469 user(s) are online (42 user(s) are browsing Forums)
captmike13 Failed emissions.
Holden Mo
2193 Posts
Well the vette failed emissions today. Hi HC's and CO. Running rich. No codes. I have and appointment to have it looked at tomorrow. I hope it is something simple. I'm not going to just throw parts at it. :ace: OK done ranting.
Posted on: 2009/4/15 19:38
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
captmike13@yahoo.com
pianoguy Re: Failed emissions.
Bummer! Good luck - hope they can sort it out cheaply!
Posted on: 2009/4/15 20:05
CSS996 Re: Failed emissions.
Mega Guru
Central PA
3644 Posts
Here's to a cheap and easy fix!
Posted on: 2009/4/15 20:24
Currently "Between Vettes".
BrianCunningham Re: Failed emissions.
Running rich
Could just be a temp sensor, or bad plugs
How it's something simple
Posted on: 2009/4/15 20:37
Matatk Re: Failed emissions.
22996 Posts
Hope it's an easy fix. When's the last time you changed your O2 sensor? You said it's running rich.
Posted on: 2009/4/15 22:01
captmike13 Re: Failed emissions.
Holden Mo
2193 Posts
I have never changed it. That was what I was thinking also. But that doesn't mean that it hasn't been change before we've only have had the car for just over 2yrs. I wouldn't be surprised if that is it.
Posted on: 2009/4/15 22:11
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
22996 Posts
From the sites I've read, you should change a single wire 02 sensor from our vintage every 30,000 miles. I did mine last week.
Posted on: 2009/4/15 22:27
Dads90 Re: Failed emissions.
Pearland, Tx
318 Posts
Did you get it really hot before you took it in ? They were having trouble logging onto the emissions website and my car sat (not running). When they got finally online it failed. I was bummed, read on a forum to get it hot and when I went back to another station, they too were having trouble logging on, but he let the car run the whole time and it passed. He told me that was the trick to get it to pass. Just a thought.
Posted on: 2009/4/16 3:34
Holden Mo
2193 Posts
Yes it got hot. I waited in line 15 - 20 min. I was doing some research in FSM and I thinking over what my shop said. I could have a bad fuel pres regulator, the O2 sensor. Also could be the charcoal canister. Timing, injectors (those better not be bad I just put those in last yr from John).
It is going into closed loop mode so that would eliminate the temp sensor I hope.
Just alot of stuff to digest.
Mike.
Posted on: 2009/4/16 3:54
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
captmike13 Re: Passeed emissions.
Holden Mo
2193 Posts
Turned out to be a lazy O2 sensor. The damn thing wouldn't react fast enough. It wasn't bad in such a way that it would set a code. All is good now.
Posted on: 2009/4/16 19:23
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
Glad it was resolved nice and easy.
And now the car will run better to boot!
Posted on: 2009/4/16 20:27
Sweet90 Re: Passeed emissions.
Edmonton, Alberta
1143 Posts
Good news Mike, now just nail that interview
Jim
Posted on: 2009/4/16 21:03
Lichen Re: Failed emissions.
Scottsdale, Arizona
166 Posts
Mine failed this morning too. It's always run pig-rich, but a little sea-foam has always gotten it through before. I'm getting pretty sick of this piece of plastic.
Posted on: 2009/4/16 21:51
Holden Mo
2193 Posts
I can't complain to much. It is 24yrs old and only 72,743mi on it.
Posted on: 2009/4/16 23:10
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
22996 Posts
See - simple stuff! Glad it was the 02. I replaced mine and it's still running rich. Gotta figure out why. I plan on seafoaming it over the summer - but in a deserted parking lot
Posted on: 2009/4/17 1:24
CentralCoaster Re: Failed emissions.
Running rich usually doesn't get you high HC. I'd be looking at the ignition system for that issue.
Look on the bright side, an excuse to get your car tuned up and running right.
Posted on: 2009/4/17 2:24
