218 user(s) are online (140 user(s) are browsing Forums)
convas L98 upgrade
12 Posts
Hi,
Bit of background, have owned a '86 z51 coupe last 15 years, recently the intake manifold started leaking, so I started taking it apart to replace it and "while I was in there" you know the story.
Anyway this is what I am planning
HSR intake
Ported 113's
1.6 Roller rockers
1 3/4 LT's
2800 stall
3.07 rear
Have not pulled the engine yet so not sure what the bottom end looks like but its done 120k miles so may need a bit of work.
I was looking at the one of the cams below, would they suit, its mainly street car (not DD anymore) with odd run down the strip
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=88&sb=2
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=22&sb=2
Thanks
Posted on: 2009/3/12 11:30
PeteK Re: L98 upgrade
In my opinion, no. They can work, but both are huge.
If it were my car, I would look for the following:
Int duration @ .050 224
Exhaust duration @ .050 230
Intake lift .550 with the 1.6 rockers
Exhaust lift .550 with the 1.6 rockers
Lobe seperation 112
I would not go flat tappet cam, and would do a roller conversion.
In my opinion, flat tappet cams should be obsolete. Without zinc in the oils, the risk of break in failure is not worth it.
Posted on: 2009/3/12 11:57
mseven Re: L98 upgrade
Motor City Madhouse
247 Posts
I agree those cams are pretty healthy for a 350 street car, if it were me I'd wait and see what I'm doing w/the bottom end, and what the heads end up at w/numbers. At that point (depending on rebuild cost of original short block)you may want to consider that crate 383's go for reasonble money these days.
Posted on: 2009/3/12 12:47
BrianCunningham Re: L98 upgrade
I wouldn't thrown $$$ at those 113's
There's a ton of CNC'ed heads on the market nowadays that will outflow what you can get out of them.
Posted on: 2009/3/12 15:00
CFI-EFI Re: L98 upgrade
Top of Utah
372 Posts
I agree with the cam recommendations. Plus you will get more from headers in the rpm range you will be using with 1 5/8" primary tube headers rather than the 1 3/4" you mentioned.
RACE ON!!!
Posted on: 2009/3/12 15:01
Josh Re: L98 upgrade
I ran an XFI 280 in my 350 for awhile and liked it. It's a little more along the lines of the cams you posted, but not quite as aggressive.
230/236
.571/.565
113 LSA
You'll have to work on the guides of a stock 113 head to keep from pushing the valve retainer into the head, but if you are machining the heads anyway it's not too big of a deal.
Posted on: 2009/3/12 21:56
convas Re: L98 upgrade
12 Posts
Hi Guys,
Thanks for the response, I am in Australia so options are more limited than US and generally more expensive.
I did think about replacing the heads but seemed to get expensive real quick, same with the roller cam conversion.
Re the headers I have only seen 1 3/4" listed here (car is converted to right hand drive) but will have another look.
Hopefully I will get the engine out in the next couple of weeks and see what its like.
Josh, what was your setup when you ran the XFI 280 ?
Posted on: 2009/3/12 23:15
