JonnyAngle | All 4 U Joints? | ||
I've got a bad u joint in the rear, so I'm going to replace it. Am I supposed to replace all 4 at the same time, or is that not necessary?
Posted on: 2009/6/16 18:45
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
BrianCunningham | Re: All 4 U Joints? | ||
If one's shot, so are the others
Better safe At least do the two on the same subaxle. Also check you bearing They're a real PITA to change, now would be the time. |
Posted on: 2009/6/16 18:49
jhammons01 | Re: All 4 U Joints? | ||
I have a thread on Switching the u-joints on the half shaft
http://www.corvette-guru.com/modules/ ... =ASC&type=&mode=0&start=0 |
Posted on: 2009/6/16 19:43
Matatk | Re: All 4 U Joints? | ||
Me too. Just look for it in C4 technical. Don't buy greasable AC Delco. Matthew |
Posted on: 2009/6/16 22:56
I don't know what brand I got...but they have the zirk fitting....
Someone said they don't fit...but they do. |
Posted on: 2009/6/16 23:38
vetteoz | Re: All 4 U Joints? | ||
jhammons01 wrote: It is not the fitment but the theory that the hole for the zerk weakens the cross that makes people recommend solid u-joints with no zerk |
Posted on: 2009/6/17 13:13
JonnyAngle | Re: All 4 U Joints? | ||
what kind of grease do you put in the zerk? The ones I ordered came with the zerks and are not greased at first glance.
Posted on: 2009/6/20 2:53
Cup grease in a tube......you need that squeeze gun and any cup grease (where is the run and hide icon) If you are greasing all the Zirks regularly what you put in is not so critical.
Posted on: 2009/6/20 3:48
CentralCoaster | Re: All 4 U Joints? | ||
I recommend ujoints with zerks for anyone who doesn't race the car or have added HP.
Posted on: 2009/6/20 6:14
I bought the Mobil 1 synthetic grease at autozone. Was about $6 or $7 for the big tube. You can use others, but Mobil 1 is good quality.
Matthew |
Posted on: 2009/6/20 13:07
How bout those that just go to Kragen and buy what they have? |
Posted on: 2009/6/20 16:19
...or NAPA! |
Posted on: 2009/6/20 17:53
