92 user(s) are online (58 user(s) are browsing Forums)
vetteblondie, more...
X-FIRE Window Loose..
Ohio
104 Posts
I am having problems with the side windows. I can actually move the glass with my hands on both sides, the passenger side moves more than the driver side. They both leak, but the passenger side is worse. Any body have any suggestions on the fix for this. Thanks for any help.
Posted on: 2009/1/29 17:52
pianoguy Re: Window Loose..
Could be the regulators or the pads, hard to tell without taking the door panels off and having a look. If it needs more than just an adjustment, Corvette Recycling sells full rebuild kits with regulators, pads and outer seals - the kit was around $300 if I recall. They also sell parts individually - I picked up a set of pads for about $30.
Posted on: 2009/1/29 18:47
X-FIRE Re: Window Loose..
Ohio
104 Posts
Thanks I'll check that out. I have to repair the carpet on the door also it came loose..
Posted on: 2009/1/29 20:10
CentralCoaster Re: Window Loose..
Loose side to side or pushing in & out?
Loose in & out can be fixed by adjusting or replacing 2 felt pads in the door, and by replacing the rubber seal on the outer side. This will also help with leaks by keeping the glass tighter against the weatherstrip.
You can also adjust the glass where it mounts to the regulator to get a better seal. First make sure the door hinges aren't sagging, that could be to blame. Does the belt line on the car line up with the door slightly ajar?
Slop side to side is either a loose regulator or loose were it attaches to it.
I would be surprised if the windows weren't pretty sloppy to begin with straight off the assembly line.
Posted on: 2009/1/29 23:14
Matatk Re: Window Loose..
I replaced my outer door seals last week along with adjusting the felt pads since I had the panels off. It made a huge difference in how the window closed.
Posted on: 2009/1/30 0:30
BillH Re: Window Loose..
Yea, what CC said.
Especially the felt pads, I'll bet they're shot, mine were and I replaced them with the seals. I actually had to adjust the glass looser so the door would close. The pads are avaliable & cheap.
No water leaks.
Additionally, if the felt wears too much, the metal bracket will scratch the glass.
Posted on: 2009/1/30 1:45
And if the felt comes loose, there's some nasty sharp edges inside the door assembly for the glass to scrape on too.
Posted on: 2009/1/30 4:10
I happened to notice that the window rebuild kit is on sale, if you need it:
http://forums.corvetteforum.com/c4-pa ... ding-unit-front-hubs.html
Posted on: 2009/2/7 2:50
That is a great price for new parts.
Posted on: 2009/2/7 4:29
jhammons01 Re: Window Loose..
I bought the regulator for ~$100. They have that kit on sale for $300
So the outer seal and the inner felt pads are worth $200?
I'm missing something. Are they selling both sides for $300?
Posted on: 2009/2/7 5:13
That kit includes:
* LH Window Regulator Replacement: 22063225
* RH Window Regulator Replacement: 22063224
* Exterior Window Seal Pair: LH & RH
* Window Pads (Qty. 4)
Posted on: 2009/2/7 12:43
It's both sides and it's $250.
Posted on: 2009/2/7 16:32
^^that is a hell of a deal.
If I needed the driver side again, I'd buy that package and do both sides.
Posted on: 2009/2/7 17:35
VetteUSA Re: Window Loose..
103 Posts
x-fire, it might also be that the window stop guides are broken. Here's a write-up I did if you want to look into it:
C4 Window Alignment
Posted on: 2009/2/8 3:48
NC Kid Re: Window Loose..
North Carolina
1671 Posts
I replaced the pads and OMG, it made such a difference. They were tight. I am about to do the inner seals and outer seals. If it gets tighter than now, damn. They do not budge with just replacing my felt pads. BTW, I got them from corvette recycling and they are the real deal!
Posted on: 2009/2/8 4:41
I got my outer door seals from corvette recycling. One had a little kink in it, but they are NOS and for the price I couldn't beat it.
BTW, if it gets too tight, you can loosen up the pads a little.
Posted on: 2009/2/8 12:09
One problem though, is tight felt and window seals will cause the plastic ribbon to break. This happened to me.
Then your $40 window tightening will turn into a $250 window regulator upgrade. So don't get carried away with snugging it up.
Posted on: 2009/2/9 3:17
