/IMG]
[IMG]http://i66.photobucket.com/albums/h244/red_johnny/DSC00768.jpg[/IMG]
[IMG]http://i66.photobucket.com/albums/h244/red_johnny/DSC00769.jpg[/IMG]
[IMG]http://i66.photobucket.com/albums/h244/red_johnny/DSC00770.jpg[/IMG]
Posted on: 2009/1/26 1:04
Looks good so far. I especially like the contractor grade ladder
Are those PVC supply lines for your sink & toilet? Is that code down there?
Posted on: 2009/1/26 13:18
RJ, is the gut giving you an estimate for the window or the install? The reason I ask is that with your expertise, the window install should be easy.
Posted on: 2009/1/26 15:13
