214 user(s) are online (142 user(s) are browsing Forums)
flyboy more corn squeezins in our gas?
The ethanol lobby has asked the EPA to raise the ethanol blend in gas to 15%. There is so much misinformation, misconception, propagada, and general ignorance on this subject. Do you think the Senate subcommitee that is "studying" this will come up with a raional conclusion?.
Posted on: 2009/4/5 2:20
bogus Re: more corn squeezins in our gas?
20861 Posts
They will be forced to. Ethanol is not a bad idea, but the cost - currently - is not effective.
Now, if we could get to a point where it was, that's another story. And celluistic (sp?) ethanol might be a better answer. Uses grasses that will grow anywhere and are much easier to harvest. Also has higher sugar to work with. I am not a chemist, but it works with some natural enzymes to make more sugars out of less product.
I am concerned that at 15%, it would start effecting older vehicle fuel systems.
The original reason for the 10% was for emissions. Ethanol is an oxygenate. It replaced MBTE, which is some gnarly shit. It was able to leach out of tanks and contaminate ground water, leading to birth defects and cancers. Not good.
I suspect that additional ethonal would result in such decreased MPG that any positive it provided would be lost.
Posted on: 2009/4/5 3:12
flyboy Re: more corn squeezins in our gas?
Let's grow pot and burn that...in our cars that is. Oh, in liquid form in the gas tank.
Posted on: 2009/4/5 13:35
TommyT-Bone Re: more corn squeezins in our gas?
33810 Posts
Could potentially make getting stuck in a traffic jam a more pleasurable experience. Honey ... put down the windows.
Posted on: 2009/4/5 17:45
CSS996 Re: more corn squeezins in our gas?
Mega Guru
Central PA
3644 Posts
It's like.... The end of road rage, man!
Posted on: 2009/4/5 18:20
Currently "Between Vettes".
20861 Posts
wouldn't it increase road munchies?
Posted on: 2009/4/5 19:13
33810 Posts
Give me a fill up on #5. Do you guys carry twinkees in a box? How about Yoo-hoo?
Posted on: 2009/4/5 19:33
The C7 seats will have to be even larger than the C6.
Posted on: 2009/4/5 21:16
Durango_Boy Re: more corn squeezins in our gas?
I don't understand why there hasn't been more research into using LP or CNG in cars and trucks. Propane has been used for a long time. CNG would be something you could fill your tank from home at, and from what I understand it's cheaper by volume than gasoline and you gain MPG and hold power rates.
Posted on: 2009/4/5 22:08
Dads90 Re: more corn squeezins in our gas?
Pearland, Tx
318 Posts
Heck, nobody would make it to work, because everyone would mellow out and chill. Of course, the also stuck snack truck would suffer a large hit.
Posted on: 2009/4/6 3:29
BrianCunningham Re: more corn squeezins in our gas?
I wish there was more than one E85 pump in MA.
Forced induction LOVES the stuff.
I'm really surprised there's not more E85 pump in CA.
Posted on: 2009/4/6 15:54
400hp427vette Re: more corn squeezins in our gas?
Long Island, NY
373 Posts
Yeah and alot off roadside 7-11's would pop-up every two blocks
Posted on: 2009/4/7 2:32
CentralCoaster Re: more corn squeezins in our gas?
Good for the economy. Looks like a win-win situation all the way around.
They would have to make the lanes wider though and change the max speed signs to min speed.
Posted on: 2009/4/7 3:18
