209 user(s) are online (115 user(s) are browsing Forums)
JonnyAngle All 4 U Joints?
Minneapolis, MN
151 Posts
I've got a bad u joint in the rear, so I'm going to replace it. Am I supposed to replace all 4 at the same time, or is that not necessary?
Posted on: 2009/6/16 18:45
BrianCunningham Re: All 4 U Joints?
If one's shot, so are the others
Better safe
At least do the two on the same subaxle.
Also check you bearing
They're a real PITA to change, now would be the time.
Posted on: 2009/6/16 18:49
jhammons01 Re: All 4 U Joints?
I have a thread on Switching the u-joints on the half shaft
http://www.corvette-guru.com/modules/ ... =ASC&type=&mode=0&start=0
Posted on: 2009/6/16 19:43
Matatk Re: All 4 U Joints?
Me too. Just look for it in C4 technical. Don't buy greasable AC Delco.
Posted on: 2009/6/16 22:56
I don't know what brand I got...but they have the zirk fitting....
Someone said they don't fit...but they do.
Posted on: 2009/6/16 23:38
vetteoz Re: All 4 U Joints?
jhammons01 wrote:
I don't know what brand I got...but they have the zirk fitting....Someone said they don't fit...but they do.
It is not the fitment but the theory that the hole for the zerk weakens the cross that makes people recommend solid u-joints with no zerk
Posted on: 2009/6/17 13:13
JonnyAngle Re: All 4 U Joints?
Minneapolis, MN
151 Posts
what kind of grease do you put in the zerk? The ones I ordered came with the zerks and are not greased at first glance.
Posted on: 2009/6/20 2:53
Cup grease in a tube......you need that squeeze gun and any cup grease (where is the run and hide icon) If you are greasing all the Zirks regularly what you put in is not so critical.
Posted on: 2009/6/20 3:48
CentralCoaster Re: All 4 U Joints?
I recommend ujoints with zerks for anyone who doesn't race the car or have added HP.
Posted on: 2009/6/20 6:14
I bought the Mobil 1 synthetic grease at autozone. Was about $6 or $7 for the big tube. You can use others, but Mobil 1 is good quality.
Posted on: 2009/6/20 13:07
How bout those that just go to Kragen and buy what they have?
Posted on: 2009/6/20 16:19
Minneapolis, MN
151 Posts
...or NAPA!
Posted on: 2009/6/20 17:53
